Question about Sewing Machines
When I sew the stitching wants to gather, I've made the stitches larger and smaller and they still gather. I have a memory craft 6500.
  • 42 Answers
Rewind the bobbin. Thead may tangled.
Posted on Apr 20, 2014
    Sergeant:
  • 264 Answers
Hi' I'm Peter, I really don't think the length of your stiches is the problem. I was having a similar problem and one of the ladies at Hancock Fabrics told me just to adjust the tension on the thread and WOW something so simple made a world of a difference so give it a try you may have the tension set a little too loose like I did. Hope it helps let me know.
SOURCE: Zig Zag Skip Stitch
your machine might have a problem with the rotary hook, it might need to get timed by a professional.
Posted on Oct 30, 2007
  • 43 Answers
SOURCE: need insturtion manual for janome memory craft 6000
I can help you with the manual, but you need to provide a model number. "Memory Craft" is a designation used an many Janome models.
Dave
Posted on May 07, 2009
bugoy31
  • 1238 Answers
SOURCE: I have a Janome Memory Craft 3000 sewing machine.
Good day!!!
please apply a some oil on the motor and other moving parts inside you sewing machine..
After that reboot the machine and used it....first try is persisted but when you used it continuously for at least 10 minutes your machine is OK...
Posted on Jun 29, 2011
SOURCE: kenmore 1941 sewing machine irregular stitches
try rethreading the machine top & bobbin make sure to get ever thread guide
try chaning to needle, make sure the needle goes all the way into the needle holder-normally flat side goes to the back of the machine
check to make the thread is moving smoothly around the tension dial
if these suggestion don't help, then the machine probably could use a servicing
Posted on Mar 14, 2012
  • 1564 Answers
SOURCE: Janome Memory Craft 8900 QCP. Upper tread jamming in the bobbin area and around. Needle jumps randomly on one side. Was sowing quite thick material with straight stitch and it was fine. Then I decided
Did it break the needle when you changed stitches? Or did it just go straight to jamming.
Posted on Nov 30, 2012
Adjust the size of the stitch
Most machines have a little lever that you slide up and down or left to right with numbers on it. The larger the number, the larger the stitch. Just move the dial or lever to a smaller number.
Mar 01, 2015 | Sewing Machines
Having a problem with stitch tension can you help
is it just the fabric that is gathering or the bobbin thread also ?
Jan 24, 2015 | Janome Memory Craft 9000 Computerized...
There doesn't seem to be a stitch long enough on machine for basteing so I can gather material?
Try loosening both top and bottom tension. while longer stitches are easier, it can be done on shorter stitches as well. A bennifit to shorter stitches is the gathers will be smaller and easier to work with! Remember to reset the bobbin tension before sewing again.
Dec 16, 2012 | Janome 8080 Computerized Sewing Machine
Memory Craft won'e change stitch selection
the machine may need to be serviced to see if it's a computer problem
or mechanical one.
Apr 29, 2012 | Janome Memory Craft 9000 Computerized...
I'm using my sister's Memory Craft 4800QD, and the
try changing the needle
rethread the machine top & bobbin
make sure the bobbin is inserted correctly into the bobbin case
make sure the bobbin is threaded correctly
Apr 23, 2012 | Janome Sewing Machines
Sewing a topstitch
Top stitching is usually done with straight stitch, ie stitch width on zero and stitch length on 2.5 but it depends on the application and the effect you are trying to get. Normal top stitch is where you might be stitching a facing down on the outside of a neckline, so you might want to stitch about 5mm away from the edge of the fabric. Always stitch from the outside of the garment, the finished side so you can turn on corners and control the fabric. If you have a clear pressure foot, then this will make watching the stitching easier. Not sure what your problem is with this technique so feel free to add more in comments if I've missed something.
Oct 02, 2011 | Janome Memory Craft 5700
I have purchased a gathering foot. What do I have to have my machine on (stitch length etc.) to get good results? Thanks. Kath
You need to use a straight stitch set to about 6mm. You may also have to loosen the tension discs to mid range.
Dec 08, 2010 | Janome Memory Craft 4900QC Mechanical...
My Memory Craft sews great until I start to quilt or use one of the different stitches and then the stitches either skip or become so tiney I can't pick them out.
Skipping could indicate you need to use a larger size needle.
Tiny stitches could be save reason, or the top thread is hanging up.
Sometimes the thread can wrap around the spool pin or catch on a rough surface on the end of the spool.
Be sure to use the correct size spool cap and if the thread is wrapping around the pin, a thread net can help.
Give the machine a cleaning according to the maintenance section of the manual for your machine, including cleaning the feed dogs, bobbin case, shuttle and surrounding area.
Make sure the feed dogs are up unless you are free motion quilting and the presser foot down.
This may seem elementary.........just trying to cover all the bases.
May 02, 2010 | Janome Memory Craft 9000 Computerized...
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
