Question about Refrigerators
Water doesnt come out of cooler on viva water cooler
  • 957 Answers
If you have no water at the door do you get any ice in the ice bin? If not then you may have a bad water inlet valve. First check to see that water is getting to the fridge with some force not just a dribble. If u are getting a good flow of water then replace the inlet valve.
Posted on Apr 20, 2014
Can I store my viva water cooler Ina pantry if I get an electrician to put an electrical outlet in the closet?
As long as there is enough ventilation to let air in and out of the pantry so the coolers refrigeration functions are not impeded. It should be OK
Aug 26, 2017 | Measuring Tools & Sensors
Viva bottom loading water cooler does not dispense water
Some others addressed this issue on Fixya.com before:
Brett 42 said: the water line is froze.. I took a hair dryer and applied it directly to the dispenser for about 10 minutes. I then held down the buttton for approximately 30 seconds and the water began to drip extremely slowly then faster until a small chunk of ice shot out of the dispenser. I believe the reason this happened was that I the temp of my freezer set lower than the fatory setting.
Mike Smith said: "1) remove the tubing connector behind refrig kickplate . Press for water . If no water comes from tube under refrig , then possibly frozen tank but probably not . Probably bad water inlet valve . ( tank is in the lower potrion of the refrig section behind the crispers ) .
2) if water does shoot out , then your freezer door is frozen which requires leaving door open and tapeing light switch closed and tape plastic around freezer section opening so fridge will continue to operate normally . Thawing freezer door could take a day or 2 . 3) You can plug the hoses back togather and walk by occasionally pressing water untill comes out . Lower your freezer temperature setting also ( could be set for too cold)"
I hope this helps you out!
Apr 09, 2017 | Water Filters & Coolers
Request unlock HTC viva touch
Hi, To which network has your HTC TOUCH VIVA has been locked to? You can unlock your HTC TOUCH VIVA safer and easier using unlock code. You can get the unlock code for a HTC TOUCH VIVA from www.onlinegsmunlock.com/htc-touch-viva/rs7wp9/ at affordable cost.
UNLOCKING STEPS FOR HTC TOUCH VIVA
1. Switch ON your HTC Touch Viva with a Not ACCEPTED SIM Card.
2. If your HTC Touch Viva asks for a PIN code, then enter your SIM card PIN and press OK.
3. HTC Touch Viva will ask to enter an "unlock code".
4. Enter Unlock Code we send to you.
5. Your HTC Touch Viva is now unlocked.
Oct 06, 2012 | Cell Phones
Viva water dispenser Noise
The cooler is making a bep noice
Jan 20, 2012 | Refrigerators
Water leaked into transmission and transmition oil into radiator
Your transmission cooler is cracked. Discontinue using that cooler immediately. Get some caps, cap off the cooler. Replace the cooler with an after unit vor about $80.00. Change the transmission fluid and engine coolant before you drive any further.
Sep 19, 2011 | 1996 Ford Explorer
1950 ford, runs cooler on pure water, should I ad rust preventor. In ms.V8 flathead. earlier tried two gallone of antifreeze and it got hot..holds 16 quarts..water pumps working, radiator pretty...
antifreeze raises the boiling temp of water from 100c to about110c,it also inhibits rust,AND if you have alloy heads it stops them from corroding next to cast steel blocks.IT IS NOT A GOOD IDEA TO RUN WITHOUT ANTI FREEZE AT ALL.....30% IS THE IDEAL MIX..(50/50 BELOW MINUS 0C)
Jul 21, 2010 | Ford Crown Victoria Cars & Trucks
Free download for usb driver for the htc viva fone
check what OS you are using...if XP then download active sync Microsoft website... if windows vista or 7 then download microsft mobile device center... your PC will then recognise the phone.
Jul 20, 2010 | HTC Touch Viva Cell Phone
My water cooler runs but it doesnt cool anymore, is it worth fixing, its about 5 years old. It a unit that holds a 15litre bottle
Hello. The sad reality these days is that a service call is generally going to cost you about $100. or more. You can purchase a new and much more efficient cooler at a box store for a very low price. AND, many bottled water companies give you a loaner cooler if you have them deliver the water to you.
Nov 11, 2009 | Refrigerators
HTC Touch Viva is not charging
You have to check first the charger you can used multitester in position DC volt to make sure the voltage no problem, if in the plug no voltage maybe the cable damage, or the soldering on pcb circuit bad,you can try with another charger first to make sure where is the problem.
Jul 12, 2009 | HTC Touch Viva Cell Phone
Refrigerators Logo
220 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
