Question about Intrusion Intel PRO/1000 XT Server (605-0505-101) Network Adapter
Intrusion turned off and not detected
How do i turn my intrusion systyem back on
  • 143 Answers
If you're refering to the chassis intrusion... (Which is what I'm assuming.)
There should be a switch in the case itself that release itself when you open the case. Make sure that it is properly placed and angled and that it is connected to the appropriate pins on the motherboard. (Often labeled "CH INTR" or something to that effect.)
There is also usually a function in the motherboard's BIOS that enables/disables the chassis intrusion alert. Check to make sure that the function is enabled in the BIOS. (Don't forget to save your settings!)
There may also be a jumper on the motherboard that enables/disables the chassis intrusion detection. (Although this is less common.) Check around for that if the other options aren't making themselves apparent to you.
Good luck with that. Hope I was on the right topic. :P
Posted on Nov 04, 2007
I have a dell and it said that i had a chassis intrusion I dont know what it means nor what to do help
That just means the case of the desktop was opened by someone.
Security Chassis Intrusion Detection note.gif NOTE: When the administrator password is enabled, you must know the administrator password before you can reset the Chassis Intrusion setting. This feature, if installed and enabled, detects that the chassis was opened and alerts the user. To change the Chassis Intrusion setting:
  1. Enter system setup.
  2. Press the down-arrow keys to move to the System Security option.
  3. Press <Enter> to access the System Security option's pop-up menu.
  4. Press the down-arrow key to move to the Chassis Intrusion setting.
  5. Press <Enter> to select an option setting.
  6. Press <Enter> again after you update the option setting.
  7. Exit and save system setup.
Option Settings
  • On - If the computer cover is opened, the setting changes to Detected, and the following alert message displays during the boot routine at the next computer start-up:
Alert! Cover was previously removed.
To reset the Detected setting, enter system setup. In the Chassis Intrusion option, press the left- or right-arrow key to select Reset, and then choose On, On-Silent, or Off.
  • On-Silent (default setting) - If the computer cover is opened, the setting changes to Detected. No alert message appears during the boot sequence at the next computer start-up.
  • Off - No intrusion monitoring occurs and no messages appear.
May 27, 2012 | Dell OptiPlex GX620n PC Desktop
What do you do if you have a window that say's, "Warning Event Notification;" "chassis intrusion detected. This typically does NOT indicate a hardware failure. 1. Contact your help desk if you did not...
Resetting the Chassis Intrusion Detector Turn on (or restart) your computer. When the blue DELL? logo appears, press immediately. If you wait too long and the operating system logo appears, continue to wait until you see the Microsoft® Windows® desktop. Then shut down your computer and try again. Select the Chassis Intrusion option and then press the left- or right-arrow key to select Reset. Change the setting to On, On-Silent, or Disabled. Hi, Above is the procedure for resetting the switch. This is directly from the on-line manual. If this does not work, just comment back. Thanks for using Fixya,.
May 13, 2010 | Dell OptiPlex GX280 PC Desktop
Noticed everest picked up on chassis intrusion detected=yes, no alarms are going off but i cant find where to turn the chassis intrusion dection off in the bios, looked everywhere. help please
NO idea where it is in the bios either but if you disconnct the switch from the motherboard, then that might tell the unit that it is diasbled and not in use. Not sure if that will work but it might do the trick.
Mar 11, 2010 | Computers & Internet
Chassis intruded
turn off intrusion detection in your bios.
Jun 06, 2009 | ASUS P4P800 Motherboard
There are several IDS packages available. Search on to find both executable versions and source code for intrusion detection systems. Some of them give information on how to set up and configure that particular IDS. You can also find honeypots for a different variation of network protection.
May 26, 2009 | Compaq Computers & Internet
Chassis Intruded!
Go into bios or cmos setup. when you turn the computer on it says what you need to press to get in there, look over the bios, look for chassis intrusion detection, turn it off, then go back to the main screen save and exit.
you won't have the problem anymore.
Thanks and good luck.
May 04, 2009 | ASUS P5V800-MX Motherboard
Lost intrusion switch cable, needing jumper configuration
Just enter the Bios and turn off the intrusion detection
Apr 07, 2009 | HP (D9820-60007) Motherboard
Took hard drive out and put back in now green lights are on but m
Are you getting anything at all on the screen or just a green light on the front of the PC?
IF the drive was removed make sure that the ribbon cable was not reattached with pin 1 on the pin 40 position, try turning the cable over 180 degrees and power back on, you will also have to reset the intrusion detection
Mar 07, 2009 | Dell OptiPlex GX280 PC Desktop
Request for Help
Hi, Muhammad, It sounds to like you have been infected with a virus and will need to run an antivirus program at bootup. If you are unable to do this yourself then it is not a big job for a computer technician to do for you. Regards mistyman
Aug 14, 2007 | IBM IntelliStation M Pro 6868 PC Desktop
Intrusion Intel PRO/1000 XT Server (605-0505-101) Network Adapter Logo
292 people viewed this question
Top Intrusion Computers & Internet Experts
David Payne
David Payne
Are you an Intrusion Computer and Internet Expert? Answer questions, earn points and help others
