Question about Dynex 32 in. LCD Flat-Panel HDTV
Trying to change tv channel to 04 for cable and can't seem to be able to add it
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 164 Answers
Ash Far-Ross: Make sure you have and use the TV remote or use the channel changer ON the TV it self. NOT THE CABLE BOX REMOTE. try that on for size.
Posted on Apr 19, 2014
How do I select channel 4 for cable box to work?
Channel 4 must not be an active broadcast channel in your area so you can try to fool your TV by entering 04 using the keys on your remote.
Aug 23, 2015 | Seiki Televison & Video
Accidently changed something and not able to get antenna tv now - do not ahve cable here at work
I am unable to see at a glance how to correct this but it is between its menu, channel and volume buttons to alter the settings it may be worth to run through the re-tune sequence below?
To preset a channel or to change a preset channel, follow the procedure below.
1) Press the POWER button to turn on the TV.
2) Press the MENU button so that the menu display appears
on the TV screen.
3) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
Then, press the VOL(ume) ? button.
4) Press the CH(annel) ? or ? button to point to "AUTO PRESET CH".
The tuner scans and memorizes all active channels in your area.
? The TV distinguishes between standard TV channels and cable channels.
? When AUTO PRESET CH action is completed, the lowest memorized channel reappears on the
screen.
? When you press the CH(annel) ? or ? button after selecting "AUTO PRESET CH", the tuner
will stop at the memorized channels only.
? The TV may recognize TV channels to be CATV channels by the receiving conditions. In this
case, try AUTO PRESET CH action again in the fine receiving conditions.
? When AUTO PRESET CH is activated where there is no TV signal input,"NO TV SIGNALS"
will appear on the display after the completion of channel scanning.
[ADD/DELETE FUNCTION]
1) Press the MENU button so that the menu display appears on the TV screen.
2) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
3) Press the VOL(ume) ? button so that "ADD/DELETE" is selected.
4) Use the CH(annel) ? or ? button to select the
channel you wish to put into memory or to erase from memory.
Note: The menu will disappear in about 10 seconds.
Perform "ADD/DELETE" function while this display appears on the
screen.
? Press the VOL(ume) ? or ? button to light up the channel number
in LIGHT BLUE if you wish to add the channel into memory.
in LIGHT RED if you wish to erase the channel from memory.
5) Press the MENU button to exit the menu.
Hope this helps.
Jun 29, 2015 | Durabrand DWT1304 13" TV
What buttons do i press to add/delete channels on emerson tv model# EWC1304? I cannot seem to get pass channel 2. I have no remote.
I have the same problem, my tv will not allow me to change channels but will only let me add/delete the channel the tv is currently on
Oct 11, 2011 | Emerson EWC1304 13 in. TV/VCR Combo
Rca hdtv channel changed by mistake
RCA channel setup and selection is not easy to understand. You may try to add channel 3 on the add/remove channel section. If that doesn't work try pressing the input button. Good Luck.
Feb 28, 2010 | RCA HD52W56 52" Rear Projection HDTV
Add or delete channels on LXI tv
I have a Phillips LXI 46in TV. How do you save channels?
Jun 15, 2009 | Philips TP2784C TV
Channel changes by itself
There is a button on the remote when if pressed will surf through all the channels on its own.Other than that you have a ghost in your house and should evacuate imediatly.
May 07, 2009 | Samsung LN40A650A LCD TV
I need playback channel for tv to be ch.4 -
Solution 1
How to set the DVD Recorder+VCR’s RF output channel
Turn off the DVD Recorder+VCR, then press and hold
CH (v/V) on the front panel for about five
seconds to change the RF output channel (CH 03 or
CH 04). “RF 03” or “RF 04” appears on the front panel display.
Solution 2
Cable Service With Cable Box
If a cable box is required in your cable system, follow the
instructions shown below. This hookup permits both TV and
DVD Recorder+VCR operation.
To view or record a CATV channel:
1 Tune the TV to the correct video input channel.
2 Set the DVD Recorder+VCR to the output channel of the
cable box using the CH (v / V) or the 0-9 keys on your DVD
Recorder+VCR (e.g., CH3).
3 Select the channel you wish to view on the cable box.
Please rate this a fixya
Jan 30, 2009 | GoVideo Go Video DVD/VCR Combo
I get no channels wen i plug in my cable wire into the cable jack
First, I would change the cable that comes from the wall to the TV.
Plug the cable into the cable port, then go into the menu of the TV. Go to the channel setting and go down to where it says "CABLE YES/NO"and change it to cable YES. Then try to re-autoprogram it.
If there are no channels found after that, then you may have an issue with the tuner.
Jan 07, 2009 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Dont seem to be able to install channells in
Auto installation should search for local tv stations, or add new channels, then it will search for new ones.
Feb 20, 2007 | Philips 14PV225 14 in. TV/VCR Combo
Dynex 32 in. LCD Flat-Panel HDTV Logo
37 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
