Question about Canon PowerShot A1400 16 Megapixel Digital Camera - Black
Micro SDHC size
Bought a memory card 64g of China is recognized as 64g but when copying files can not be read after. how to flash the correct size?
    Guru:
  • 135 Answers
Try formatting the card first maybe the alocation table is defected
Posted on Apr 24, 2014
  • 36 Answers
SOURCE: Memory Card Error
Use USB card reader&writer to retrieve the pictures directly from the card.
Posted on Dec 28, 2007
  • 3 Answers
SOURCE: memory card error after inserting SDHC card on powershot A620
the a 620 only goes up to 2 gb no higher
Posted on Jan 28, 2009
  • 262 Answers
SOURCE: my canon sd600 is not reading PNY sdhc memory
HC or High Capacity is not compatible with this camera. You have to buy a memory card which says only "SD" and NOT "SDHC". Cards of 2Gb and less are usually "SD". Cards of 8Gb and more are always "SDHC" for technical reasons. Cards of 4Gb can be either, but the SDHC kind are much more common, because they're cheaper and newer.
Posted on Jul 27, 2009
F1xer
  • 415 Answers
SOURCE: is canon digital IXUS 55 compatible with 4gb SDHC
The maximum amount the Canon sd450 can support is a 2gb card, anything more and you 'll just get error problems.
Posted on Aug 16, 2010
  • 11967 Answers
SOURCE: I get a memory card error message after installing
Your camera can only use SD cards up to 2GB....not SDHC cards.
Posted on Oct 11, 2010
How do i copy the memory card i use in my mp3 player to the one i use in my cell phone the cards are the same as each other
What memory card type? My guess would be SD as it is the most popular format in that size. It would be best if you bought a card reader and then used a computer to transfer the files.
Tek Republic TUC 300 USB 3 0 Supports SD SDHC SDXC Micro SD Flash MS MS...
Oct 22, 2014 | Cell Phones
No correct size
Make of card?
You may need to partition the card into 2 32 GB partitions.
Many devices cannot deal with more than 32 GB.
Format card as FAT 32.
Apr 19, 2014 | Electronics - Others
I bought a 4 gig SanDisk Adapter micro SD, micro SDHC. my Acer Aspire will not recognize the card, i've tried the switch both ways multiple times. how can i get my PC to recognize the card?
My reader will not read mine either. I use a usb key card reader. It used to read the regular old SD cards but the new HC card format wont work. This is due to UDF differences. You can try to reformat the card but then your camera or device may not recognize it anymore. good luck
Jun 16, 2011 | SanDisk 1GB microSD Memory Card
Drivers for detecting 4gb kingston SDHC
SD vs SDHC is a question I get alot. First let me explain your issue. Unless your CARD READER is rated for SDHC chances are its an older model and cant handle the card, even with driver updates. You will need to check the manufacturers website of the device you are using as a reader to see if there are newer drivers. If its a laptop go to the manufacturers page and and be sure and choose Windows XP as your OS. Ok, now to the difference. SD cards are called solid state memory. The internal workings of each hasnt changed much except that the SD card used standard file formatting that was understandable in Windows XP and earlier operating systems. the SDHC (HC stands for High Capacity) uses the same architecture in teh card but changes the way data is stored and read that enables it to hold more data on same size device. (note architecture means design of card type not inside guts) Thus your system and Operating system may not be capable of addressing the new coding and file system changes on teh SDHC cards. Many older cameras (2008 and before) dont recognize SDHC cards either. Good news is they make an SD card (plain) in a 4 gig and you may be able to replace yours at the retailer with teh correct one needed (unless you bought via ebay or other method) Yours is a good question and is often asked, so dont feel bad in anyway. Just look at it this way.. you learned the lesson recently when the pricing between the two is about the same.. I learned the lesson 2 years ago when an SDHC cost about 80$ compared to 19 $ for a normal SD... SMILE!
Jun 28, 2010 | Kingston 4GB Secure Digital High Capacity...
I can not get my Sciphone i9+++ to recognize my 2g micro disc ... i can put in my card reader and copy files to the card but my phone does not recognize it's in there
Hi.
Basically there are two types of SD Cards variant available in the market, they are normal SD card and SDHC card(High Capacity) card..
Mornal SD card can be detected by all the card reader, but if you have a SDHC card, it can de detected by normal card reader , you should need a special SDHC certified card reader, so you wont able to read the SDHC card from your card reader
If you have the following logo present over the card, then it states that, you have a SDHC card..
PLease leave me comments, if you need further assistance
Rnj VINODKUMAR
Nov 02, 2009 | Cell Phones
Formatting troubles for a 8gb Sandisk Micro SDHC
Hi Tony,
Have your My Computer window open and re-insert the card into the reader. If it doesn't show immediately, then right click and choose refresh. It should show up then.
Rob
Feb 27, 2009 | SanDisk 8GB microSDHC Memory Card with...
Pc not recognizing sandisk micro sd
The Card Reader you are using is probably not compatible with SDHC Memory Cards (High Capacity SD). You may need to get an SCHC compatible reader or check the website for your product to see if the is a driver update. You can get a new reader for about $20 bones if needed. I had the same issue.
Dec 30, 2008 | SanDisk 4GB microSD High Capacity Memory...
Sony 400gb Microvault
I have To This Deviced But I Think Its Fake I Face Also This Problem But I Am Happy To Solw U Just Plug Ur Pen Drive To Ur Pc And Run Windows Xp Proffesional Bootable Disk
Start Win Xp Setup And When U Go To Chose Hard Disk There Is Ur Removel Drive Display Delet Ur Pen Drive Partition And Creat New One And Give It To 31000 Mb Size And Make Partition FAT32 now Don press F3 And Exit Setup And Login To Ur Xp And Go TO Disk Manager Format Pen Drive New Partition U Have 31 GB Of Size That Work Correctly And Ur Unpartition Space That Show Pen Drive Is 100% Fake Just Only One Way To Use Ur Pen Drive Is This One Say Thanx If My Suggetion U Like...... Sorry For My Pour English........
Apr 09, 2008 | Computers & Internet
Sansa mp3 player could not detect micro sd add on card
Anything over 4GB is a Micro SDHC card, not a Micro SD card. It is a completely different type of card format on the inside, and despite the compatible size and shape, it will not work on devices labeled only as Micro SD card compatible. The Sansa e200 and up (e250, e260, ect.) are NOT COMPATIBLE WITH MICRO SDHC CARDS (Micro SD cards that exceed 2GB in capacity).
Dec 16, 2007 | SanDisk Sansa e260 MP3 Player
Canon PowerShot A1400 16 Megapixel Digital Camera - Black Logo
22 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
