Question about Dryers
Kenmore oasis codes
Washer displays sd code and will not finish cycle. What is this?
  • Dryers Master
  • 5,159 Answers
The SD code means that excessive suds were detected. There are a few possible causes: 1) too much detergent, 2) not using a HE detergent, 3) something clogging the pump debris catcher (coin catcher) or drain, 4) a problem with the pump.
First try pressing Cancel and wait for any suds to subside. Then try the spin cycle again. If that works, try running the washer a few times with no clothing and no detergent. This will rinse any excess soap out.
Since the spin/drain cycle isn't completing, I suggest you prepare to pull the pump. Unplug the washer and remove the hoses (inlet and drain). Tape the door shut. You will need to tilt the washer onto the front (put some towels on the floor). Have a bucket ready to catch the water from the unit. Disconnect the drain hose from the larger pump you see by loosening the clamp. Look for any foreign objects in the pump. Similarly remove the inlet hose from the pump. To get the pump completely free, remove the end cover and remove the wire connector. Then remove the three screws that hold the pump. Check the pump again for foreign objects. Make sure that the hoses are also clear. If the pump doesn't work and there are no foreign objects, you probably need to replace the pump. If the washer is under warranty, contact Sears. Replace the pump by reversing the steps.
I hope this helps.
Posted on Apr 19, 2014
SearsTechToo
  • 261 Answers
SOURCE: Kenmore Elite Oasis error code F41
I don't see this code often although I can steer you in a good direction, F41 to F47 is error codes for dual motor problems on oasis.
Posted on Sep 13, 2008
SOURCE: Kenmore Elite Oasis HE/ Error Code F1
My washer keeps shutting off and flashing F1 error code. I haven't had it but a couple of years. I've always bought kenmore appliances and had very good luck with them. I'm very frustrated with this washer. It has never seemed to clean clothes that great even using HE detergent. Help!!!!!! It's a kenmore Oasis HE washer.
Posted on Mar 15, 2009
  • 212 Answers
SOURCE: MY DRYER IS DISPLAYING CODE F41-WHAT DOES THAT
check for tech sheet behind front panel
Posted on Jun 20, 2009
  • 3 Answers
SOURCE: f2 error code
F-02 error relates to a malfunctioning user interface board, most commonly a stuck button.
Here's a link to the technical sheet for it which includes some tests you can run to determine the problem:
https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%20W10035270.pdf
Posted on Jan 05, 2010
jyackle5
  • 8197 Answers
SOURCE: error code F44
The F44 error code on this type of dryer indicates a blower motor control board failure. Since it happens only occasionally, then you could have a loose wiring connection or a partial obstruction in the blower housing. Complete details of the troubleshooting for this error code are included in this link of a previous answer: What does the fault code F44 indicate on my Kenmore Elite Oasis dryer?
I recommend that you unplug the dryer and check the wire harness connections if you are confident that you can safely access the internal dryer components. If you find a loose connection, then tightening it or plugging the harness securely into the connection will likely correct this problem.
Posted on May 08, 2010
What does it mean when SD is showing on the display
The Sd (5d) error code is displayed on this washer when the machine control board detects a suds-lock condition by analyzing the drag on the washer basket. It will be displayed while the control runs a mini-clean out cycle. If this clean out cycle is unable to remove the excessive suds and correct the condition, then the cycle will end and Sd will flash in the display.
Make sure that you are using HE (High Efficiency) detergent in the appropriate quantity in your washer. If you detect excessive suds in the washer, this likely caused your problem.
Another cause could be a toy or other item under the washer that would cause friction on the drive mechanism. If you do not see excessive suds, check for this type of problem under the washer.
Jan 19, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
While in the middle of wash load, an error light appears. Sd, what does this mean? kenmore top load washer model 8567165
A code of "SD" indicates the washer has entered its "Suds Routine." That happens when an excessive amount of suds is detected in your washer, and the machine changes operation to remove the suds for proper rinsing of your load. The code will clear itself once the "Suds Routine" has finished.
If it keeps doing this each load, try lightening up on the detergent.
Oct 08, 2013 | Kenmore Oasis HE 27082 Top Load Washer
IT WILL DRAIN THE WATER BUT WONT SPIN AND CODE SD WILL COME ON
Washer repair in Corona Del Mar, CA
Appliance repair in Corona Del Mar and Orange County, CA
Jan 26, 2011 | Kenmore Oasis HE 27082 Top Load Washer
What is the HC code for the washer . It comes on after the wash cycle is finished.
After replacing the part to fix the F1 code, the washer (Oasis he) now comes up with a HC code. Also, even though the cycle is set for warm/cold, the clothes are coming out hot at the end of the cycle...and the cold water is hooked up and on. Any suggestions?
Sep 08, 2009 | Kenmore Oasis HE 27082 Top Load Washer
F1 error code on Kenmore Oasis He
I think there might be a recall on your washer call to see. I am not for sure that there is a recall but I a m pretty sure there is. So don't quote me on that. the f1 error code usually means that you have a bad board. f1 means that your pressure switch line is failing and this is all in your board. check your owners manual if whirlpool is not going to pay for this repair sometimes there are extended warranties in your manual
May 29, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Moister can get in between the contacts,is it in a high moister environment? Try using a hair dryer on the panel to dry it out.Also unplug it to reset.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 31, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Enmore elite oasis HE 110.2708 - It starts with an SD code and then goes to F-51.
THE CODE must be typed so we know which one you are talking about.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 11, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis TL washer, stubborn Sd code
Found the problem. After removing the back panel, found some garments in the bottom of the surrounding clear plastic tub. These must have been periodically blocking the outflow area and triggering the Sd error code. Fixed it by opening the top components of the washer so I could see down into the surrounding tub from above. Fished out the garments with clothes hangar. Put everything back together and have done six loads with zero problems.
Mar 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Dryers Logo
26 people viewed this question
Top Dryers Experts
