0xc18a0506 hp photosmartC5180 comment je resout le probleme du code erreur 0xc18a0506
3 Suggested Answers
  • 1751 Answers
SOURCE: Message sur l'imprimante HP Photosmart
Hi
replace your printheads
Pls vote us to keep us alive
Posted on Nov 21, 2010
  • 100 Answers
SOURCE: plus moyen d'imprimer a partir
@claudezevart - C'est trop longtemps que je parle ou ecrire en francais, alors ma response en anglais...
My C6180 had the 0xc19a0035 Ink System Failure code, eventually the printer would power on and off every 15-20 seconds - continuously. Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This fixed the on and off problem and also fixed the ink system failures the printer was having. A similar fix may apply to other HP printers. acca299.jpg
Posted on Dec 28, 2010
OCE PLOTWAVE 300 ERROR CODE 8510
JAI UN PROBLEME AU PLOTWAVE 300 MARQUE OCE
CODE ERREUR 8510
C QUOI LE PROBLEME ET C DU A QUOI ET QUESQUE JE DOIT CHANGER
MERCI
REPONDEZ PAR EMAIL
benztirage@yahoo.fr
Jun 27, 2012 | Office Equipment & Supplies
Message d'erreur oooofeoo comment l'enlever faut il changer la batterie
Vous pouvez essayer de le réinitialiser en appuyant sur tous les boutons sauf le pouvoir et les boutons directionnels alors qu'il est allumé. Cependant, ce n'est que temporaire. Plus que probable que vous devrez faire réparer. Le code 0000FE00 signifie qu'il a du mal à communiquer avec la puce NAND. Si tel est le cas, la puce NAND pourrait être absent, il peut être rompu trace, ou votre CLK a court-circuité, donc changer la batterie peut ne pas suffire. Mais si vous voulez remplacer la batterie, suivez les 2 images ci-dessous. Je m'excuse d'avance pour toute erreur de traduction, que je suis américain et mon français n'est pas très bonne.
g6dlrvzpjeebldqs.mediumd2suhqut3ynfs5sm.medium
Mar 07, 2011 | Nintendo DSi XL Burgundy
Je viens d'acheter un pc packard bell easynote tk85 et il me demande de faire des dvds de restauration, ce que j'essaye de faire depuis maintenant 2 jours et il me met a chaque fois le code erreur 0x9411!!...
Essayez un autre marque du cd et essayez de graver le CD ? vitesse r?duite.
Escuse-moi pour mon mal francais. Vous peut utilizer "Google Translate".
J'espere qui cette solution aide-vous.
Dec 29, 2010 | Computers & Internet
J'ai desinstallé par erreur le
Salut ,
Sauf erreur , c' est du HP ça . Des pilotes sont disponibles ici :
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?cc=us&lc=en&dlc=en&softwareitem=ob-40706-1
J' espère t' avoir été utile .
Cordialement ,
Dec 19, 2010 | Computers & Internet
J'ai par erreur désinstallé mon scanner
Commence par deleter Director Player . Va ensuite sur Device manager ( gestionnaire des p?riph?riques ) et delete ( pas seulement d?sinstaller ) le pilote du scanner .
D?connecte le scanner . Va dans le Control pannel ( panneau de configuration \ programmes ) et delete le logiciel de ton scanner . Fais un restart .
Ne connecte pas encore le scanner . R?installe le logiciel pilote . Fais un restart . Attends que le systeme d' exploitation soit compl?tement stabilis? .Reconnecte le scanner et attends confirmation que le pilote est correctement install? . Cela devrait marcher ? pr?sent .
Si oui , r?installe Director Player et vois ce qui se passe .
Dec 13, 2010 | HP ScanJet 2300C Flatbed Scanner
Pourquoi code erreur 52030
Bonjour,
Mon nom est Brandonmxb. Je veux essayer de vous aider du mieux que je peux. Je ne parle pas anglais, mais puisque vous parlez français, j'ai appris la belle langue, ou bien je viens d'utiliser Google Translate. Bref, voilà votre solution.
Certains utilisateurs ont un problème de reconnexion à la fonction WiiConnect après la mise à jour il ya des systèmes.
Si vous avez trouvé soit un 32002 ou une erreur 52030 essayez de changer votre canal sur le routeur à 11 ou 1. Si votre déjà sur l'une de ces chaînes aller de l'avant et mettez-le à tout le reste, laissez le cycle de routeur, au moyen (redémarrera après le changement), puis changez-le sur le canal 11 ou un. Aussi, si vous avez un téléphone sans fil aller de l'avant et de l'éteindre juste pour s'assurer qu'il n'y ait aucune interférence. Si rien de tout cela fonctionne aller de l'avant et appeler Nintendo sur l'organisation d'une unité de remplacement ou de dépannage mai ils vous fasse.
Pour les "routeurs Linksys WRT54G" Entrez l'adresse IP du routeur (par défaut est 192.168.1.1) le mot de passe et nom d'utilisateur (par défaut admin / admin) puis cliquez sur l'onglet sans fil, maintenant sélectionner un autre canal sans fil dans le menu déroulant. Ce correctif mai ne fonctionnera pas pour vous, mais il vaut la peine d'essayer, et à nouveau ce correctif n'est pas garanti de fonctionner pour toutes les consoles.
Si cela a permis, s'il vous plaît taux de moi.
Besoin d'aide?
Aller à: http://www.nintendo.com/consumer/
Appelez: 1-800-255-3700 *
Dec 12, 2009 | Nintendo Wii Console
Je ne suis pas capable d aller dans mon mp3 il ne le reconnais pas et il a une erreur allors je ne peux pas mettre ou enlever des chanson
réinstalle le firmware du mp3 et cela devrait régler le problème
tu devrais trouver le firmware sur le site du fabricant du mp3
dans la section support.
une fois téléchargé, connect ton mp3 et ouvre le ''firmware updater''
il devrait trouver le mp3 par lui meme sinon aide le à trouver le bon lecteur soit le lecteur E: ou peu importe
une fois que cela sera fait déconnect le mp3 de l'ordinateur de facon sécuritaire a l'aide de l'option retirer un périphérique
et ton mp3 devrait maintenant te permettre d'ajouter ou de suprimer des chanssons
Bonne chance
Jun 19, 2009 | RCA JET S2002 MP3 Player
Bonjour, je vient de m'acheter une imprimante C4280 et lorsque je l'installe (avec les drivers du site HP) une erreur se produit. Sa me dit qu'il manque 2 clés de registre : slbcsp.dll et sccbase.dll
Vous devez retourner à l'emplacement de puissances en chevaux et télécharger les conducteurs aussi bien que l'autre logiciel encore. réinstallez-les… remise à zéro et voyez comment elle disparaît Robert
Aug 27, 2008 | HP Office Equipment & Supplies
23 people viewed this question
k24674
