Question about Electric Garden
Task force electric lawn mower parts - Electric Garden
  • 22 Answers
SOURCE: I have Black and decker electric lawn mower does not start
one of the problems i found with electric detectors was that they do not tell you if there is a break in the neutral cable so you could have a break there,another problem is that the levers can break inside the cover giving the impression that it should work but is not making contact with the switch ,hope this helps
Posted on Mar 30, 2009
spekgt
  • 60 Answers
SOURCE: Instuctions to replace lawn mower deck
Hello
The only thing I can get you is a parts breakdown . If that helps here's the link
http://www.dewaltservicenet.com/SearchResults.aspx?q=cmm1200 and you just have to see the service tag to check the type you have .
Hope this help
Posted on Sep 02, 2009
SOURCE: Morrison 1400W electric lawn mower goes for 20 secs.
I would think that switch may be faulty? Or is it a momentary switch only?, if so, then you have an input to the controller problem, insomuch as it starts, runs, for some reason thinks there is a problem & shuts down, whereby the switch is being pressed, so it "Sees" this and starts again, and so on?
Posted on Mar 04, 2010
rycgl
  • 1545 Answers
SOURCE: Where is the egine model number located on a Lawn
Go to www.lawnboy.com and input the model number of the MOWER and probably any of the serial #'s if you don't have yours. More options and info will pop up and you may get your engine model info from there. I hear that the Duraforce engines are all the same model?
Posted on Jul 11, 2010
ga_boyintuls
  • 120 Answers
SOURCE: black & decker electric mulching lawn mower won't start
does it have a main fuse besides a breaker ?
Posted on Sep 03, 2012
My 2 year old corded electric Task Force mower whch has had very light use suddenly stopped in middle of mowing and won't restart. Didn't trip any breakers and the cord is fine. Felt cool, not clogged
Sounds like electric motor has gone bad. If you can get past the switch and put a tester on and see if there is any power there that would tell whether your switch has gone bad. I had a new electric motor go bad after ten minutes use. I ended up replacing it.
Sep 28, 2014 | Garden
Stuck brushes,in the brush holders caused by corrosion,unplug the cord first,remove the cover and look for two carbon brushes that should be contacting the motor,if not stuck they may need replacement !
How doyou change the drive belt on a task force 2000 riding lawn mower?
there mite be diagram on deck look in owners manual or to jackssmallengines.com he may have diagram or manual
Aug 26, 2014 | Mtd Drive Belt 42"
Electric Mower zapped?
They should replace it. They broke it. If it was just a cut in the cable it should work again, but they have probably burnt it out. Change the fuse first also as that would have popped.
Jul 13, 2013 | Garden
Neighbor mowed the extension cord and mower won't start
Check the cord has been properly replaced. Check circuit with a meter (NOT connected to mains) The live pin on plug should connect to live pin on motor switch etc. (need to take off cover on switch unit)
Cutting through the cord should not have damaged the mower.
Jul 13, 2013 | Electric Lawn Mower
Electric Mower electrocuted?
wire disconnect in lawn mower.
I have a task force electric push mower and while mowing my lawn it started to smoke and shut off.. now it wont turn back on what could the problem be
it probably burn up if it smoked throw it away get a new one not worth sinking money into it to fix it
May 26, 2013 | Garden
Task force lawn mower 24 volt battery
Battery Source - if it's made they can get it but usually they use 2 - 12V batteries and wire them in series to get 24V
Mar 23, 2013 | Garden
How do you pull the starter off of an Ariens zero turn lawnmower. I need to replace the starter.
Expose the engine and take off a few covers and you will accomplish your task young Jedi... May the force be with you................
Apr 18, 2011 | Ariens Zoom 42 In 165 HP Briggs Stratton...
Garden Logo
32 people viewed this question
Top Electric Garden Experts
Steve Oakes
dannydoesita
roeb
Are you an Electric Garden Expert? Answer questions, earn points and help others
