Question about Estate Dryers
I think wiring problems turned my Estate dryer into a brick.
So when I moved into my new apartment, I had to replace the 3-wire plug with a 4-wire one. When I went to Home Depot and bought one, the guy told me "exactly how to wire it up". Normally I wouldn't have have listened, but he sounded like he knew exactly what he was talking about.
Anyway, there was a greenish ground screw that had a wire (I think it was white) under it going back into the dryer. He used the word "piggyback" so I thought he meant to leave it there. Well, I connected therest of the pins properly, but I grounded that white wire with the green one from the new cord.
Towards the end of the first load, I opened the door to check how dry everything was. The dryer was room temperature and nothing was quite dry. So I closed the door and pushed the start button, and nothing happened. Since then (almost a month ago) it's been completely hosed. In reading through the manual which I dug up that day, I found that apparently, I should have run that white wire to the center pin of the 3, which is also white.
I've tested the start button, and the heat-sensitive fuse and both are good still. The only thing I can think that it might be is the motor, but I thought I'd ask first.
Thanks in advance.
- Collin
  • Collin Klopfenstein Jun 29, 2009
    Thanks for your reply. I went ahead and tested the thermal cutoff, and thermal fuse, both of which are fine. I also tested the push to start button and the control knob, both of which are fine.
    Where I'm baffled is this:
    My multimeter's pins aren't long enough to get down in the 240V outlet. So I plugged my dryer in and tested the ends of the cord.
    Here's what I got:
    ( R = Red, B = Black, W = White, G = Green )
    R-W: 120V
    R-G: 120V
    B-W: 0.5V
    B-G: 0.5V
    R-B: 1.5V
    Obviously, something's wrong here. As you said, it should be 120 across either R or B to either W or G, and 240 across R and B. I'm going to mave my apartment's maintenance crew come take a look at the outlet tomorrow.
    Something else I noticed: I was testing the push-button's pins for voltage just out of curiosity, and it read 1.5V with the door shut. But when I pushed the start button, the voltage dropped to 0.
    If you need any more readings, I'd be glad to take them.
    Thanks for all your help thus far.
    - Collin
  • 23 Answers
The dryer has a jumper wire that goes from the center terminal to the case of the dryer, probably a white wire like you are talking about. When you put a 4 prong cord on, the piggy back he should have been talking about would be to take that white wire and put it back to the center pin and piggyback it with the white from the cord. Then the green wire from the cord should go to the green screw grounding the case. The idea is to seperate the grounded case from the neutral wire. With a 3 prong cord the ground and the neutral wire are the same and the neutral is tied to the case. I think it should have ran and heated for you the way it was hooked up. As long as you had the red and black on the outside terminals and the white or green in the center, it should have ran and heated. You probably have a blown fuse or bad breaker. Best thing is to check with a voltmeter and you should have 220 volts across the two outside terminals and also make sure you have 120 volts from each outside terminal to the center. You can chase your tail all day though without a meter to measure the voltage.
Posted on Jun 20, 2009
  • maytagman15 Jun 29, 2009
    It looks like you have a wiring problem in the building and you are only getting 120v to the dryer. Most lilley a blown fuse.
Just moved, the dryer has a 4 prong plug and house has 3. Should it replace plug to dryer to 3 prong or house plug?
Buy a 3 wire cord and install it on the dryer. Hang onto the 4 wire one in case you move again.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 28, 2011 | Whirlpool LER4634J Electric Dryer
TEDS680EQ2 estate dryer. I need directions on how to change a 4 prong plug to a 3 prong
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Aug 25, 2010 | Estate TEDX640JQ Electric Dryer
Whirlpool Estate Dryer barely heating
Four wires on the new cord.
Red and Black go to outside screws on the terminal.
White goes to the middle terminal.
Green goes to the cabinet ground screw near the terminal plate cover.
Mar 11, 2009 | Whirlpool GEW9250 Electric Dryer
Wall plug is 3 prong, dryer is 4 prong...is there an adaptor available?
The following link explains the wiring scheme for 3 and 4 prong power cords. I know the instructions are for converting from a 3 to a 4 prong, but if you look under the "Additional Notes" section it explains how to convert back to a 3-prong if you are currently using a 4-prong.
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
I hope this helps you. If you have any questions, please let me know.
Aug 13, 2008 | Estate TEDX640JQ Electric Dryer
Dryers Logo
76 people viewed this question
Top Estate Dryers Experts
Tim Whalen
Mike
John Tripp
John Tripp
Are you an Estate Dryer Expert? Answer questions, earn points and help others
