How to lite furnace for heater - Heating & Cooling
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 164 Answers
Make SURE you don't smell fuel fumes, turn fuel valve "ON" press and hold PRIME button, light flame tip, continue hold prime button down for 10 seconds , slowly release. ( look near burner door for instructions). MAKE sure there is no fumes. BigAl
Posted on Apr 19, 2014
Furnace won't lite
Look at the code explanation either on the inside of the door or thru a peephole in the panel. It will tell you what 5 flashes means.
don-ohio (:^)
Dec 21, 2016 | Heating & Cooling
Orange lite flashing when burner is on
WHAT MODEL AND BRAND FURNACE DO YOU HAVE ? USUALLY THE ORANGE INDICATOR LIGHT IS SHOWING THAT FLAME IS PRESENT. USUALLY SOLID ORANGE NO FLASH . INDICATOR LAMP COLOR AND FLASH CODES FOR TROUBLESHOOTING USUALLY ON INSIDE OF ONE OF THE DOORS AND IN PAPER WORK THAT CAME WITH FURNACE.
Jan 01, 2014 | Heating & Cooling
Pilot lite will lite but the heater and fan will not lite up or come on (model # ny117)
you need to check to see if you have power telling the control valve to open usually 24v unless it is something diffrent than a standard furnace
Dec 09, 2012 | Heating & Cooling
Four flashes open high limit explain
Blower is probably bad. Dirty filter or not enough air flow
Nov 17, 2012 | Emerson Furnace Control Board Lh33wp001...
Gas Furnace - residential -found furnace off - pilot light off -
check ur venting first make sure its not plugged
Jan 01, 2010 | Heating & Cooling
Laars Lite 2 Spa Heater
it might be the hot surface ignitor. a common problem with gas furnaces also. also, check if there is an code on your screen. it will be called an FL code. call the manufacturer.
Aug 05, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Gas furnace wont stay lite
I'm a little confused by your terminology. You are saying you have a pilot lite and electric heat strips? Are you possibly meaning burners? Is the heater running for 2 hours straight without shutting off? how cold is it there? Lastly what temperature do you have the thermostat set at and how close does it get to the temp. before it shuts off?
Dec 16, 2007 | Heating & Cooling
Goodman ac/gas furnace unit mdl. # gmp075-4
i HAD THE SAME PROBLEM, TURNS OUT IT WAS THE FLAME SENSOR, CLEANED IT, AND ALL WAS GOOD
Nov 27, 2007 | Cozy (W352E) Heater
Cozy one sided wall furnace (no blower motor)
This is a weird one, but make sure all the wire connections are in the correct place. I accidentally miss wired a heater like this and it did the same thing.
Coleman Furnace
Based on the info you have given here, I am going to make some assumptions. In "cleaning out all the components" you cleaned the air filter or changed it, cleaned the duct-work, and the intake combustion chamber? When the "furnace stays lite" the pilot and the main burner stays on? Lastly, when it "continues to blow cold air" is this when the main burner is on after long periods of time? If the answers are all yes, then maybe some of the ducts have come off, or the burners aren't working correctly.
Nov 08, 2007 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
