Question about Toshiba Televison & Video
Connect toshiba BDX3400KB to the internet
Connect to wifi
My laptop will not connect to wifi.
Is it your own wifi or a public wifi? In 9 cases out of 10, the person didn't open a browser to a new page so they could accept terms and conditions and truly connect. Just being connected in 'wifi connections', isn't fully connected. You are just connected to the signal, but not authorised to use the data feed. Sometimes when you open the browser to a new page you are asked for a password.
If it is your own, turn off wifi and then click the option that should say 'renew lease' or similar.
May 12, 2016 | Toshiba Computers & Internet
My Toshiba satellite pro c850 wont stay connect to the internet
TRY TO UN INSTALL WIFI DRIVER AND RESTART LAPTOP AND THEN INSTALL DRIVER AFTER RESTARTING THEN RESTART ONCE AGAIN AND CHECK.IF ITS NOT WORKING TRY TO UPDATE BIOS LINK FOLLOWS http://www.mytoshiba.com.au/support/computers/satellite/pro/c850/pskc9a-00t019/download?os=25.WHILE UPDATING BIOS U SHOULD BE CAREFULL BATTREY SHOULD BE ATLEAST 50 % AND UPDATE WITH POWER ADAPTER CABLE CONNECTED.
Jan 12, 2014 | Toshiba Satellite Computers & Internet
My computer does not connect to wifi and only show ethernet. i don't have a long enough ethernet so i cannot connect to my internet.
Do you have a wifi card in the computer? It is a hardware part that you need so that the computer can connect to the wifi. If you have that but can't find it in the operating system. I suggest that you either install or update the driver for it.
You can use RadarSync to scan your computer for the available updates of your wifi driver. Make sure that you connect to the internet first using your ethernet so that it will detect the available driver updates somewhere in the databases of the manufacturer.
David
http://goo.gl/CxsY9u
Aug 19, 2013 | Toshiba Satellite Computers & Internet
My loptop not working in modem,but in wifi it is working
You must run the "Connect to internet Wizard" and set up the Dial Up connection, as default, from new, so that the WiFi is NOT the default connection, OR designate the Dialup connection as "Default" and Windows will then use that one to connect to the internet.
Mar 03, 2010 | Toshiba Satellite P105-S6104 Notebook
Wifi can dtects signals, but no internt
Maybe, the router is not allowing the connection to the internet. It can also be that the cable from the modem to the router is not placed on the right slot.
Jun 12, 2009 | Toshiba Satellite U305-S7448 Notebook
M300 toshiba connecting to locally, not connect to internet
Dear Shifsa,
Considering the fact that you are trying to connect to a wifi connection which of course is unsecured,
here are some workarounds..
1. Uninstall the wireless card driver.
Go to device manager > click on the + sign beside network adapters > right click on the wireless adapter and select uninstall. Restart the computer it should get reinstalled automatically.
2. try disabling or uninstalling the antivirus or internet security software. you can later on again download the a free software from www.hippo.com
Hope this helps.
Regards,
Anup
Apr 05, 2009 | Toshiba Satellite Pro M300-S1002X Notebook
Connect to the net via wifi
go into wifi properties and select internet protocol..
here select obtain ip address auto (check box)
and same obtain dns auto
Jan 24, 2009 | Toshiba Satellite A215-S7422 Notebook
Toshiba Laptop Wifi not working
Please make sure you have turn on the wifi and your computer is updated. if you are not sure then you go to http://www.techssupport247.com/wifi-is-not-working-on-toshiba-laptop.html
Here you will get more help about wifi problem on your toshiba laptop and you will able to fix your problem easily.
Dec 18, 2008 | Computers & Internet
Cant get my unit to connect at wifi hotspots
Have you connect/pair your laptop with hotspot/access point ?
Before going into internet explorer, you should connect to the access point first.
Nov 03, 2008 | Toshiba P25-S526 Notebook
Wireless Internet Access
Hi, Normally there should be an Icon at the system tray (lower right) which is for the WiFi. Placing your mouse over the icons would tell you what the icon is for. Right clicking on the WiFi icon would show you whether it is enable or disabled. Double clicking on it would give you the WiFi access window where you can select which WiFi network you can connect to. Some of these wireless internet cafe would grant free access while others would need you to check-in with their admin or somebody and on certain cafes for a fee. Hope this be of some help to you and pls post again how things turn up. Kind regards.
Jul 19, 2007 | Toshiba P205-S6267 Notebook
Televison & Video Logo
29 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
