Question about Cub Cadet Garden
Depress drive pedal forward or reverse, tractor will not move
Was driving tractor, running great, all of sudden it would not move forward or backward while pressing drive pedal
    Scholar:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 94 Answers
Assume it's a hydrostatic transmission - most probably the drive belt has come off or broken. Be sure to replace it with a Kevlar belt as changing the belt isn't easy and you don't want to have to repeat the process too soon.
Posted on Aug 19, 2014
5 Suggested Answers
  • 49 Answers
SOURCE: Ariens Yard Tractor 935 Series - initially drives, then stops moving as it gets warm
Is it a hydrostatic tranmission? If so, sounds like the fluid might be old or not the right viscosity. Recommend changing the trans fluid, and use recommended viscosity of fluid.
Posted on Feb 06, 2009
wadembly
  • 462 Answers
SOURCE: Sears lawn tractor. While mowing, ran over a
the branch probably got cought in the belt that runs the rearend it may have caused it to come off check the drive belt
Posted on Jun 06, 2009
  • 2841 Answers
SOURCE: tractor won't go forward or reverse
Check the drive belt. It has probably broken or has come loose.
Posted on Sep 01, 2009
saailer
  • 1868 Answers
SOURCE: I have a Husqvarna YTH
Hello! There are two known faults with the Husqvarna YTH...# 1 is the drive belt slipping...The belts have a manufacturing defect, in that they are out of specification in length...After some usage slipping occurs...#2 is a brake recall which is described below...It refers to the 19.5 HP 42" cut but the 46" cut utilizes the same braking mechanism...Guru...saailer
Brake Recall.
http://www.usrecallnews.com/2009/07/cpsc-6146.html
Husqvarna Lawn Tractor Recall: Parking Brake Failure
July 9, 2009
NAME OF PRODUCT: CRAFTSMAN LAWN TRACTORS
UNITS: ABOUT 8,200
MANUFACTURER: HUSQVARNA CONSUMER OUTDOOR PRODUCTS N.A. INC., OF AUGUSTA, GA.
HAZARD: The tractor's parking brake may fail, which could result in a loss of control.
INCIDENTS/INJURIES: No incidents or injuries have been reported.
DESCRIPTION: The recalled Craftsman Power Lawn Tractor is gray, has a 19.5 horsepower engine, automatic drive and a 42 inch cutting deck. The model and serial numbers can be found on a plate under the tractor's seat. The following model and serial numbers are included in this Husqvarna lawn tractor recall.
MODELS CRAFTSMAN 917.289080, CRAFTSMAN 917.289081, Serial numbers, 012709A001000 THROUGH 031209D999999
SOLD BY: SEARS AND KMART STORES NATIONWIDE AND ON THE WEB AT WWW.SEARS.COM (http://WWW.SEARS.COM) FROM JANUARY 2009 THROUGH APRIL 2009 FOR ABOUT $1,200.
MANUFACTURED IN: UNITED STATES
REMEDY: CONSUMERS SHOULD STOP USING THE RECALLED TRACTORS IMMEDIATELY AND CONTACT SEARS FOR A FREE INSPECTION AT YOUR HOME AND, IF NECESSARY, A FREE REPAIR OF THE PARKING BRAKE CABLE. SEARS IS DIRECTLY CONTACTING CONSUMERS WHO PURCHASED THIS PRODUCT.
CONSUMER CONTACT: FOR ADDITIONAL INFORMATION, CONTACT SEARS AT (800) 978-7615 BETWEEN 9 A.M. AND 10 P.M. ET MONDAY THROUGH FRIDAY, OR VISIT SEAR'S WEB SITE AT WWW.SEARS.COM (http://WWW.SEARS.COM)
Posted on Dec 18, 2010
Replaced drivebelt on troybilt riding mower now the forward pedal moves mower in reverse?
Sounds like you have the belt running in the opposite direction. You need to Change the way the belt is routed around the pulleys
Jun 18, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
My Weedeater riding lawn mower will not move when it is in drive or reverse
Check your drive belt that it has not slipped off the drive cog under the motor. Also check the alignment of the motor with the handle on the right side (speed, reverse, and neutral lever).. This lever tilts the engine to engage the drive belt.. there is no transmission in this machine.. just how the belt engages by its angle when you push the lever forward and backward.. If the engine is running, it must be either the belt to drive the unit or the angle has been messed up somehow..
Apr 21, 2013 | Weed Eater Weedeater 26" Riding Mower
John deere sabre 2354 hv moves slow forward, even slower in reverse
this hydrostat drive tractor is designed to max at 5.5 mph forward, 2.5 in reverse, check linkage at pedal if you dont think your achieving those speeds
Mar 23, 2013 | John Deere 420,1020,2010,2020,2510,2520...
Can anyone help? My Cub Cadet LT1045 won't move (foward/backward).
Hi, check that the drive belt, pulleys and shafts are all ok and that they are actually driving the transmission, hopefully you will see the problem. If the transmission is driving ok and the fwd and reverse lever is functioning as you said, the transmission may have failed. Also check the hydro release lever is functioning. Regards Phil.
Jun 25, 2012 | Cub Cadet Garden
Mowing right along and suddenly the tractor won't go move
it's 1 of 5 likely things
The drive belt from the engine to the transaxle is totally slipping or broken
The linkage from the control pedal to the transaxle is faulty.
The transaxle is broken (not user fixable)
The by-pass rod is pulled out
The brake pedal is pushed or the linkage is stuck in the "brake" position.
Jul 11, 2010 | John Deere 22HP Hydrostatic 42" Riding...
When I depress the forward drive pedal I move very slowly weather the deck is engaged or not. It is also very slow and sometimes stops in reverse. I usually have to use my foot and pull back on the...
You didn't specify a brand or type but it sounds like a hydrostatic drive model and if so, it is 1 of 4 likely things
Drive belt from engine to transaxle slipping badly (replace the belt)
FWD-REV pedal linkage faulty
Transaxle is broken or has fluid issues (not user fixable)
by-pass rod (neutral lever/rod) is pulled out a bit. (push it in fully!)
Jul 11, 2010 | Garden
Garden Logo
279 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
