Question about Brother MFC 8500 All-In-One Laser Printer
Brother mfc 4100e need to print out counter info. for copies and print
  • 32 Answers
On the control panel u have to see reports botton after press it have to select user setings!if u don't have this botton in menu u have to find print reports and there again user setings!i gues the print reports in menu are at number 5 !
Posted on Jun 19, 2009
I have a brother mfc 3360C fax and it gives me error message 50.How do I reset the machine.
How to the Reset Purge Counter on a Brother Printer (With a Numerical Pad)
The 'Unable to Clean: Machine Error 46? message prevents you from printing on your Brother inkjet printer. It is especially frustrating when you realise there no reason why you can't carry on printing other than this message. Continue reading to find out what makes me say this and how you can rid yourself of this error.
This guide will deal specifically with Brother inkjet printers that have a number pad on the front of the printer. If you printer has a touchscreen as well as a numerical pad please see here. If however your printer does not have a number pad at all, the guide found here should be of use.
What is Error 46? 'Error 46: Unable to Clean' indicates that your Brother printer believes the ink absorber in the base of your printer is saturated with ink and any further printing could cause ink to overflow. How full this waste ink tank is has been estimated by monitoring how many pages your Brother printer has produced and how many manual/automatic cleans have performed. Sadly this is not a particularly accurate method of measuring how full an ink absorber is and the majority of the time your printer could prints hundreds of pages before there was any danger of any ink escaping. However getting the waste ink tank changed and resetting the counter can be an expensive procedure if you get a service centre to do it on your behalf. In many cases owners of Brother inkjet printers report the cost of the procedure outweighs the value of their printer.
With this in mind we suggest resetting the purge counter of your Brother printer using the method described below and continuing to use it until waste ink begins to overflow inside/outside the printer. This ensures you get the most out of your printer and can avoid replacing it until it becomes necessary to do so. I do however recommend you protect any surfaces around the printer should you decide to reset the purge counter to save any surfaces becoming stained with printer ink.
What printers will this reset work with? This reset procedure should be compatible with almost any Brother inkjet printer with a numerical keypad on the printer itself (and not touchscreen panel) and has been tested on every current compatible printer at our disposal. You can find a full list of compatible printers below:
Brother MFC-210C, MFC-215C, MFC-3240C, MFC-3340CN, MFC-3342C, MFC-410CN, MFC-420CN, MFC-425CN, MFC-5440CN, MFC-5840CN, MFC-620CN, MFC-640CN, MFC-640CW, MFC-820CW, MFC-235C, MFC-260C, MFC-240C, MFC-3360C, MFC-440CN, MFC-465CN, MFC-5460CN, MFC-5860CN, MFC-660CN, MFC-665CW, MFC-680CN, MFC-845CW, MFC-885CW, MFC-250C, MFC-255CW, MFC-295CN, MFC-297C, MFC-490CW, MFC-5490CN, MFC-5890CN, MFC-5895CW, MFC-6490CW, MFC-790CW, MFC-990CW, MFC-J615W, MFC-J220, MFC-J265W, MFC-J410, MFC-J415W, MFC-J430W, MFC-J5910DW, MFC-J625DW, MFC-J6510DW, MFC-J6710D, MFC-J6710DW, MFC-J6910DW, MFC-J825DW
If you have a printer with a numerical pad not covered above and find the purge counter reset works for you then please let us know so we can update our list.
Video Guide Purge Counter Reset Instructions Please note that some of the terms used below to describe buttons may change from one printer to another. For example:
  • START may be down as MENU or SET on your printer or be a green button
  • STOP may be referred to as EXIT or a red button
Before you begin the reset procedure your Brother inkjet printer needs to be in maintenance mode, but depending upon the model of your printer the method of doing this will vary. For most modern Brother printers please try the following:
  1. With the printer turned on and ready to print remove the power cable from the printer (or turn the printer off if you have a fixed power cable).
  2. Hold down MENU/SET/START and re-insert the power cable/turn it back on.
  3. Keep the button held down until the screen reads MAINTENANCE.
If your screen does not now say MAINTENANCE it will need to be put into maintenance mode using one of the two methods below:
  • Printers with a built-in Fax: Hold down MENU/SET/START and quickly press * 2 8 6 4.
  • Printers WITHOUT a Fax: Hold down Menu/Set and the Black Start key before pressing the UP arrow four times.
Now your printer should say MAINTENANCE on the screen and you are ready to begin the process of actually resetting the purge counter.
  1. Type in 80 using the numerical keypad.
  2. Use the DOWN key to locate the purge counter. eg. PURGE0060025
  3. Use the number pad to enter 2783 (this should zero the numbers after PURGE).
  4. Press STOP/EXIT to return to the first stage of maintenance mode.
  5. Press 9 and 9 to exit maintenance mode.
Your purge counter is now reset and you can now resume printing as normal. If however this has not cleared the error message I advise going through this guide again following the instructions to the letter. If the error persists please let us know.
I hope you have found this guide useful. If however you have anything to add or any further questions please don't hesitate to let us know in the comments.
Jun 02, 2015 | Brother Office Equipment & Supplies
Number of pages printed on my printer
Sure!!, simple: Click on MENU, LCD screen on the printer; scroll to #8 (Machine Info), click ok., 2 (Page Counter). "TOTAL XXXXXX" appears on the display. Give you Total, Copy's and faxed totals....How about that sports fans!
May 15, 2014 | Brother MFC-9840CDW Laser Printer
Drum Life Ends soon - Brother
The problem with this is the design. Each toner cartridge has a microchip on it, that counts the pages you print. The company has determined that you get x amounts of prints. Then you have to replace it, empty or not. This printers do not work the same way as an expensive professional business copier. In an pro style there is a spent toner cartridge that collects all of the wasted toner that is on the drum. On a small business/home style this spent toner goes back into the cartridge. There is no level indicator, even on the inkjet printer. They too, have a chip that says you have x amount of prints/cleaning cycles they can go through. Look up inkjet refill kits or inkjet cartridge programmer.
Mar 31, 2014 | Brother Mfc-7340 All-in-one Laser Printer...
2" black band prints on right-side of every page
print a report, any report, from your control panel. if it looks good and your band is only on copies and transmitted faxes, that would be your Contact Image Sensor going bad. its located under your document feeder and looks like a sinny piece of glass that runs left to right.
hth,
razors
Nov 14, 2011 | Brother IntelliFax-4100e Fax
Replace drum, still says replace the drum and now it won't print.
Did you reset the drum counter?
When you replace the drum unit with a new one, you need to reset the drum unit counter by completing the following steps:
  1. Turn the the machine’s power switch back on.
  2. Press Menu => Machine Info. => Reset Menu.
  3. Press the Up or Down Arrow key to choose Drum.
  4. Press OK.
  5. Press 1 to reset the drum unit counter.
  6. Press Stop/Exit.
I hope this helps.
(if you did the reset, you may need to talk to Brother Support. I'm assuming you used a Brother drum and only handled it by the handles.)
May 12, 2010 | Brother MFC-9440CN Laser Printer
Brother IntelliFax-4100e Fax Reset drum counter
With the front cover still open, you should press Clear ("Replace Drum?" should appear on the display), and then 1 for Yes. Wait for "Accepted" message and close cover.
It may be necessary to remove the drum unit and put it back in, and then, with the cover open, do the a/m procedure.
Nov 07, 2009 | Brother IntelliFax-4100e Fax
Brother mfc 8500 is there away you can print out the counter information . like how many copies or prints have been done on it.
Try this:
Power off. Hold down the "Menu" button while you power back on.
Machine should say "maintenance"
Press "7", "7"
Slight pause and then machine will print out a report containing lots of counter information.
Press "9", "9" to exit (or switch off/on.
Jun 19, 2009 | Brother MFC 8500 All-In-One Laser Printer
I replaced all the ink and my brother mfc 240 still wont print black, or copy black, or test print black
i replaced all the ink and my brother mfc 260 still wont print black, or copy black, or test print black
Mar 24, 2009 | Brother Multi-Function Center MFC-240C...
My brother mfc7420 won't send or receive faxes.
please give me more info! what is on the screen? i am a brother tech, i will try and help you but i need mmore info.
Dec 16, 2008 | Brother MFC 7420 All-In-One Laser Printer
Product info
yes. It can fax and copy in b/w or color without pc.
Apr 08, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC 8500 All-In-One Laser Printer Logo
93 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
