Question about Michigan Industrial Tools MIT 18-Volt Cordless Drill Battery
MIT battery charger
Where can I get a new MIT quick Charger Model FOU-HT08-/18? Can't get a response anywhere!!
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 142 Answers
Did you try Michigan Industrial Tools at 888-648-8665?
Posted on Apr 22, 2014
You would think they mit would at least be willing to tell us what other battery & charger would work for this drill/driver. their tools must not be as good as they are advertised to be.
why would any manufacturer refer you to a competitors part when they have their own to sell---get real
now batteries can be replaced in a battery pack and there are plenty of battery shops that can do that for you
What's more most will have a generic charger that will do the job if not the OEM charger or can test your charger
remember this --the price of a battery drill is directly related to the quality of the batteries in the pack
a quality brand that is cheap indicates poor quality batteries or if it is a quality brand and has several spare packs again the batteries are of poor quality
so the fix is to visit a battery shop with your pack and charger and ask questions of them
Oct 28, 2017 | Drills
When I put the battery on the charger the light on the charger stays on for little awhile the it starts to blink, but when I try to use the battery it is not charged. So I am not sure if I need a new
Hi there! It sounds like you have our Linx stick vacuum or hand vacuum model. Plug only the charger into an outlet, the blue light on the charger should flash once. If the light on the charger flashes once then the charger is fine. Try resetting the battery by following these quick steps below.
1. Remove the battery from charger or cleaner
2. Unplug the charger
3. Insert the battery into the vacuum and turn the unit on for 30 seconds (even if it has no power)
4. Remove the battery
5. Plug the charger into an outlet, make sure the light on charger blinks blue once.
6. Insert battery into charger
The light should be a solid blue, indicating the battery reset worked. If so, allow the battery to charge for 3-4 hours, completely deplete battery on your next use and re-charge. If the light on the charger is still blinking, your battery will need to be replaced. I have included a link where you may go to purchase a replacement battery if needed. Hope this helps!
Search Results
Sep 21, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
Engenius handsets won't respond
Will likly cost more to repair that replace. Sorry, that is the way our society is today....throw away what dosen't work.
Jul 27, 2014 | EnGenius DuraFon 1X Handset DuraFon 1X-HC
Packard bell easynote mit gha20 M5284 - memory upgrade
Hello Wallace.
http://www.crucial.com/store/mpartspecs.aspx?mtbpoid=9B9F5310A5CA7304
Try this, i think that`s it.
mfg Gue.
P.S.: Do you know Gooooogle ?
Feb 28, 2013 | Computers & Internet
Took the battery off of the charger and it was dead, will not charge, only charged a few times
Mike, Would need a bit more detail to give the best answer, but here are some general tips to point you in the right direction. Need to know if you get any LEDs on the charger or batteries, do you have other batteries you can use to test the charger/tool to isolate the problem (even the old NiCads)? Does this problem occur with one or both new batteries? Anyway, read below for some suggestions:
Lithium Ion batteries do not like to be fully discharged even if they are new. If you ran a tool until the battery fails, two problems can occur. 1. The circuitry in the charger and the battery itself senses a fault due to "too low" voltage in the cells, and prevents charging as a protection measure (prevents overheating a shorted cell). 2. You damaged the cell(s) inside the battery either due to sulfate build up or heat. If your Ryobi charger is flashing a red LED (no green) indicating battery fault,
I have found that removing the battery and reinserting it multiple times can help as the charger does a diagnostic when you first insert the battery. This test likely applies a small charge to the cells and analyzes the response, if you do the test enough, it can bring the cells back up to a sufficient level to allow the charger to accept it.
If the battery charger cycles normally but displays a full charge very quickly, the battery may be defective and not pulling any current from the charger, so the charger thinks it's fully charged.
If the battery charger does not sense the battery at all (no LED display) then the problem could be a defective charger, defective (open) battery or corroded/dirty connections (make sure no paint or dirt got into the charger port and no rust on the contacts).
Aug 29, 2012 | Ryobi Two 18V Lithium-Ion Batteries +...
Hi i have a packard bell easynote Mit-COU-A. Its power button d0esnt work. Can any0ne give me soluti0n?
It sounds like you need to buy a new power cord for it. You could pick one up at Amazon here:
http://www.amazon.com/MIT-COU-A-MIT-DRAG-5OC-MIT-DRAG-A-MIT-DRAG-SOC-MIT-LYN01-Adapter/dp/B006VT11E8
May 17, 2012 | Computers & Internet
Where can i purchase a new battery model MIT 12 V for cordless drill ? as shown in the photo
You can go to the site of Amazon.com where you can purchase that kind of battery that your looking for.
Jul 27, 2011 | Michigan Industrial Tools MIT 18-Volt...
Michigan Industrial Tools MIT 18-Volt Cordless Drill Battery Logo
382 people viewed this question
Top Michigan Industrial Tools Drills Experts
Are you a Michigan Industrial Tools Drill Expert? Answer questions, earn points and help others
