Question about Kids II Baby Gear
Plug in sway and swing
The button on the swing broke off and the plug the wires broke from the base
3 Suggested Answers
motor1258
  • 6674 Answers
SOURCE: 2000 dodge caravan right front sway bar broke off
Autoparts store should have them, if not dealer will, and are fairly easy to change. Garage should not charge more than 1/2 hr. labor each.
Posted on Mar 09, 2009
SOURCE: I had cosco sway n play swing and my big boy jump
Repost in the correct place on the site
Posted on May 19, 2014
Cosco swing and play music plays but does not swing
Take it back they will replace it for you for up to 2 years.
Apr 25, 2014 | Cosco Juvenile Cosco Sway n Play Swing...
Cannot get saw to lift up on toedo chop saw
If your handle has two buttons, they are usually a power swtich and safety button so the saw isn't accidently started. No, power should not matter in the function of the swing arm. Most chop saws lock down by way of a small chain from the base to the end of the handle. Most miter saws and some chop saws lock down by way of a pin located on the pivot point of the swing arm. The pin locks the swing arm down by passing through a hole in the base pivot bearing.
Aug 17, 2012 | Saws
I bought a used Graco baby swing (I think from about 2001) and I can't fiure out the buttons. There are four - low-timer- high - music. It has 6 speeds, 15 songs, and time listed on the front. I don't...
YOU NEED THE MODEL NUMBER then follow link below
LOOK FOR THE MODEL NUMBER
  • BOUNCER On the back of the vibration unit, below the battery compartment door
  • OPENTOP™ SWING Inside the battery compartment behind the batteries
  • WIND-UP SWING On the underside of the top housing- the piece of plastic that runs across the top of the swing and is right above the baby's head
  • TRADITIONAL SWING Under swing tray
  • TRAVEL LITE™ SWING On the bottom of the contoured plastic seat
  • SWEETPEACE™ NEWBORN SOOTHING CENTER On the bottom of the seat
  • DUETSOOTHE™ SWING + ROCKER On the underside of the housing
  • DUETCONNECT™ SWING + BOUNCER On the underside of the housing
  • DUETCONNECT™ DLX SWING + BOUNCER On arm with motor hub
  • LITTLE LOUNGER™ Inside leg near Rock Lock
  • DUET ROCKER™ Backside of front plastic panel with Graco Logo
  • GLIDING SWINGS Under motor housing unit (electronics hub on right hand side of swing)
  • SIMPLE SWAY™ INFANT SWING On tubing on bottom of unit
  • COZY DUET™ SWING + ROCKER Under battery hub on back of swing
  • DREAMGLIDER™ GLIDING SWING + SLEEPER On side hub with electronics
Product Instructions Search Results
Jan 01, 2018 | Graco Toys
My timing belt broke on my 2002 kia sportage is the engine gone?
Hello
Although the 2.0 kia engine is an interference engine.(valve bender) The
odd's that you have bent valves depend greatly on how high the rpm's
where when the belt broke, if you where on the hi way the odd's sway
against you, around town they swing in your favor. That said, the kia's
survival rate for this problem is pretty good compared to many other
rubber band driven engines. Hope this helps.
Jun 23, 2010 | Cars & Trucks
Mar 09, 2009 | 2000 Dodge Caravan
Cable jack on tv broke off
This is clearly not your fault! and sounds like a defect in the manufacturing process happend to this part!! if you used your fingers THIS PART SHOULD HAVE NEVER BROKE!!
hope this helps
Feb 12, 2009 | Panasonic CT-27D12D 27" TV
Baby Gear Logo
89 people viewed this question
Top Kids II Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Kids II Baby Gear Expert? Answer questions, earn points and help others
