Question about Sharp EL506WBK Calculator
The digits on the display can hardly be read
I changed the battery (LR44 battery)but things didnn't change. The contrast doesn't change pressing 2ndF and up arrow one after the other. Can you help me?
How bellsouth caller id ci 43 contrast adjustments?
If the display is too light or too dark, you should adjust the contrast of the display.
Press either review button until NO CALL or the number of calls displays. Press and hold the READ button approximately 5 seconds until the display reads CONTRAST followed by a number. Release the READ button and use the review up and review down buttons to change the contrast number. When you are finished, press READ again.
From:http://users.javanet.com/u/s/use/caller_id_ci43.htm
Apr 26, 2014 | Canon Office Equipment & Supplies
How to work with complex number
Press 8 2ndF , 6 2ndF ->r(theta) and see r on the display.
Press 2ndF <-,-> and see theta on the display.
Press 2ndF <-.-> to switch between r and theta.
Dec 06, 2012 | Sharp EL-520X Advanced Scientific...
Fx 115 es can't see the display
First, try adjusting the display contrast. Press SHIFT MODE down-arrow 6 then use the left/right-arrows to change the contrast. If that doesn't do any good, try replacing the battery.
Contrast adjustment is on page E-5 and the battery replacement instructions start on page E-71 of the manual.
Apr 05, 2012 | Casio FX-115ES Scientific Calculator
Change the decimal place settings on calculator from 2 to multiple
Press [2ndF] [TAB] and then the number of desired decimal places. Press [2ndF] [TAB] [.] to see all digits (except trailing zeros) up to ten places.
Mar 20, 2012 | Sharp Office Equipment & Supplies
It just went dead..no display, changed batteries and still nothing. I was using it when this happened.
It is possible that the calculator went dead because the main batteries were depleted. However when you change the main batteries, it is often the case that the display contrast changes, and may become too light for you to see anything. If that is the case, you can increase the contrast of the screen.
Press the [2nd] key and release it.
Press and HOLD the [UpArrow].
The contrast should increase and the screen darkens. Keep pressing the UpArrow until the display is satisfactory to you.
Jan 31, 2012 | Texas Instruments TI-84 Plus Calculator
How can i change the contrast of the display?
Hi ik12364,
The Hp 10s doesn't have contrast control. You probably need to change the button cell battery LR44. This battery only last 3 years, if your lucky under normal use. No telling how long it sat in a warehouse or, on the shelf. If replacing the battery does not work then you may have a defective screen. HP should replace it, if you had it less than a year of purchase date. If you have any more questions about this calculator just post a comment about your inquiry and, I'll be glad to respond.
Jan 13, 2011 | HP 10s Scientific Calculator
How do i change the number of decimal places on a F-502
Press 2ndF [FIX] and a digit for the number of digits to the right of the decimal point. [FIX] is on the ENG key next to the 2ndF key at the top left corner of the keyboard.
Nov 24, 2010 | Canon F-502 Calculator
I am a teacher. I have about 10 calculators that
It has two batteries CR2032. They should not be removed at the same time. There must always be one battery in the calculator. The calculator should be turned OFF when changing batteries.
Often after you change batteries the screen contrast may be too light and you cannot see anything. The contrast can be adjusted (lightened or darkened). As you adjust the contrast setting,a highlighted number in the upper right corner changes to indicate the current contrast setting; 0 is the lightest, and 9 is the darkest.
To adjust the display contrast:
1. Press and release the [2nd] key.
2. Use one of two keys: (UpArrow or DownArrow)
--- To increase the contrast (darken), press and hold [UpArrow]
---To decrease the contrast (lighten), press and hold DownArrow
Hope it helps.
Thank you for using FixYa.
Nov 23, 2009 | Texas Instruments TI-80 Calculator
Digit display
Adjust contrast [MENU] Arrow till [CONT] icon is highlighted. Arrow down to highlight CONTRAST. Press + ou - to adjust.
You can also adjust colors, if you have the color version.
It this does not work, chamge batteries (main batteries).
Hope it helps.
Oct 12, 2008 | Casio CFX 9850GA Plus Calculator
Sharp EL506WBK Calculator Logo
54 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
