Question about Dometic Rooftop RV Air Conditioner
AIR AND FUNACE RUN AT SAME TIME
AIR AND FAN MODES WORK FINE BUT ON FURNACE MODE AIR AND FURNACE BOTH RUN.
    Problem Solver:
  • 14 Answers
Change thermostat.
Posted on Apr 24, 2014
5 Suggested Answers
burzerko
  • 254 Answers
SOURCE: Coleman RV roof air
I think you have a high pressure switch that has tripped. open up the case and look for a switch connected to the line with a resettable button in the case it is not resettable you will have to have a professional replace it. If you are able to reset it make sure to clean the condensing coil on the top side before running it again as most likley this is what may have caused it to trip.
Posted on Jun 22, 2008
  • 46 Answers
SOURCE: AC Fan not working on Auto
ac can take up 2 ten minutes to reconize commands be patiant and stop pushing buttons wait desired ten minutes if does not solve problem faulty conrol box and if comfort cortol thermo try reset in owners manual
Posted on Aug 01, 2009
  • 10 Answers
SOURCE: The ac unit no longer turns on, just makes a
Check for a tripped breaker inside breaker box. A/C outdoor units are on seperate breakers than furnace.
Posted on Mar 28, 2010
motor1258
  • 6674 Answers
SOURCE: shut off automatically, and I run it in fan only mode
Remove filter cover and see if front coils /fins are frosting up. Let me know
Posted on May 27, 2010
Amana Air Command 80 with fan mode is on, the furnace is running and blowing heat. Why the furnace did not do any thing when I set it on auto mode? Then I replaced a new thermostat, but nothing change
Try setting the temperature higher. It could be that the room temperature is not getting cold enough for the automatic controls to activate the heater.
Nov 02, 2014 | Heating & Cooling
Why heater fan will not come on?
Wish I knew how old your furnace is. Let me answer your question directly. In the heat mode the fan runs independently from the air conditioning fan relay. Its either brought on by time or temperature. An old furnace will use a fan and limit control that uses a coil to sense the heat exchanger temperature and turn the fan on or off. Newer furnaces use a timer on a circuit board. 20 years or newer Ill bet its a timer board. Follow the blower motor wires back to the component and ill bet that's the culprit. Hope it helps. Good luck.
Oct 12, 2014 | Heating & Cooling
FURNACE AND AIR RUN AT SAME TIME
sensor failure, communication between t-stat and module bad modu\le board.
Apr 19, 2014 | Dometic Heating & Cooling
Furnace will not run when hooked up to electricity
Go to your thermostat and access the fan mode. Change the fan mode to Automatic, AU. This will stop the AC fan from blowing when the furnace is turned on. If the fan mode is on Hi or Lo and the furnace is turned on it will turn on the AC blower. Bad design...
Mar 02, 2014 | RVs
Air conditioner won't stay off
Go to the thermostat and access the fan mode. Change the mode to AU (automatic) then turn the furnace on and it should work normally. If the fan mode is in Hi or Lo the Ac fan will blow.
Dec 21, 2013 | Prime Time Manufacturing 2013 Sanibel 3600
Pleasureway Traverse furnace fan runs when funace is off.
Bad/ stuck fan relay or temerature sensor is not shutting the fan off. Or there is a short on the low voltage fan control circuit. Check to see if the Green terminal is jumpered to the Red terminal at either the furnace control board of the 'stat, if not, ohm the wires with both ends off- I've seen installers accidently shoot a staple thru the wire and short the wires together more often than even I can believe! Hope this Helps! PS Some furnaces have fan switches inside the furnace- check for one and see if it's "on"- sounds too simple, but sometimes the "simplest" is the correct answer.
Mar 22, 2013 | Heating & Cooling
My Maytag 90% plus funace you can only feel a slight air movement coming out of the ducts. My 80% one at home I could dry my hair from the vent. What is wrong with my 90% unit? should the air movement be...
First check to make sure that you furnace filter is not plugged. Now with that being said your furnace may be working exactly as intended if the motor is staged. The way a high efficiency unit works is slowing down the fan speed to maximize heat transfer from the coil.
My guess is that your furnace is working correctly (if filter is not plugged).
Jun 16, 2011 | Heating & Cooling
Coleman mobile home electric furnace
Peace,
It seems you need hands on servicethis time !
ngafm
Bless You,
Please leave me a rating before you sign off!
Thank You
Sep 07, 2008 | Heating & Cooling
Dometic Rooftop RV Air Conditioner Logo
65 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
