Question about Cuisinart DGB-500 Coffee Maker
Quisinaart Grind & Brew DGB-500BK shuts of power to machine while brewing
While brewing the machine shuts off including the display. Sometimes it will start if hit on the right side, but usually it has to be unplugged and plugged in again. Even that doesn't fix it all the time.
SOURCE: Automatic Grind not working
My grinder was not working properly, because the blade was not rotating freely. So we carefully chipped away some caked on coffee residue. Then it worked for awhile, but started to sound weird and only partially grind the coffee. So we applied a small amount of vegetable oil to the blade and let it seep down a little, and that was very succcessful! Just needed a lube job!
chrisnap49
Posted on Jul 07, 2008
SOURCE: cuisinart grind and brew
This happens when the machine needs cleaned. Fill coffee maker with white vineger instead of water. Turn grind off, make sure empty pot is in place. Brew a pot of hot vineger. Repeat. Brew a pot of hot water. Repeat. This process removes mineral buildups inside machine. If you have access to filtered water, start using that to brew your coffee. I do and probably do this process 1 per 6 weeks.
Posted on Oct 07, 2008
SOURCE: I Have a Cuisinart Automatic
I do love our Cuisinart pot...but find they only last 2-3 years...so my suggestions is: if the pot is still in warranty, call Cuisinart for a new one...they are great about it. If you don't know if it is still in warranty, call them, give them the number and they will tell you.
jlo
Posted on May 31, 2009
  • 85 Answers
SOURCE: Machine shuts off during brewing
Hello bean_54806,
This is a really common problem with the cuisinarts. I am most familiar with the DCC-1200, but you may be able to solve the problem. The may be an indication that something is plugged up. Open the top of the unit and in one of the corners you should find a water filter stick or column that is removable. Pull it out and open it up to clean out the clogged up carbon filter in there. (You can later buy a new filter on Amazon.) Clean out the debris from the bottom of the cavity. Replace the stick into the cavity once cleaned. Now it's time to run through a solution of 2 parts water and 1 part vinegar. Do this once or twice with fresh solutions, then with a pot of fresh water. When the filter stick is plugged up the sensor says its time to clean it or shuts the unit down, but most people don't know about this fix. I hope this is helpful to you, bean. Positive feedback is appreciated. Good luck. NormanZ
Posted on Jul 11, 2009
  • 464 Answers
SOURCE: My Cuisinart 10 cup Grind & Brew does not
you need to run a few pots of straight white vinegar through the machine to clean out the lime build up in the tubes. the first time you do it, after it starts to pump the water, shut it off for a few hours and let the vinegar sit in the tubes. after doing this run a few pots of cold water through before making coffee.
Posted on Nov 08, 2009
Need manual fordgb300bk
Here is the link (this is for a mac) Cruisinart COFFEE BAR Automatic Grind Brew DGB 300 SERIES MANUAL...
or there is a website called manualonline.com
Mar 16, 2014 | Cuisinart DGB-300BK Automatic Grind & Brew...
This coffee maker (10 c maker with grinder) beeps it's done every few minutes with water left. we have to brew about 5 times for a full pot, what gives?
Presume this is the Grind & Brew Thermal™ 10-Cup Automatic Coffeemaker, Model # DGB-600BCC
An instruction booklet is available here: http://www.cuisinart.ca/pdf/ibs/en/DGB-600BCC_en.pdf
Review the sections beginning on page 11 of the pdf on Turning Off the Grind Function (if not using the grind feature) and Making Coffee.
Make sure you are turning off the grind function if using preground coffee and that the reservoir lid is securely closed.
Check the Cups Setting button; is sounds like the 1-4 feature may be turned on.
Jan 30, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
Just bought a cuisinart grind & brew dgb-550 and can't get the program setting to work. Tried putting in a time and leaving it and tried pushing the program button after entering the time.
Push the program button one more time - the first push allows you to set the time, the second push stores the time you have just entered, and then you have to press it one more time to make the light next to the program button light up tell it to brew at the set time.
Aug 23, 2009 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
Need instructions to operate DGB-600BC
Thanks for the reply. Got rid of the coffee maker. Its a dud. No more information required.
Jun 18, 2009 | Cuisinart Thermal DGB-600 Grinder
WARMING PLATE DGB 300
The Automatic Shutoff Time can be programmed
anywhere from immediate shutoff
after completion of the brew cycle up to four
hours. When the coffeemaker shuts itself off,
two tones will sound. Four hours is the default
time. The 0:00 setting shuts the unit off immediately
after brewing is complete. To check the
current setting, press the “On/Off” button and
the Automatic Shutoff Time will be displayed.
To change the preset time, press and hold the
“On/Off” button until the red “power” light
begins to flash. This signals that you have
entered the “Set Automatic Shutoff” mode.
Press the “Hours” and “Minutes” buttons
to scroll forward through the digits until
desired time appears. The first setting which
appears is preset at “4:00” and the next
display will be “0:00”, since four hours is the
maximum Automatic Shutoff setting. Pressing
and holding either button will allow you to
scroll continuously, slowly at first, and then to
accelerate to the rate of about three digits per
second. As the desired time setting approaches,
release the button and then press repeatedly
to advance one digit at a time.
The Automatic Shutoff Time (ASO) may be
programmed either before or during coffee
brewing. You may also re-program the ASO
time when brewing has been completed. If you
do so, the Automatic Grind & Brew™ will automatically
account for any time that has already
elapsed after brewing.
Feb 01, 2009 | Cuisinart Grind and Brew DGB-300BK 10-Cup...
NEED oWNERS mANUAL FOR gRIND & bREW SO i CAN SET IT
if you go to this address you can download a manual...
http://safemanuals.com/user-guide-instructions-owner-manual/CUISINART/DGB-300BK-_E
if the address doesn't go just go to safemanuals.com and in drop boxes choose cuisinart/dgb-300bk. will take you to thie page.
enjoy your coffee.
Dec 02, 2008 | Cuisinart Grind and Brew DGB-300BK 10-Cup...
Cuisinart 10 cup auto grind and brew
Here is a link for the PDF version of the Instruction Booklet for the DGB-600BCC (from the name you provided I’m assuming this is the correct product).
If it’s not the right product, check out the Cuisinart.ca website, you can select the product you are looking for and download the instruction booklet from the product page.
http://www.cuisinart.ca/en/pdf/ibs/DGB-600BCC_en.pdf
Hope that helps!
Oct 15, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart Grind and Brew DGB-700 12-Cup
Hi - You can download the manual by clicking the link underlined in blue below:
DGB-700
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 12, 2008 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
I Have a Cuisinart Automatic Grind & Brew Thermal that when you start brews a small amount of coffee and then shuts off. I shut off grind and start. After I do that it brews a full pot. We have cleaned...
I have a cuisinart model dgb-600bc coffee grind & brew, didn't have a manual with it when purchased, plugged in it & hit the on button, lights up when pushing in on it, but let it go & it stops, but doesn't brew nothing. HELP -
Aug 26, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart DGB-500 Coffee Maker Logo
54 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
