Question about Kenwood KMR-555U In-Dash CD/MP3 Marine Receiver
Protect code flashes
Whats the reason for that
Hi I have a transcend jetflash d33193 4Gb flash that won't format. It tells me the flash is write protected and i don't she any physical lock. i have tried every possible thing i know on it but it...
The message which you are facing while formatting your flash drive maybe be due to below reasons.
1) It could be due to virus. Try to scan your flash drive with your anti-virus and check.
2) Second reason would be when you connecting your flash drive it may include some autorun files which starts its own when you connect your flash drive and because that file is running it wont allow to be formatted, so try to delete all the files including in your flash drive and than try formatting.
or
There is right protect switch on many pen drives , a physical write protect switch which enables you to either allow writing on the disk or disallow writing on the disk.
All you need to do is toggle the right protect switch and you would be able to write files on your pen drive.
Please find an image below for more information.
Jun 08, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I cannot reformat my flash drive..always indicating" write protected" what shall i do to through reformat it?
Hi sampagac ,
Hope this helps ...:) your feedback would be appreciated.
May 13, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
When power gets put to the amp the protection, power and clip lights start flashing and the amp puts out zero power
Check the impedance of the speaker set up. Reasons for going in to protection mode is that amp can't handle the impedance... Just incase you don't know what impedance means, it is another way of saying ohms!
Sep 18, 2010 | Infinity Car Audio & Video
My car radio keeps flashing protect do i need a code
don't know what kind of radio you have, but usually if a radio is flashing protect it is because you have a short in the wiring, a bad speaker or a bad output ic.
Jun 18, 2010 | Car Audio & Video
My TV shuts off as soon as I turn it on...What is causing it to do this??
When it shuts off. Try doing what's called a self-diagnostic test. As soon as the television shuts try these steps.
Pressing on the front panel's 'INPUT' and 'MENU' buttons at the same time, and holding for 5 seconds, activates the Self Diagnostic Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem has occured since the last Initalization.
Note: The front panel buttons must be used, NOT those on the Remote Control.
-The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
-The flashing then pauses for approximately 1/2 second.
-The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
-The Error Code is repeated a total of 5 times.
-Example: If the Error Code is ?24?, the LED will flash two times, pause, and then flash four
times.
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
Self Diagnostic Code Description
1 - 2 = no error detected
2 - 1 = X-ray protect (high voltage or beam current)
2 - 2 = Short protect (short protect monitors low voltage supplies)
2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection)
2 - 4 = Vertical protect (usually loss of vertical from the source).
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
BearWeb
Apr 08, 2010 | Haier 20" TV/DVD Combo
Keeps shutting off
times.
Warm regards,
BearWeb
Hi ,i having 1GB of flash drive of Transcend company.for some unknown reason that showing "write protected ,disable it to use" message is coming.i tried several ways but not succeeded.how to disable that...
I sense that your usb memory is equipped with a physical write protect switch that you may have overlooked. Locate it, switch to the "non-writeprotected" (unlocked) mode and everything should work normally. Good luck!
Jun 03, 2009 | Kingston 4GB Secure Digital High Capacity...
I have a phillips 42' plazma and for some reason the screen won't turn on/ Red light keeps on blinking, pleas help
this is an error code that shuts the unit down and places it into a protection mode -- you need to call the customer support line at philips and they will tell you exactly what code the red light is flashing -- what is the flash ? the power board on these television is real cheap and needs to be replaced ----
Feb 02, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Will not turn on
Pressing on the front panel's ?INPUT? and ?MENU? buttons at the same time, and holding for 5 seconds,
Please do Note: The front panel buttons must be used, NOT those on the Remote Control.
? The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
? The flashing then pauses for approximately 1/2 second.
? The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
? The Error Code is repeated a total of 5 times.
times.
Self Diagnosic Code Description
Jun 09, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My tv willnot turn on
times.
Kenwood KMR-555U In-Dash CD/MP3 Marine Receiver Logo
49 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
