Question about Troy Bilt Tb20cs 2 Cycle 31cc Gas String Trimmer 17" Cs
Finally got started will idle but rough not accelerating
Replaced all fuel lines & primer bulb need to know location of mixture adjust screw
  • 191 Answers
Hi James,this is a vedio ,How to Remove Fuel Lines ,hope it can help you.
Posted on Jul 03, 2014
2 Suggested Answers
  • 45 Answers
SOURCE: Carb is running on full ckoke
screw in the adjustment screw all the way in then back off 1.5 turns.crank and adjust from there.
Posted on Apr 29, 2009
I have a Briggs & Stratton Vanguard 16 HP motor. It idles fine and it runs OK at high RPMS. But it backfires thru the carburetor during accelerating. Any suggestions?
On some float-type carburetors, you can adjust the air-fuel mixture and engine speed at idle. Check for an idle speed screw designed to keep the throttle plate from closing completely, and an idle mixture screw that limits the flow of fuel at idle. If your carburetor contains these screws, proceed below.
  1. With the engine off, remove the air filter and air cartridge.
  2. Locate the idle mixture screw and turn it clockwise until the needle lightly touches the seat. Then, turn the screw counterclockwise 1-1/2 turns.
  3. If your carburetor has a main jet adjustment screw at the base of the float bowl, turn the screw clockwise until you feel it just touch the seat inside the emulsion tube. Then, turn the screw counterclockwise 1 to 1-1/2 turns. Replace the air cleaner assembly and start the engine for final carburetor adjustments.
  4. Run the engine for five minutes at half throttle to bring it to its operating temperature. Then, turn the idle mixture screw slowly clockwise until the engine begins to slow. Turn the screw in the opposite direction until the engine again begins to slow . Finally, turn the screw back to the midpoint.
  5. Using a tachometer to gauge engine speed , set the idle speed screw to bring the engine to 1750 RPM for aluminum-cylinder engine or 1200 RPM for engine with a cast-iron cylinder sleeve.
  6. With the engine running at idle , hold the throttle lever against the idle speed screw to bring the engine speed to "true idle." Then, repeat the idle mixture screw adjustments from Step 4 to fine-tune the mixture .
May 02, 2017 | Briggs & Stratton Briggs Stratton Intek V...
I have a 1995 homelite plt-3400 gas trimmer. It starts ok. It runs fine at full throttle, but will not idle. I have replaced the primer bulb because it had a crack and it has a new spark plug. I have also...
You may be able to adjust the carburetor as I describe below but if it doesn't work then I would recommend you clean the carburetor and install a carburetor kit. When you have it back together then you will need to able to adjust the two mixture adjustment screws. When you have it started you goal is to adjust the idle screw so it not only idles but when you pull on the speed control it does not falter you try to accelerate it. The other screw affects the mixture at higher speed. When you can accelerate it from idle to full speed and back again repeatedly without faltering etc. then it is fairly good. If you turn both of these screws counter clockwise a little more it should reduce the risk that you may be too lean. It still needs to run well. I hope this helps and if you have any other questions feel free to contact me.
Aug 14, 2011 | Garden
Hi, I have a Victa Tornado Plus Whipper Snipper that starts straight away and it idles but it won't rev up. When you try and rev the motor up it sounds like it is under load and the trimmer head only moves...
Hi and welcome to FixYa, I am Kelly. I know this is a 26 cc petrol engine on your trimmer but do not know if it is a 2 or 4 stroke engine. If you are in AU then it would be a 2 stroke. There are a few things that can cause this.
If you engine has a primer bulb.... Hold it depressed hard while trying to increase engine speed. What your trying to do by doing this is prevent air introduction via the primer bulb if it has a pin hole in it. If you can get normal speeds bu holding the primer bulb depressed HARD the primer bulb has a pin hole in it and must be replaced.
Also look inside the fuel tank at the fuel collection tube end. Usually there is a screen inside the tank. Some times the screen becomes coated with gunk and it has to be removed from inside the tank for cleaning.
If your carb has a fuel shut off on the side of it... unbolt the fuel manifold and pull the bolt out of the manifold. Models with this type of fuel shut off have a screen inside the manifold that has to be pushed out of the manifold and cleaned.
If after checking all of the above you still have the problem then it is time to remove the "L" fuel mixture screw on the side of the carb. BEFORE removal... rotate the screw clockwise counting turns until it JUST barely closes. Do not turn it tightly closed as the end of the mixture screw needle will break off inside the carb and you will have to replace the carb.
Then rotate the mixture screw ccw and remove it. Spray carb cleaner into the mixture screw hole to remove any debris.
IF your carb only has an "H" screw perform the same procedure above but for sure clean both the "H" and "L" mixture holes with carb cleaner. Wipe off the needles too.
Install both screws CW until closed and then reverse the number of turns CCW you counted before removal for EACH of the 2 mixture screws.
Make sure the FOAM Air Filter is NOT clogged with debris. Clean as necessary.
Start the engine and let it warm up briefly. Attempt to increase speed slowly to full speed. If the engine hesitates open the "L" mixture screw less than 1/8 th turn and try again. You should note a change in performance after rotating the "L" Mixture screw ccw. Begin rapidly throttling up the engine after EACH adjustment until the engine no longer hesitates or tries to stall upon acceleration from idle.
RUN the engine at TOP SPEED. Adjust the "H" Mixture screw until you get maximum engine rpm. You will NOT hurt the engine but it must run at MAX speed smoothly.
CHECK acceleration from idle to MAX again. re-adjust "L" mixture if necessary.
One last thing to check is make sure the gas cap is vented. Without a vented gas cap the engine will run briefly then perfromace will degrade substantially. Many times on trimmers I see people place plastic over the fuel tank fill hole and install a damaged cap. Replacing the cap has fixed many many trimmers with tank vent problems due to a bad fuel cap!
This should get you going again. If you need any more assistance or you still have the problem after performing the aboe please respond here with any updates.
Thanks for choosing FixYa,
Kelly
Jan 03, 2011 | Garden
2000 starts easy ,but won't idle. Stops when you release trigger
The throttle (often marked "T") is located away from the other 2 screws and isn't fitted with a tamper resistant device. Try increasing the idle speed a little. If the chain rotates or chatters it is to fast.
I suspect your carburetor H & L needles needs adjustment, They are fitted with a tamper resistant fitting mandated by the EPA. I recommend you take it to a local chainsaw seller/mechanic if the carb needs adjustment.
Start with a fresh (1.5 months or less) fuel mix, at a 50:1 (1 gal premium fuel to 2.6 oz quality 2 cycle engine oil) ratio, a clean air filter, the bar and chain installed and properly tensioned.
If this is explained to mechanic I'd expect to pay $10 or less for just a carb adjustment. HTH
Lou
Gee whiz stuff:
Typical fuel system schematic.
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Nov 09, 2009 | Garden
Need to know how many turns do i turn out the needle valves on the 11 hp briggs @ stratton. need to know for everyone. thanks
ADJUSTING THE IDLE SPEED AND MIXTURE
  4. Run the engine for five minutes at half throttle to bring it to its operating temperature. Then, turn the idle mixture screw slowly clockwise until the engine begins to slow. Turn the screw in the opposite direction until the engine again begins to slow (image A). Finally, turn the screw back to the midpoint.
  5. Using a tachometer to gauge engine speed (image B), set the idle speed screw to bring the engine to 1750 RPM for aluminum-cylinder engine or 1200 RPM for engine with a cast-iron cylinder sleeve.
  6. With the engine running at idle (image D), hold the throttle lever against the idle speed screw to bring the engine speed to "true idle." Then, repeat the idle mixture screw adjustments from Step 4 to fine-tune the mixture (image C).
Sep 18, 2009 | Garden
Starts and idles but dies when i pull the throttle.
Either clogged or needs cleaning/ rebuild. ITS SIMPLE! ok If you have a Walbro WT series carb "without" a built on primer bulb here it is. First off if the fuel lines disintegrated you MUST disassemble it and clean it out. The MOST infintesimle speck of gas line trapped, can allow good prime and bad operation. OK? Don't be lazy on this. Just be delicate removing the flaps gasket and diaphram. ZAMA GND-12 Is the replacement Gasket and diaphram kit fot that carb. Use a cleaner, compressed air or blow good thru it. OK Now...Primer bulb, Carb, and Fuel tank, re connects: Smaller Diameter line comes from Gas tank (Connect filter screen to this in tank) to the short Straight brass carb connector. Primer bulb suction goes to the bent carb brass connector. If small line brings fuel "in" this other line sucks it back "Thru the primer bulb" and the blow side of the primer bulb sends it back to the fuel tank! So...Small Line brings fuel "TO/IN" carb thru short brass connect on carb. Other carb connect goes to bulb suction "IN", Then primer bulb "Pressure OUT" goes thru the larger tube "back to fuel tank". Trust me I know how frustrating a simple diagram is to find online fo this set up. And if you have a carb problem on top of the hook up uncertainty you got frustration. Not only was online help hard to find (Mfg...etc NFG at all!) My local repairshop in BBrook NJ could not tell me how!!! and thats no lie! Walbro has a "generic" carb diagram but no "hook up info" specifically. Poulan don't list it either. And these things routinly fall to pcs. all 3 of mine crumpled together on yr. 3 of use.
Jul 06, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Tiller motor set up for six years and now the motor will not start.I cleaned the gas tank,carb. ect.When I try to start it gas comes out of the muffler.What can I do to start the motor.
Hello
If you Used Spray Cleaner to Clean the Carburetor, then you Need to Remove the Carburetor and Soak it in Cleaner Overnight. The Float Needle Valve is Sticking and Flooding the Engine.
>>The Following is a Basic File I Made for Cleaning Carburetors. Any Input is Appreciated. Even though the Carburetor Looks Clean, the Internal Passages May be Restricted with Varnish that Gas Causes to Build Up over Time.
>>Spray Cleaners Remove this Varnish in Layers, so Soaking is the Only Sure Way to Remove ALL this Varnish.
>>I Suggest you Make Sure the Gas is Free Flowing to the Carburetor Inlet Port (if the Model does Not have a Fuel Pump). If the Gas is Free Flowing to the Inlet Port, then
>>**Remove, Disassemble and Soak the Carburetor Overnight in Carburetor Cleaner (I Use Gunk).
>>The Primer Bulb is Held in Place with a Locking Collar at the Base of the Primer Bulb. Use a Small Flat Screw Driver and Carefully Pry the Lock Ring Up in Small Amounts All Around the Lock Ring until the Lock Ring and Primer Bulb can be Removed from the Carburetor Body. Usually a New Primer Bulb is Required when you have to Soak the Carburetor. The Rubber is Usually Rotted to Much for the Primer to be Reused.
>>Your Primer Bulb May Differ Slightly, but Removal is Usually Almost the Same Except for the Primer Bulbs that are Bolted to the Carburetor. These are Simply Unbolted and Changed with the new Primer Bulb.
>>I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning.
>>You Only have to Remove the Bowl (if Applicable), Float Pin (if Applicable), Float (if Applicable), Needle Valve and Needle Valve Seat if Applicable. This is a Flat O-Ring Located in the Inlet Port the Float Needle Rests in. Use a Strong Wire with a Slight Bend to Remove the Old Seat. Sometimes a Small Pocket Screw Driver can be Use Also.
>>The New Seat will have a Slightly Beveled Side and a Flat Side. The Flat Side goes Towards the Carburetor Body when Inserted into the Inlet Port. Spray the Seat with Spray Lubricant to make Installation Easier. The End of a Drill Bit that is Slightly Small than the Seat can be Use as an Insertion Tool.
>>Wear Gloves or Use a Rag when Handling the Sharpened End of the Drill Bit. Remove Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed.
>>If you are Able to Remove and Disassemble the Carburetor and Keep the Gaskets Intact, then Usually these Gaskets can be Reused. Even the O-Ring Around the Bowl can be Reused if it is Not Broken. The Only Parts you May Need to Replace is the Float Needle Valve (and Seat if Applicable).
>>The Float Needle Usually is Not Replaced Unless it is Not Operating Properly (the gas flow not shutting off and the carburetor is Flooding). Do Not Remove the Main Nozzle. This is a Pressed Fit and Removal is Not Required for Cleaning. Soaking and Blowing the Carburetor Out After Soaking will Clean the Nozzle.
>>Once Disassembled, then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts.
>>Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air.
>>***(Do Not Use High Pressure Air for the Zama Carburetors, they have Check Valves for the Primer and these are Usually Blown Out of the Carburetor if Not Careful. Allow the Zama Carburetor to Set on a Drip Pan and Dry)***.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers. There are Several Location for the Air Mixture Screws. The Idle Air Mixture Screws are Usually Located at the Top of the Carburetor Bowl and the Top of the Carburetor Body.****
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is Nearest the Engine. The Main Jet Air Mixture Screw is Located in the Bottom of the Carburetor Bowl or Beside the Idle Air Screw on the Side of the Carburetor Body.
>>Some of the Older Model Carburetors have the Main Jet Mixture Screw Straight in from the Top of the Carburetor Body (this is Rare anymore). If you have Cleaned the Carburetor (Disassembled and Soaked Overnight in Carburetor Cleaner (I Use Gunk). Then Blow Out the Passages with Compressed Air and Install a New Kit if Required. Now Setting the Air Mixture Screws:
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Holding the Throttle Full Open, Start the Engine. Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required. Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
>>If This Carburetor has a Single Air Adjustment (Except Tank Mounted 9200 and 100900 Engine Model Carburetors), Use the Section Above that Pertains to Full Throttle RPM Air Mixture Screw and then Adjust the Screw if Required to Eliminate Any Hesitation when Throttling from Idle to Full Throttle.
>>For the 9200 Model Tank Mounted Carburetor Adjust the Air Mixture Screw Full In, then Reverse 1 1/2 Turns. Set the Throttle Lever to Full Throttle and Start the Engine.
>>Now Carefully Use 1 Finger and Open the Throttle Plate and Over Rev the Engine Slightly. If the Engine Over Revs and Does Not Struggle to Over Rev, then the Carburetor is Set. If the Engine Struggles to Over Rev, then Turn the Adjustment Screw In 1/4 Turn and Repeat the Over Rev Test.
>>If you Adjust to 1/2 Turns In and the Engine Still Struggles to Over Rev, then Return the Adjustment Screw to 1 1/2 Turns Out from Snug and Turn the Screw Out 1/4 Turn. Do the Over Rev Test. Continue this Process Until you have the Engine Over Revving without Struggle.
>>By Adjusting the Carburetor on this Style Carburetor Until the Engine Over Revs without Struggle, you have Adjusted the Air Mixture to the Best Possible Setting.
>>This file was Intended to Give you the Basic Carburetor Cleaning Instructions and May Not Reflect Your Carburetor Components.
>>If you have Questions, Please Ask. The links above Provide Good Directions on Cleaning the Carburetor. Make sure you use an Compressed Air to Blow through all the Carburetor Passages to make sure they are Clear.
>>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
>>2- http://www.cpdonline.com/692509.pdf .
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 11, 2009 | Garden
How do you tune up a weedeater? Runs rough. When I get it running, I have to keep it full throttle to keep it running or it will die. After 15 min or so it just quits, probably because it get hot.
Hello:
Does the Spark Plug Fire when the Engine Quits after 15 Minutes?
If No, then the Ign Module/Coil is Bad and Requires Replacing.
1- Clean the Exhaust Port and Muffler of Carbon.
>>The Following is a Basic Instruction File for Doing a Diagnostic on the Engine for this Problem. Any Input is Appreciated.
>>**Remove the Muffler and Make Sure the Exhaust Port is Clear.
>>If it is, then Try to Start the engine with the Muffler Off.
>>If it Starts and Runs Properly, then Clean the Spark Arrestor Screen in the Muffler or Replace the Muffler if Required.
>>If the Exhaust Port and Muffler are Clear, then Soak and Clean the Carburetor.
Good Luck
Respectfully
jbridger (John)
May 10, 2009 | Garden
After I start my lawnmower, the rpm?s oscillates up and down for aprox 15 to 40 sec and then stabilizes.
Hello:
>>The Cause of this is a Slightly Restricted Passage or Jet in the Carburetor and it Takes a Few Seconds for the Governor the Engine at a Slightly Higher RPM to Compensate for the Restriction.
>>The Restriction is Usually Varnish that Builds up Over Time and Usually Requires Soaking the Carburetor Overnight in Cleaner to Correct this Problem.
Hope this Helps. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
John
Apr 22, 2009 | Garden
Mower will only run if choke is on
Hello cmsbss:
>>From your Description it Sounds like the Carburetor requires Soaking and Cleaning.
>>If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Happy.
>>Thanks.
Respectfully
John
Apr 21, 2009 | Troy-Bilt Pony Garden Tiller
Troy Bilt Tb20cs 2 Cycle 31cc Gas String Trimmer 17" Cs Logo
137 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
