Question about Cub Cadet Garden
Drive pedal will not move forward or reverse when pressing drive pedal
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Cub Cadet Master
  • 1,917 Answers
Pump is bad replce it
Posted on Dec 17, 2014
4 Suggested Answers
  • 110 Answers
SOURCE: 1554 cub cadet stalls out when you turn mower deck
Seat switch - or the wiring to it - is bad.
Posted on May 08, 2010
dadevildog20
SOURCE: when mowing today i press drive pedal mow would not go forward or reverse
what kind of mower do you have? make and model would help, if its a riding mower check to see if your disengagement lever is pushed in, on some models the lever can come out of the transmission so make sure its in the lever on the transmission. then I would check your drive belt and tensioner.
Posted on Mar 25, 2012
  • 6468 Answers
SOURCE: Have a cub cadet lt 2042. When you take your foot off the forward pedal, unit keeps moving and does not stop. will stop if you hit the reverse pedal. Was told the damper was bad and that has been r
there is a adjustment on the linkage i looks like a triangle shape block with a offset screw on the rear axle near where the rod meets the rear axle move it a little at a time
Posted on Jun 09, 2012
I inherited the mower - JD Sabre -engine runs well but it will not move forward or backwards - it is belt driven - any ideas please?
if there is a pedal on the right side then press down on it with your toes or the heel of your foot .toe moves it forward heel reverse
Jan 23, 2016 | Garden
I have all gears but reverse and when in park and neutral and gas pedal is pressed the car moves forward, why?
well could be two things. either your transmission has crapped out on you. or you have a shifter linkage issue. which means when the car is in park its not really in park. try this. move the shifter and see if the car moves in a different gear then what it says it is in . so if it moves in neutral it could be drive and reverse is neutral. if it does not reverse at all. time for a new trany is my guess.
Mar 17, 2015 | 1997 Toyota Camry
Why would a vehicle in reverse move forward
The question is a little vague but I think I know what your referring to. All modern automatic transmissions have torque converters. This is the device that connects the engine to the transmission. All vehicle manufacturers like the trans to be nice and smooth shifting. That's great but it does come with some minor drawbacks. If you are facing slightly down hill and you put your car in reverse but do not step on the gas slightly I can guarantee that you will indeed roll forward. You can eliminate that issue by holding your left foot on the brake while you shift into reverse. Then, as soon as you feel the trans engage, gently depress the gas pedal with your right foot and it will eliminate that forward roll problem.
Sep 25, 2014 | Cars & Trucks
Replaced drivebelt on troybilt riding mower now the forward pedal moves mower in reverse?
Sounds like you have the belt running in the opposite direction. You need to Change the way the belt is routed around the pulleys
Jun 18, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
Depress drive pedal forward or reverse, tractor will not move
Assume it's a hydrostatic transmission - most probably the drive belt has come off or broken. Be sure to replace it with a Kevlar belt as changing the belt isn't easy and you don't want to have to repeat the process too soon.
Apr 19, 2014 | Cub Cadet Garden
Husqvarna 2754GLS, Hydrostatic forward/reverse pedal will not return to neutral position.
Parts and Diagrams for Husqvarna 2754 GLS 96043004700 2008 01
I suggest following all the safety procedures suggested in the operators manual first!
ENGINE NOT RUNNING,wheels blocked to prevent being run over, check the return spring ref # 161
Apr 12, 2014 | Husqvarna Garden
John deere sabre 2354 hv moves slow forward, even slower in reverse
this hydrostat drive tractor is designed to max at 5.5 mph forward, 2.5 in reverse, check linkage at pedal if you dont think your achieving those speeds
Mar 23, 2013 | John Deere 420,1020,2010,2020,2510,2520...
John deere 3320 starts up,engine runs,pto works however will not drive.error code 01 and 12 keep showing up
Both codes are related to the forward and reverse pedals.To cycle through and clear the codes,turn the key on and then press the forward pedal to the deck within 2 seconds and release and the do the same with the reverse pedal,the code should go away unless the problem persists.If so then you need to check the wiring to the potentiometers on each pedal and also check to see if one has been moved[knocked out of range]If none of the above is the case then either the forward or the reverse solenoids could be stuck there-by letting the tractor think you started it in gear,hence no movement,these checks are not really a do-it-yourselfer type checks so you may need to seek help from Deere,hope this helps,thanks.
Feb 11, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
41 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
