No instruction s to put the tent together
SOURCE: toddler bed
Here is a website that has the instruction manual in PDF format.
http://common.csnstores.com/common/marketing/baby/delta%20childrens%20products/Toddler%20Bed%20Instruction%20Manual%20(dora).pdf
SOURCE: LOST TODDLER BED INSTRUCTIONS
mcdevito75 here, You can try online at Disney Beds.com for info.
SOURCE: Cars Toddler Bed problem
mcdevito75 here, Use the contact info in the istruction manual you have, and speak with Disney.
SOURCE: I purchased the toy story
there are four pockets on the inside of the tent which hold the ends of the pole with the string in them. connect all the poles with the string in them. bend it in a (n) shape and stick the ends in the pockets. the poles are bent so as to give the tent height not depth, do the same for the rear of the tent. the twelve other poles are connected using the small connectors. one connector for two poles then stick those poles into the front and rear (n) shaped poles in the empty connector spaces already on the pole you bent. remember when you bend the pole they will not stay bent until you stick them into the inside pockets in the tent. the nylon straps at the bottom of the tent help the tent to hold on to the mattress. its simple enjoy. i put all the poles together first and then had my helper to hold it in a (n) shape until i could stick the legs into the pockets. look inside the tent once together you will see where you need to tie the nylon straps to the poles
