Tengo que resetear jbc kd r538 prende pero dice reset tunyn
SOURCE: no funciona mi mp3 Philips GoGear SA178
Go to: (Va a:)
www.usasupport.philips.com - click on Espanol
Enter your model number (Entra su numero de modelo)
On the next page, click on your exact model number without the "B" on the end
On the next page, click on "User's Manuals" - look for "Repair"
En Ingles:
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
SOURCE: codigo de seguridad para ingreso y su funcion
puedo desbloquear una radio kdc-mp522 sin el control remoto
SOURCE: necesito el code,pero no tengo control remoto.
Hola zubiate712,
Usted puede comprar el teledirigido en línea del almacén accesorio de Kenwood.
El número de modelo para su KDC-MP235 es RC-557 y el coste es el envío más $9.75.
Espere que esto ayude.
SOURCE: no enciende
Los "pi" que escuchas en tu computador son codigos que la tarjeta madre envia para comunicar que hay algo que anda mal.
Dependiendo de la cantidad de "pis" y el intervalo entre ellos se puede descubrir cual es la pieza dañada.
Mencionas 6 "pi", y deben tener un intervalo quizas de 1 o dos segundos entre ellos.
Eso es definitivamente daño de memoria.
Para asegurarte cual es el modulo dañado, solo remueve toda la memoria que tienes instalada, y enciende tu computadora sin ellas..
Veras que los mismos "pi" siguen apareciendo.
Aprovecha y limpia los conectores de polvo etc.
Si tienes solo un modulo, entonces reemplazalo para que se solucione tu problema.
Si tienes mas de uno, instala uno a la vez para detectar cual es el bueno.
Asi tu computadora trabajara otra vez.
SOURCE: No hay video en estereo eurovox EV-D5089BTi
paysa lo que tiene que ser es buscar otro nuevo. busce en las casa ahenas y en las yardas. luego se toma su modelo y tecate. no vale la america. puro chiva
