Question about Vacuums
Dyson dc23 troubleshooting
The power does not stay on when I push on the power supply. I have to hold the power button down.
  • Vacuums Master
  • 1,493 Answers
The switch needs to be replaced.
Posted on Apr 21, 2014
chrispurs1
  • 372 Answers
SOURCE: Dyson Power Button Problems
Hi.
Sounds like the switch is faulty & will need replacing.
http://dysonmanuals.llc.nu/
Chris.,
Posted on Jan 08, 2008
SOURCE: dyson animal, have to hold ON switch for it to work
Pull the wand out of the Vac. Need to use a small Torx bit to take out 2 screws hidden behind the wand storage. Once screws are out, there are 4 push-clips which need to be un-latched. Pry the power panel off and you will expose the two switches (one for power, one for the brushes). Push the power switch down and it should "release" and go back to clicking when pushed. Re-assemble. Took about 5 minutes to fix.
Posted on Nov 15, 2008
defrankond
  • 65 Answers
SOURCE: Dyson DC01 - can't get starter button switch off.
this issue is known well with dysons to be honest you will continue to have this problem for as long as you have the vacuum. they use substandard plastic parts which break easy. You will have to replace the button and make sure there are no other broken pieces of plastic in the housing before putting it back together.
Posted on Nov 30, 2008
SOURCE: on button won't stay on
I had this same issue under the same circumstance. I followed the repair guide for replacing the switch (I didn't replace the switch, just disassembled the switching mechanism) posted here:
http://www.sparesaver.com/help-and-support/dyson-section/dyson-technical-advice-450/dyson-dc14-technical-advice-474/replacing-the-switch.html
I found the switch to be stuck in between on and off. I just manually pushed the switch and it became unstuck and started working again.
Posted on May 17, 2009
VacuumRepair
  • 438 Answers
SOURCE: Power Button won't stay down/on.
Hi There,
Most likely your switch has gone bad, and you'll need to replace the on/off switch on your Dyson DC07. If you have to hold down the switch in order to keep the vacuum on, this is indicative of needing a new switch. Unfortunately this is very common problem on the Dyson vacuums2_bing.gif . The switch that Dyson uses for their vacuums is one of the cheapest switches on any vacuum on the market today. The good news though is that this is not a extremely difficult repair to fix.
I took pictures of replacing the switch assembly on one of our customers repairs they brought in. It was having the same exact problem that yours is, it just wouldn't stay on. Here's how you can fix the switch on your Dyson:
- T15 Torx Bit Screw Driver
- Genuine Dyson DC07 & DC14 Replacement On/Off Switch Part 901181
- Needle Nose Pliers
- Patience (haha)
The switch above is actually a link back to our site if you have yet to purchase the switch yet. We carry most every Dyson part.
IMPORTANT: MAKE SURE YOUR VACUUM IS UNPLUGGED BEFORE DOING ANYTHING ELSE!
Step 1. First thing you'll want to do is to unwrap the cord from the machine, and remove the handle from the upright part, then slide the hose all the way down the wand, and remove the hose from the handle assembly completely and set it aside. Also remove the dust bin assembly completely from the machine as well.
Step 2. Once you've remove the handle from the machine I find it easier to work on if you lay the vacuum on it's back, with the switch button facing upwards. Now remove the T15 Torx bit screw that is directly below the switch actuator. I have circled the location of this screw in the picture below:
Step 3: After you have taken off the screw, you're doing to need to remove the switch box housing from the vacuum that the screw was securing. Simply use your flat head screw driver, and pry the two small arms upwards. Be careful when prying, the plastic components on Dyson Vacuums are really cheap quality plastic, and I can't tell you how many times I have seen these plastic parts break when customers bring in repairs to us here at govacuum headquarters. Here's a picture of the location of where you should pry the switching off:
Here's what the vacuum should look like after the switch housing has been removed:
Step 4. Use your needle nose pliers to remove the terminals from both of the switch poles.
Step 5. Take out the new switch assembly. I find it the easiest to use my needle nose pliers to reattach the wires to the new switch, but it also can be done with just your hands. Both both wires to your switch. If the cords have come loose while you have been working on the vacuum, you'll need to put the wires back into their proper places as well. This is how the switch and the wires should look like when you're done:
Step 6. Once the switch and cords are back to their normal places, simply put the switch housing cover back on, and screw in the one screw.
I hope that this repair was helpful to you, if you have any questions or have any problems, please feel free to use the clarification request form here on Fixya.
If you ever need any for your Dyson, we do carry most parts and accessories on our site under our Dyson Parts Section .
If this was helpful, please be so kind and leave feedback for the repair. This is really, really appreciated and is the reason repair professionals like myself continue to post free repair help on Fixya rather then just answering the paid questions.
Thanks again,
Chris J.
GoVacuum
Posted on Apr 17, 2010
There is a sock stuck in the hose of my dyson dc23 animal motorhead how do I get it out
Hi, this is Jim with Crucial Vacuum,
Detach the hose and stretch it out completely, if the sock is in a hard to reach place use a broom handle to push it out. Be careful to mind the edges of the hose you don't want to cause a tear, which would lead to poor suction.
You can purchase replacement parts for your Dyson DC23 direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/dyson-dc23-pre-filter-part-913394-01.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
May 08, 2015 | Dyson DC28 Animal Upright Vacuum New DC 28...
Machine shut off when suction release button was accidentally pushed. Now it won't come back on! What should I do?
Hi there, it's Jack at Dyson.
The issue you've described sounds very unusual. DC23 has a suction relief trigger underneath the hand grip of the wand handle, but this isn't connected to the vacuum's electrical components and shouldn't cause the vacuum to cut out in use.
However like most Dyson vacuums, DC23 is engineered to shut off for protection if it starts to overheat. This may occur if the machine is used when blocked, or if the filter is overdue for a wash. It should reset automatically after it's had around 2 hours to cool down, but to prevent it from happening again please follow the steps shown in our online support guide: http://www.dyson.co.uk/support/dc23/dc23-animal/my-machine-is-not-working/check-telescopic-wand-step-1-turbine-head
In normal use, we recommend washing the lifetime pre-filter at least once every 3 months using cold water without detergent. Allow at least 24 hours for the filter to dry completely before replacing it.
I'm confident following these steps will resolve the issue, but if you'd like further help or advice after giving this a try, please call our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Dec 08, 2014 | Dyson DC23 Animal Vacuum
With my Dyson D23, my carpet power head attachment runs intermittently until it stops working all together.
Hi Megan, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your DC23. From your question, I'm not sure if you own DC23 Motorhead, which has a motor-driven brush bar, or DC23 Animal, which has a turbine-driven brush bar.
You can find online troubleshooting guides for both of these machines on our Support site. I'd encourage you to select your machine from the list, then follow the diagnostic checks shown:
http://www.dyson.co.uk/support/cylinders.aspx
If you'd like further advice from our experts after you've given this a try, please call us directly on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Aug 16, 2013 | Dyson DC23 Bagless Canister Cyclonic...
Dyson dc23 canister rug attachment loses power after about 5 seconds, push red button and restarts for less time. After 3 or 4 trys of it working for seconds it just doesn't turn on again. Reall
Hi Elizabeth, it's Jack at Dyson.
I'm glad to hear you've been in touch already and we're able to resolve the issue under your machine's 5-year guarantee.
In most cases, the issue you've described will be caused by something jamming the brush bar. It can usually be resolved by clearing the brush bar of any debris, threads or hair, and checking the Motorhead for any obstructions, as shown in the video below.
If you'd like further help and advice with your machine at any point, please get in touch with us.
Best wishes,
Jack
http://www.dyson.com
Feb 07, 2013 | Dyson DC11 All Floors Bagless Canister...
I have a dyson DC17 absolute The power switch is no longer working -- If I hold the button down, it will stay on, but it will not stay on without being held down. The power also turns on (if I...
I'm sorry to hear you're having difficulties with your DC17's on/off switch. If you haven't already got in contact with us directly, I'd strongly encourage you to do so. One of our experts will be happy to run through some troubleshooting over the phone with you to identify the cause of the issue you're experiencing, and will be able to recommend the best course of action. You can call us free on 1866MYDYSON - or if you email your details to askdysonUS@dyson.com, someone will be in contact as soon as possible. We'll look forward to hearing from you.
Kind regards,
Jack
Aug 30, 2011 | Dyson Vacuums
The turbine head has slowed right down and has no power!
Sorry to hear you're having difficulties with your DC23. If the turbinehead doesn't seem to be working as well as usual, it's possible that there's a blockage in the system, and you may need to give the filter a wash. The easiest way to locate and remove any blockages is to follow the steps shown in our online support guide:
http://www.dyson.co.uk/support/help.asp?article=1554&product=DC23-ANIMAL
The correct way to wash the filter is shown in the video below. Under normal use, this should be done at least once every 3-6 months. Use cold water without any detergents, and ensure the filter is totally dry before replacing it - this may take up to 24 hours.
http://www.dyson.co.uk/support/help.asp?article=1935&product=DC23-ANIMAL
Hopefully, by clearing any obstructions and washing the filter, you should be able to resolve your issue without further assistance. However, if you've tried this and are still concerned, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Aug 28, 2011 | Dyson Stowaway DC23 Bagless Canister...
Dyson Animal DC17 motor won't stay on
You will need to have the button replaced. Dyson power buttons are notorious for breaking because just a gentle push is all that is required and they can break if they have been pushed down roughly.
Apr 01, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Vacuums Logo
100 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
