Paper is not coming through printer and it comes out curled up
The paper does not come all of the way out of the printer. it then reads a problem and shuts down and shows a paper jam. I can take out the toner cartridge and assembly and pull the paper out. when it comes out it curls completely and forms a round piece of paper. There is also some printing on part of the back of the sheet of paper.
    Genius:
  • 1,018 Answers
Please make sure that any rollers near the exit tray are clean and gripping the paper. The same is true for any paper feed rollers under the cartridge.
Don
Posted on Jun 19, 2009
Why when printing or copying the paper come out to curved
If paper is damp from humidity etc. curling can occur. Try a fresh pack of paper and experiment which side curls less. Yes, there is a difference between the finish on the two sides of the paper.
Mar 05, 2014 | Brother MFC9340CDW Colour Laser Printer...
My copies come out curled. Is there an adjustment for that? Brad
Sound more like a paper incompatibility problem. Try another brand of paper, bearing in mind that a laser printer has heating rollers that do tend to put a bit of a curl in the paper.
Jan 25, 2011 | Brother MFC-8860DN All-In-One Laser...
Paper curls up when printing
Curling paper is almost always an indication of humidity in the paper. Toss the paper and get some fresh paper out of the ****. if the package the paper comes in was left open it may not be good either. open a new **** and try that
Aug 23, 2010 | Brother MFC-8460N All-In-One Printer
HP 3000n Laser Color Printer - Paper is curling up when it comes out of the printer. How do I stop that?
Make sure you've let the printer know what type paper you are using. In the print dialog on your PC, you must choose in the preferences area whether Plain, Photo, Glossy, Cardstock, Envelopes, etc. Such things control the pressure of the rollers in the fuser, as well as it temperature. Too hot will result in curled paper.
Also, make sure you are storing the paper properly prior to printing. It can't be too damp either, or it will curl.
Finally, if all else fails, your fuser may be overheating and need to be replaced. Hope not. If so, look for a rebuillt one online. Much cheaper than new. Good lick!
May 03, 2010 | HP LaserJet 3000n Printer
Copies coming out wavy
If you mean the paper comes out curled then try a heavier paper or reduce the paper weight settings.
Apr 21, 2010 | Xerox DocuColor 12 Printer
Paper is curling when it comes out of printer
either your using a poor quality paper or the heating element of the printer is malfunctioning.
Sep 17, 2009 | Brother HL 5250DN Laser Printer
Paper comes out in a rolled fasion
I guess what you mean is the paper curls when it comes out. It's most likely that the paper is cold and a bit moist, then once it goes through the transfuser (a very hot module inside the printer that settles the toner onto paper) and with the tensions on rollers, the heated surface expands and causing the paper to curl. And thicker paper will have more effect than normal papers. Try keep storing your paper in a dry location (but without sunlight).
May 27, 2009 | Office Equipment & Supplies
Paper curl
Paper Curl. Does the paper have a curl on the trail edge? (The last part of the paper to exit the printer)
If it is the entire paper replacement of the fuser will likely resolve this.
If the paper curl is on the trail edge then replacement of the upper delivery roller should be done.
Nov 03, 2008 | HP LaserJet 4 plus Printer
Paper curling from excessive heat.
Paper get curled from excessive dampness in paper. The heat from a copy machine is always the same.
Try fresh paper from a new packet. Do not store paper in Humid areas. Paper not being used for a long time, remove from copy machine and store in it's own packet..
Jul 10, 2008 | Canon DHD860 Copier
SHARP AR-507 DIGITAL COPIER
Ckeck the glass on the left side it is about 1inck by 12 inch for white out on it also clean the optics.On your curling problem install fresh paper you can check your fuser temp. in sim 43-1 change it to 180.
Nov 07, 2007 | Sharp AR-507 Copier
99 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
