Question about Panasonic Matshita- | UJ-845-B | USB 2.0 | DVD-+RWRAMDL (GPUJ845BU) Burner
Matshita dvd ram uj892as region free - Panasonic Matshita- | UJ-845-B | USB 2.0 | DVD-+RWRAMDL (GPUJ845BU) Burner
4 Suggested Answers
jobsagoodun
  • 156 Answers
SOURCE: hi there, need to region free matshita 867s dvd
There is a solution, but it costs money, I'm afraid:
http://www.slysoft.com/en/anydvd.html
"AnyDVD works in the background to automatically remove the copy protection of a DVD movie as soon as it's inserted into the drive, allowing you then to backup the movie using a DVD backup tool such as CloneDVD and CloneDVD mobile. You can also remove the RPC region code, thereby making the movie region free and viewable on any DVD player and with any DVD player software."
It doesn't make the drive itself region-free, but strips out the region code of any DVD put into it...which has much the same effect.  You can play anything from anywhere, and if you're copying (your own legally purchased, of course) films, the copy is region-free.
Please rate me if you found this helpful.  Thanks.
Posted on Mar 08, 2010
elix0411
  • 3530 Answers
SOURCE: Computer is a Sony Vaio
1. Click Start, and then click Run.
2. In the Open box, type regedit, and then click OK.
3. Locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE/System/CurrentControlSet/Control/Class/{4d36e965-e325-11ce-bfc1-08002be10318}
4. Click the REG_MULTI_SZ data type UpperFilters, and then click Delete on the Edit menu. When you are prompted to confirm the deletion, click Yes.
5. Click the REG_MULTI_SZ data type LowerFilters, and then click Delete on the Edit menu. When you are prompted to confirm the deletion, click Yes.
6. Quit Registry Editor, and then restart the computer.
And another way is to make sure you have correctly inserted the IDE and Power Cables.
Thank you for using Fixya!
Posted on Oct 16, 2010
bijusasi03
SOURCE: matshita uj870 qj dvd ram can't read blank disk
Same problem on me also I am also looking for firmware
Posted on Oct 19, 2012
How to unlock region code 6 from my Matshita BD-LMT UJU-220s
Hi!
There's no RPC-1 (Region-free) firmware for your drive...
You can use AnyDVD to unlock all regions! To get more information about it and download it - look here!
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Best regards,
Pelu.
Feb 15, 2011 | Panasonic Matshita- | UJ-845-B | USB 2.0 |...
I have an Asus laptop with matshita dvd ram uj892as and when I put someone dvd or cd, noise, but nothing happens.. i need help! thank you!
You need to go to device manager and pull up the properties for the DVD drive and choose the "Region" that you are in. After that the drive should work.
Aug 18, 2010 | Panasonic Matshita- | UJ-845-B | USB 2.0 |...
Hi there, need to region free matshita 867s dvd rom. any solution available??
Mar 08, 2010 | Panasonic Matshita- | UJ-845-B | USB 2.0 |...
Dvd regions locked set on number 3 but unable to change to # 1.Have Matshita dvd-ram uj880es player on my lapttop
If the region on your DVD is locked then the EPROM has been flashed after 5 changes. The only way around this is to install a multi-region software.
The best one available is DVD Region Free. You can purchase these online at sites such as:
www.dvdidle.com
www.slysoft.com
Hope that helps
Mar 07, 2010 | Computers & Internet
My pc dvd drive won't let me change region back
No its not a bug most DVD-ROM computer drives allow you 4 or 5 region changes first check your region code and number at DVD Region Info it will tell you region code Australia is 4 UK is 2 sand so one plus you region changes http://www.visualdomain.net/
I however do suggest removing your region code from your DVD-ROM using a region free firmwar or on your PC you can use http://www.dvdidle.com/dvd-region-free.htm it is however a bit pricey the region 0 firmware hack would be better.
Dec 01, 2009 | Computers & Internet
How can i reset my cd/dvd region in my acer aspire 4715z series, i plan to do this my cd/dvd rom is choosing a disc to play, i think some change the cd/dvd rom without my knowledge and I'm not able to fix...
To change the region code on your DVD player go to Control Panel - System - Hardware - Device Manager and expand the DVD/CD ROM drives, then right click on your DVD drive and click on Properties then click on DVD Region tab. You will see the number of changes remaining (you can only change the region code 4 times and then it locks on the last region change and no further change is available). You will see the Current Region and You can change the region in the New Region box.
If you have run out of changes then you have a problem, this can be fixed. The hardest way is to upgrade the firmware on the DVD drive to a region free firmware BUT if you install the wrong firmware or stuff up the upgrade your DVD drive will be a piece of junk.
The best way is to install a piece of software that defeats the region code. There may be some free software on the Internet but I use DVD Region Free + CSS Free from DVD Idle, it not expensive and I have no problem viewing DVDs from any region.
Use this link to DVD Idle WEB site.
www.dvdidle.com
Jul 28, 2009 | Acer Computers & Internet
How do i change my region code in my sony vaio dvd player. it is a matshita dvd ram. my current dvd region code is set to 3 and i want to play a dvd of region 2/5. the number of changes now is zero in my...
You can only change the region code 4 times and then it locks onto that region. There are firmware upgrades for various model DVDs on the Internet that makes the DVD drive region free, but if you make a mistake in upgrading the firmware or installing the wrong firmware version then the DVD drive is turned into a piece of junk.
The best way to solve your problem is to install software that defeats the region code so you can play DVDs from any region.
I use a region free program fronm DVD Idle, it is not very expensive and there are other similar programs on the Internet. Use Google to search for them.
Have a look at www.dvdidle.com
Jul 05, 2009 | Sony Computers & Internet
Cannot change region code after 5 times
It is burned into the chips! Buy new dvd reader writer for each region. DVD makers have made this happen.
Jul 01, 2017 | Panasonic Matshita- | UJ-845-B | USB 2.0 |...
My dvd drive(Matshita DVD-RAM UJ-852) is locked on region 1. How do I unlock it? andrew
download software like region free dvd player enjoy, or for changing the dvd region code go to device manager select the dvd right click on it go to properties, go to region code change it, but becautious you can change the region code for only five times
Nov 09, 2008 | Computers & Internet
Open Questions:
Computers & Internet Logo
143 people viewed this question
Top Panasonic Computers & Internet Experts
micky dee
Computer Repairing
Computer Repairing
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
