Question about KitchenAid Dishwashers
Model w10311121b no power
No power
    Problem Solver:
  • 6 Answers
Hi Scott. It appears you have the same dishwasher as mine bought in 2010- it worked sporadically for several years. I bought one year warranty ($289) in Feb2014 . Over 2 months, service technicians replaced 3 parts (user control board, motor control board and water sensor) hoping that each would fix it. They told me to run hot water before starting a wash cycle. Dish washing cycle failures were still sporadic and it finally lost all power in May2014. Service techs would not come out so I confirmed house power supply with a multimeter and then took the door apart to access the latch. I determined the latch kill circuit was not assembled properly and it had carbon buildup which I scraped off.
If your warranty has ended and you attempt this, do not use a power screw driver with these Torx screws as you can easily strip the threads or damage the plastic user control housing by screwing in too far on the top screws. (especially if you forget to reinstall the internal handle which acts as a spacer).
To disassemble: Remove the top 4 screws and top side screws, loosen the middle and lower side screws as needed. Separate the washer door face wide enough to remove the user control board, let it hang by the cord. The handle will be loose in the way, remove it. The latch has a white plastic kill circuit which is held to the latch with tabs. Unplug the circuit and carefully remove it. The circuit comprises 2 flat metal sheets that are pushed together by the latch lever when the door is shut. These plates separate when the door is open to kill washer power. The latch lever should be under both circuit plates with the shorter plate on the bottom. (long plate, short plate, lever, white housing). Reassemble, remember to include the handle My dishwasher operates properly now.
Posted on Jul 07, 2014
Can i connect 8 b2 and 4 l1 model 2 and play at the same time as dj
For each Model II Power Stand you can connect one B2, then run the bass line out to a PackLite Power Amp to power a second B2. To do what you want, you will need 4 PackLite Amps.
Bose PackLite power amplifier Model A1 Accessories L1 reg portable...
Mar 19, 2014 | Bose Dual L1 Model II w/ 2 x B2 Sub & T1...
Need a power supply model number for Gateway model GM4019E
Gateway GM4019E Cool Power Gamer Pro 875W 20+4-pin ATX Power Supply w/SATA PCIe & Dual 12V Rails (Titanium)
The Power Supply features one 20+4-pin ATX power connector, six SATA connectors, six large Molex... More Details
SKU: 50563-425048
Jan 30, 2013 | Computers & Internet
Where can you buy a model: u120320AB4 ITE power supply cord?
where can i found a ike power supply model mu122120100a1
Jan 04, 2012 | Kitchen Appliances - Others
Hi, I need a new power supply for my Mac G4 Model M7892LL
Your machine is a "Gigabit Ethernet" model PowerMac G4.
The power supply for this model is 661-2332 or equivalent. It has a 22-pin connector.
May 13, 2010 | Apple Power Mac G4 Desktop
How to find model of power supply for G4 power PC?
The power supply model number should be on a sticker on top of the supply when you remove it.
May 12, 2010 | Apple Power Mac G4 Desktop
Power cord
call 1-800-948-1358 ask for Buck mon.-fri. 9am-5pm est sat.9am-1pm est
Apr 10, 2009 | Vacuums
HP1730 TFT monitor not powering on
There are multiple circuits for this model. I suspect your model is PE1237. If so this model frequently has bad solder connections at the AC socket. Also capacitor 2119 or capacitors 2041 & 2031 can cause no power up. They normally are bulging if bad.
If your model is PE1238 (BenQ), you may see bulging capacitors in the power supply.(1000uf/25v)
Monitor Mike
Sep 18, 2008 | HP Serial adapter (17302A)
Waring Pro DF200 power cord needed asap
The DF200 model has been discontinued by Waring, their parts department does not sell the power cord anymore. Unfortunately the DF250 model has a different power cord and does not work in the older model.
Jun 16, 2008 | Waring DF200 Deep Fryer
Dishwashers Logo
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
