Question about Ironman 430r Recumbent Bike
E1 error pec 7500
E1 error code showing on power up, will not work after that
E1 error code displays when unit is plugged in I have a wall unit with about 10,000 BTU capacity. Two days ago, it quit working and displayed the E1 error code. I unplugged the unit, let it sit for 10...
highly annoying issue error code E1. After hours
of fan operation, the error code E1 will appear on the seven segment
LED temperature display. This error code is intended as a reminder for
the user to clean the air filter. However, because the procedure
outlined in the user manual does not clear this error code as
indicated, and the appliance has a nonvolatile memory that cannot be
reset by simply unplugging it, the user of the appliance will become
mightily frustrated, standing in potentially sweltering heat watching
the appliance repeatedly shut down in the midst of operation with the
"E1" display flashing.
Believe it or not, that is what it does: if you unplug it to remove the
"E1" code from the display, and plug it back in and re-start it, it
will simply run for anywhere from a few minutes to a few hours, and
then merrily shut down again with the same flashing "E1" code.
So you will come home to a hot bedroom, living room, etc. unexpectedly,
and you will NOT be amused, as I was not.
Many people at this point, having put the manual under the canary or
some such, will simply return the unit and never buy another Sharp air
conditioner. But for the tech-savvy and search-adept, I offer the
following procedure to clear the nefarious E1 indication, and obtain
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
_____________________________________________________
Was this solution helpful? Show your Appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
Jun 05, 2008 | Haier hwr10xc6 Air Conditioner
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    Fix error code E1-F1 on kenmore oven...model-95802000
    That us usually a fatal error of the control board unfortunately. the control may need replacing.
    Sep 17, 2014 | Kenmore Kitchen Ranges
    Error e1 f1
    F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
    Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Apr 27, 2010 | Kenmore 91112 / 91114 / 91117 Electric...
    Error codes E1 to E5
    E1: tape end detection LED open
    E2: front loading motor lock
    E3: loading motor lock
    E4: cylinder motor lock
    E5: reel motor lock
    These are from a Panasonic AG-7500 service manual.
    Mar 04, 2010 | Panasonic Televison & Video
    Error mesege Showing E1
    The E codes E1-E7 are displayed in the copy counter.To display both digits of the E code press the ENTER key.When the machine detect E13 condition E1 is displayed in the copy counter.Hold down the enter key and 13 is displayed.
    E 11 - Exposure lamp error.In this case check the exposure lamp continuity,the thermofuse is open or power suplly board defective.
    E 12 -Exposure lamp error .AC drive defective,main board defective
    E 13 - Zero cross signal error.Main control or DC power board defective.
    To clear the service code turn OFF/ON the machine.
    Sep 09, 2009 | Ricoh Office Equipment & Supplies
    What is the error POW 5 on a marantz sr 7500
    I have a POW 5 failure on a marantz sr 7500. Anybody know how to fix?
    Jun 02, 2009 | Marantz SR-7400 Receiver
    After a power outage oven will no longer work
    Apr 02, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
    Oven has error E1 F1 will not work
    F1 - E1
    EEPROM checksum error
    1. Disconnect power for at least 30 seconds.
    2. Re-apply power and observe for at least one minute.
    3. If code re-appears, replace control board (also called ERC or clock).
    Jan 11, 2009 | Whirlpool RBS275PD Electric Single Oven
    Ironman 430r Recumbent Bike Logo
    37 people viewed this question
    Top Ironman Sport & Outdoor - Others Experts
    Bill Eager
    Are you an Ironman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
