Question about Neff V4380X0 Front Load Washer / Dryer
Bra wire has gone inside the drum,how do you remove it
    Champion:
  • 203 Answers
You can take off the rubber around the drum and then using a torch find the wire an get it out or if you have a magnet use that.
Posted on Apr 19, 2014
3 Suggested Answers
  • 410 Answers
SOURCE: BRA WIRE STUCK BETWEEN DRUM AND HOUSING
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. Therefore the washer ID doesn't mean
anything to me. It's been about 55 years since I had experience with front load washers. However I can refer you to Applianceaid.com where they have very good and complete trouble shooting and repair information on front loaders. I think you'll find what you need there. Don't worry about the timer, they hardly ever go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Posted on Nov 25, 2009
HansPP
  • 2510 Answers
SOURCE: Bra wire has gone through the holes in the drum
Cannot make out if that is a typo. There are signs of the wire or there are not? If you can see the end of the wire, grip it with a pair of pliers and carefully work it out back through the hole it is stuck in. If there are no signs of the wire, look if you machine has any removable plastic paddles in it. If it has, remove one of the paddles, usually held in by screws and clips, and rotate the drum till you see the wire, and remove it. Also look around the front of the drum behind the door in case the wire is jammed in there. If all this fails there is only one solution and that is to remove the front of the machine and the front of the outer drum to gain access to the gap between the two drums.
Posted on Mar 08, 2011
Bra wire stuck in washing machine
You could try a very thin pair of twezers, or a very thin magnetic pick up tool,you might be luck.. if not the only other way is to remove the ruber door seal to get acces to the inside of the drum.
Dec 28, 2011 | Electrolux Refrigerators
Bra wire has gone through the holes in the drum and makes a dreadful noise when it rotates, there are now signs of the wire inside the drum. How do I get the wire out
Mar 08, 2011 | Neff V4380X0 Front Load Washer / Dryer
Indesit 1600 WIE167 washing machine
locate element and remove you should then be able to remove bra wire they normally get caught around element
Jul 01, 2009 | Washing Machines
Bra wire trapped in drain of washing machine noisy when drum rotates.How can I get it out?
Fishing line was looped through the larger holes in the back of the drum with a lassoo on the end of it & hooked round the wire then drawn out. A very time-consuming procedure in a confined space with a fine bendy light to illuminate the part.
Jun 01, 2009 | Zanussi FJS1225W Front Load Washer
Bra wiore inside drum
HAVE YOU A GOOD BRIGHT TORCH? IF SO I REMOVED MINE WITH A TORCH IN MY TEETH & A SMALL FLAT ENDED SCREWDRIVER, IF YOU CAN SEE IT TURN OFF ALL POWER TO THE MACHINE FIRSTLY THEN USING THE SMALL SCREWDRIVER COAX THE BRA WIRE TOWARDS THE NEAREST HOLE IN YOUR DRUM & THEN FEED IT THROUGH AS BEST AS POSSIBLE & THEN GRAB IT WITH EITHER FINGERS OR PLIERS IF IT IS A STRUGGLE TO PULL IT OUT.
DONT LEAVE IT IN THERE & THEN OPERATE IT AS IT WILL JAM IT & BLOW YOUR EXPENSIVE MOTOR WHICH ARE APPROX £80 OR HIGHER & YOUR PUMP IF IT JAMS IN THE BLADES BEFORE REACHING YOUR FILTER ..
May 22, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
How do you remove underwire lodged between drum and outer case
hi to remove bra wire from between drums ? you might try this 1st ? if you diconnect water supply hoses and unplug power supply then remove rear panel from machine you will have access to the large rubber drain hose from outer drum down to discharge pump ? ok hose is held by spring wire clips both ends remove clips then hose you may find bra wire either in hose or close to drum drain if you need ? feel inside drom via drain hole ? or probe with a piece of coat hang wire ? you may even find the mysterious missing sock/ thong / etc when you disconnect the hose too?? any debri has to lay in bottom of outer drum and so a little patience will locate them using this method instead of removing the main front door sealto drum for access to same area also with rear panel off you can check belt tension ? hope this helps/inspires you ? best wishes from uk
Feb 26, 2009 | Hotpoint First Edition FEW12 Front Load...
Bra underwire stuck
disconnect from electricity. take back panel off.you will see heater at bottom of tub held in by 1 10mm nut.disconnect wires to it. loosen this nut and pull heater out - you may have to help it with a screwdriver. you can then see into the gap between tub and drum and fish for the bra wire.
tell her not to wear bras with wires!!
Jul 14, 2008 | Electrolux EW1000i Front Load Washer
Bra wire gone inside drum!!!!!!
DLB POST!! SEE ANSWER below From old post Solution #1 posted on Jan 26, 2008 0%20stars.png
1ad4dee.jpg Master_Tech
Rank:guru_s.gif Guru
Rating: 85%, 47 votes
you will have to open the bottom of the unit there is a pump clean out and a hose to the tub you maybe able to get it from there REMOVING the tub is not an option at this point
Jan 26, 2008 | Washing Machines
PS: have some towels handy to catch the water
Jan 26, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bra wire stuck in AEG washing machine
Hello, to fix this, what you should do firstly, is remove the machine from it's normal position, and then get a handyman to take off the back cover (which is not recommended by the manufacturer) and get right into the guts of the machine. Once you have found and identified the drum, internally, then open the waterproof cover, and note where are the parts and screws go. Keep digging the inside up until you ahave reached the bra wire. Alternatively, if the wire is still visivly poking out of the small holes in the drum, pull the wire out with pliers. Good luck! PS- If this information was helpful, please rate me either solved, thanks for trying, etc. Thankyou! Daniel Ballantyne
Oct 10, 2007 | AEG Lavamat 72640 Front Load Washer
Neff V4380X0 Front Load Washer / Dryer Logo
Top Neff Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Neff Washing Machine Expert? Answer questions, earn points and help others
