Question about Cal Pump 5500 GPH Waterfall Pump
Won't pump water
Pump just has a low pitched humming sound and won't pump any water
    Champion:
  • 216 Answers
UNPLUG PUMP AND SEE IF THE IMPELLER IS JAMED, IF IT SPINS FREE TRY IT WITH A SHORT DISCHARGE HOSE. POSSIBLE BLOCKAGE IN DISCHARGE HOSE WILL TRAP AIR AND WONT LET PUMP PRIME.
Posted on Apr 20, 2014
My samsung dishwasher will not drain? What could be causing this problem. We checked the line and it is not plugged.
when you first start the dishwasher the first thing it will always do is drain, does it make the normal draining sounds or is it a low pitch humming noise? if its a low pitch humming something is stuck in the drain pump like a peice of chicken bone or glass, if it sounds normal then there is a blockage somewhere and 9/10 times its the little drain spiggot that the drain hose plugs onto under your sink, they often block up as the pipe diameter gets smaller there
Oct 08, 2014 | Samsung DMT400RHS Builtin Dishwasher
Machine won't turn on
That sounds like the pump is jammed and did not pump all the water out.
May 10, 2013 | Fisher and Paykel WA37T26G Top Load Washer
Humming sound coming from engine told it was the alternator
This noise could be the alternator, water pump, power steering pump, idler pulley or tensioner pulley. Sometimes an automotive stethescope is used to isolate noises around the engine.
Dec 20, 2012 | 2002 Chevrolet TrailBlazer
Waterfall pump hums but won't pump
this sure sounds if the impeller is blocked and not being able to turn ,Dont let it run this way , can dammage motor of pump , remove intake cover (unplugged) and wash out with garden hose real well , see if impeller (black plastic blade) can turn with your finger (unplugged) , should move easy ! this might be an indacation of need for a filter on pump inlet !!!
Oct 14, 2012 | Little Giant Submersible Fountain Pump
Asko 620 washer won't drain well with heavy load
Washing machine won't drain
When your washing machine won't drain, it could be as simple as a kinked hose or as complicated as a faulty impeller on the pump. Overloading your washing machine can cause items to be swept into the space between the inner and outer tub, leading to clogs in the drain hose or pump. These clogs may be the reason for why your washing machine won't drain. Here are some steps to help you determine the problem and solution:
1. Pinched hose: Is the drain hose at the back of the washer been flattened or twisted in any area? A pinched hose could prevent the water from draining thoroughly. Gently straighten the hose, and make sure there is sufficient room between the back of the washing machine and the wall to prevent a repeat of the problem.
2. Clogged drain hose or pump:
Does the drum spin normally, but the washing machine won't drain the water? Sometimes a piece of clothing, money, fabric or other debris gets into the water between the inner and outer tub. It may then make its way into a drain hose or even into the pump itself. The farther into the machinery a clog goes, the trickier it can be to remove. Call a repair professional for help.
3. Faulty timer: Does your machine fill with water and begin agitating, but the cycle never advances far enough to allow the water to drain? The timer that controls the cycles may be broken. Arrange for washing machine repair service.
4. Worn or loose belts: Are clothes still soaked at the end of a wash, even though the washing machine appears to go through the spin and drain cycles? The timer that controls the cycles may be broken. This is a job for the pros.
5. Faulty or jammed internal impeller on pump: When the spin cycle starts, do you hear a humming noise? The internal impeller that moves the water through the drain pump may be faulty or jammed. A grinding or grating sound is almost always an indication of a coin, button or other object colliding with the impeller. Have a washing machine repair expert determine if the impeller is jammed and can be cleared, or if the pump needs to be replaced.
6. Pump failure: Is your washing machine more than 7 years old? Your pump may simply have worn out. Even if it sounds as though it is running, the pump may not be working well enough to draw the water out of the machine. Replacement parts for pumps are generally unavailable. A new pump may be necessary.
For more troubleshooting steps, see Washing machine won't drain. I hope this helps!
Oct 08, 2012 | Asko W6021 Front Load Washer
Pump hums but won't run
awwhhh it sounds as if you stored your pump dry all winter long ill bet, well ya just cant do that after it pumps salt water all summer , salt has crusted up inside pump and valves , try a hot water dose (not on motor) that might get it going again (repeat several times)
otherwise your gonna need to take it all apart clean in hot water and grease all up with foodgrade waterproof grease (see kitchen faucet parts section of hardware store)
on a salt water pool you have to store your filter and pump filled/capped with RV antifreeze (foodgrade) any good rv store sells it
salt wont crust up inside then
Mar 23, 2012 | Intex Salt Water Saltwater System Chlorine...
High pitched noise coming from front of engine only at high speeds. When at low speed, it mainly sound like a higher pitched tire noise. Any suggestions would be helpful
check the altenator berrings, also check condition of air pump it may be going out,don;t forget the water pump berrings
Sep 25, 2011 | 1993 Chrysler Lebaron
Have a pentair 1 HP whisperflow pool pump. It makes a loud high pitch sound when turned on. Sometimes when first turned on it won't but quickly will begin making the loud high pitch sound. Almost...
Are you sure that you have it wired the right way. it has a setting for 220 or 110 the pump will run if it is not wired correctly however it will be varey ******* the brushes inside the motor resulting in a loss of efficiency
May 22, 2011 | Pentair Whisperflo 1 12 Hp Pool Pump Wf26...
2000 blazer (almost 200K miles) loses power after 15-20 minutes at highway speeds but regains power after stopping for a few minutes. Also has low pitch humming sound coming from rear of vehicle? Sound...
catalytic converter will be red hot when problem is most evident.May also be bad connection at intake boots or the intake itself spray soapy water solution at all vacuum points engine will bog down/stall if leak is present.
Feb 04, 2011 | 1999 Chevrolet Blazer
I have a fisher and Paykle GW612 washing machine, it won;t drain the water and won;t do the spin cycle. It now is making a huming noise. I think it is the motor that has an issue?
There should be a tech sheet located underneath the control panel that has the procedure for putting the machine in "diagnostic mode" and you can easily run the water pump by itself. Listen for a "hum" sound- If you hear a hum instead of a running water pump, then something is keeping that pump from turning for sure.
If this is the case, then you would need to check your water pump. It is located underneath the machine in the right front corner (as viewed from the front of the machine)
There is a black plastic external cooling fan impeller that you can spin with your finger (of course unplug the machine first) and see if the pump spins freely. You should also examine the pump for signs of leakage or corrosion. You may simply have an object that was left in someone's pocket that has become lodged in the pump. Pump removal requires no tools, however you need to first bail out as much of the remaining water in the wash tub as possible.
Jan 15, 2011 | Washing Machines
Cal Pump 5500 GPH Waterfall Pump Logo
148 people viewed this question
Top Cal Pump Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Cal Pump Plumbing Expert? Answer questions, earn points and help others
