Question about Haier DWL7075MBSS 24" Built-in Dishwasher ENERGY STAR
Haier dishwasher stuck on auto wash
Washer is on auto wash, and runs continuously when the door is closed. No other buttons work. I have disconnected power and it goes right back to auto wash when plugged back in.
  • Haier Master
  • 3,247 Answers
I think the flood switch has triggered which forces the pump to run continuously but does not take any other input. I am assuming it is the pump sound that you are hearing as soon as you connect power to dishwasher. The float switch is at base of dishwasher. You can press the disc visible near the filter sump. It should move up and down when you press it. If it is not moving then the spring is stuck and needs replacement. However if the disc is ok but you are still getting the problem, then you will have to check for flood switch failure. The flood switch is under the dishwasher and to access it you will have to pull the dishwasher out and lay on side. Make sure the mains power is disconnected and water inlet tap is shut.
see items 17 and 21 in this diagram.
http://www.searspartsdirect.com/partsdirect/part-model/Haier-Parts/Dishwasher-Parts/Model-DWL7075MBSS/3126/0130000/50037858/00001?blt=06&prst=&shdMod=
might be a bit slow to view.
Posted on Apr 25, 2014
5 Suggested Answers
ehmbee
  • 9 Answers
SOURCE: Haier Dishwasher hdp18pa - Power reset
Are you blowing a fuse or throwing a breaker? Either way there is a chance that no outlet you have chosen to test with yet is on a circuit with sufficient amperage-I had this with a microwave I recently had installed. If you have the manual, check for requirements regarding amperage. You then need to be sure you are using an outlet with amperage comparable to the requirements-this is on your fuse or breaker. If your requirement is, say, 20 amps, a 15-amp or less breaker or fuse is going to fail. I had to go to a 'clean' circuit from my garage with nothing on it to find out I did not have enough amps in my circuit. My solution was a dedicated breaker. Another option is to use my second option (which I did not need), to plug it into a gas generator with sufficient wattage/amperage. This ensures nothing else is on the circuit.
Failing all that, it could be the power supply for the washer, a circuit board issue, etc. Don't mess around if you don't understand electricity, though-it's not worth frying yourself.
Finally, if it worked ok before and this has just begun to happen, I'd tend to think it's an issue with the washer itself. Hope this helps.
Posted on Jul 07, 2009
  • 17 Answers
SOURCE: Haier dishwasher wont run and shows a code OP
The code "OP" means the door is open. I would suspect you have a faulty latch. The dishwasher thinks the door is open and will not start the cycle.
Posted on Aug 02, 2009
  • 17 Answers
SOURCE: Haier buttons not working!
From previous experience, I would bet that the circuit board/ control panel is failing. The one I had leaked steam near the top of the unit and the condensation will work it's way into the top control panel. Bad design on Haier's part. The worst part about mine was there is no adjustment for the door. I ended up getting a refund on the unit and buying a very nice LG model. Good luck dealing with Haier. They will send A&E factory Service out and they are not very good. I would suggest getting rid of the Haier. (personal opinion)
Posted on Feb 09, 2010
SOURCE: Dishwasher will not power on.
Did you ever get this fixed. Mine just started doing this a few days ago.
Posted on May 26, 2010
Dishwasher starts program, then few mins in pause/start button flashes "insufficient water supply". Checked all hoses and all clear. Anyone? Thank you. Glen
As soon as the waser begins the wash cycle pause, open door record water level in sump.
Close door and continue cycle until machine faults and stops.
Open door, record water level in sump.
Compare before and after. If level is low that the flapper valve that allows the water to drain is stuck open and the water is draining into the sink as the unit is washing.
To confirm, if the washer drain hose is connect to the neck of the disposal or sink drain, observe the drain after restarting the wash cycle from the beginning. If water is trickling out from the dishwasher while it is washing then it is confirmed the drain door is not closed if equipped with that configuration.
All washers have a process and hardware to drain. Some have a sepperate drain pump
Hope thisd helpd?
Jun 29, 2017 | Dishwashers
I have a haier dishwasher and it has stopped working,it's not filling water or doing anything
Check the small sensor along the rim of the door/door jam. It may be stuck. Free the machnism an start washing. Another common problem that cuase those symtoms is a bad door gasket.
Apr 09, 2011 | Haier HDP18PA Stainless Steel...
I have a Bosh Logic dishwasher SGS65L12GB/04 The other day it got to 1 min left and would not stop pumping out water and continued even with the door open. After 5 mins playing around it started working...
Hi Jonathan,
Welcome to FixYa.
Your float may have got stuck or it's possible that you have water leaking into the bottom of the washer. In the bottom of the wash compartment, next to the drain you will find a plastic dome/mushroom (the float). You might need to rotate the bottom spray arm to see it.
Turn the washer on so that the pump starts to run, open the door and push down on the float. This should stop the pump running. When you let go of the float, if it rises back up on its own, then it's almost certain that you have water in the bottom of the washer. If this is the case please post back for further assistance. If the float stays down, then it may have simply got stuck.
Please try this simple test and post back with the results.
Regards,
BElectric
Nov 11, 2010 | Bosch Dishwashers
Open the dishwaser while still filling now keeps going to error
After reading a few of the other Haier models troubles, I pulled the unit out and tip it at 45 degrees backwards for around minute. Water pored from the back of the unit, once cleaned water up reinstalled unit and all seems to be back in working order.
May 16, 2009 | Haier Dishwashers
The clean button keeps blinking, will not go off and i cant restart to wash. i hit the heat dry button for six seconds and it was unlocked but i cant get the washer to restart.
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Feb 21, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher quit during cycle.
Need a little more info.. anyway.. open dr will shut off dw...close dr.. push power button until power on... lights on, but nothing happen.. try holding down drain and one of wash cycle.. repeat holding drain w/other buttons until you hear drain pump running.. make sure you hold both buttons for a few seconds.. if your drain pump works.. then, you might have a problem w/your wash motor or something is stuck in the impeller area.
Jan 13, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Whirlpool dishwasher
Watch the light closely. If it blinks 7 times then pauses, this indicates a heater or door latch issue.
Press the following buttons in sequence: Hi Temp Wash, Heated Dry, Hi Temp Wash, Heated Dry, Hi Temp Wash.
If this doesn't work, check the tech sheet. (should be stuck to inside of the bottom toe panel)
All lights should illuminate then a diagnostic sequence will start.
Listen carefully, as soon as you hear the water begin to fill, open the door and feel the heater. if cold, check the heater for continuity (should be around 10ohms)
Also, bend the door catch on the dishwasher tub downward, this will engage the door latch better. Don't bend too far as it will hit the door while closing.
Jun 21, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool du1055xtpt4
Jun 21, 2008 | Whirlpool 24 in. DU1100XTPS Built-in...
Whirlpool DU1100XTP vlean light blinking
May 16, 2008 | Whirlpool 24 in. DU1100XTPS Built-in...
KENMORE ULTRA WASH 1626
If the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding current into the water.
-high temp wash
-heated dry
-high temp wash
-heated dry
Nov 27, 2006 | Kenmore 24 in. 16262 Built-in Dishwasher
Haier DWL7075MBSS 24" Built-in Dishwasher ENERGY STAR Logo
76 people viewed this question
Top Haier Dishwashers Experts
Tim Doolittle
Tim Doolittle
Bill Boyd
Andrew Taylor
Andrew Taylor
Are you a Haier Dishwasher Expert? Answer questions, earn points and help others
