Question about Tomtom GPS
Xl340 no written instructions on mounting
Help me to mount on windshield and explain the purpose ot part no.5s00.009
  • 3 Answers
It sticks to surfaces that a suction cup mount does not stick to.
Posted on Dec 28, 2009
How do you replace windshield wiper motor on a 1997 ford e250 van
REMOVAL
  1. Raise and support the hood.
  2. Remove the windshield wiper pivot arms.
  3. Remove the cowl top vent panels.
  1. Disconnect the windshield wiper mounting arm and pivot shaft.
  1. Remove the access cover from the dash panel.
  2. Remove the mounting arm and pivot shaft retaining clip.
  3. Disconnect the windshield wiper mounting arm and pivot shaft from the windshield wiper motor.
  1. Remove the windshield wiper motor.
  1. Disconnect the electrical connector.
  2. Remove the three bolts.
  3. Remove the windshield wiper motor.
INSTALLATION
  1. Install the mounting arm and pivot shaft retaining clip on the windshield wiper mounting arm and pivot shaft.
  1. Install the windshield wiper motor.
  1. Place the windshield wiper motor in the dash panel.
  2. Install the three retaining bolts.
  3. Reconnect the electrical connector.
  1. Reconnect the windshield wiper mounting arm and pivot shaft.
  1. Press on the windshield wiper mounting arm and pivot shaft after it is aligned with the windshield wiper motor.
  2. Install the access cover in the dash panel.
  1. Install the cowl top vent panels.
  2. Install the windshield wiper pivot arms.
  3. Adjust the windshield wiper pivot arms.
This is technically for the V6 4.2L but I'm sure those Ford E250's have the same setup for windshield wiper motor. Let me know how it goes.
Nov 17, 2014 | Cars & Trucks
I need instructions on how to mount the nuvi 200w to my windshield
To secure the nuvi 200w to your windshield with the included suction cup mount (pictured below),
center the GPS on the clip, and tip the bottom edge on the bracket. Push the top of the GPS against the top clip until it clicks into place. Hold the bracket and GPS near the windshield where you like it best. Note where the suction cup is on the windshield in relation to the mirror, etc. Remove the GPS from the mount's clip by pushing the top tab back from the top of the GPS.
Clean the windshield (or portion that the suction cup will be stuck against) with a paper towel or newspaper and ammonia solution like Windex, etc. Clean the suction cup with the paper towel and Windex, too.
Lift the lever at the base of the mount - is shown in the picture above - if it isn't already. With the mount oriented as shown in the picture above, press the suction cup against the windshield where desired with one hand. Hold the mount firmly against the glass and use your other hand to press the lever on the base back toward the suction cup and glass. Press until it lays flat against the base / suction cup. Plug the power cord into the GPS and reinstall the GPS in the mount clips as done earlier.
To remove from the windshield, release the GPS from the mount clips, and lift the lever away from the base / suction cup. Locate the tab that is connected to the suction cup edge near the lever. Pull on the tab away from the glass to break the suction seal and remove from the windshield.
If this was helpful, please rate it 4 thumbs up. Thanks & good luck!
Sep 20, 2011 | Garmin GPS
We just bought a new bosch dishwasher (smu50e15au). Its easy to connect to water and power, but how do we mount it to the kitchen? Instructions are in German! Thanks, Suzanne
Hello Suzanne,
Bosch installation instructions are usually multi-language. They may appear to be in German, but on closer inspection, you should notice they are written in English below the German instructions.
However, just in case you do have German only installation instructions, you can download the multi-language version by clicking on the link below. These may look to be in German on first glance, but I promise the English version is there as well.
https://portal.bsh-partner.com/TCcustomBSH/controller/download_file?PDFOBID=vdxng6icdcso0pdmdb---jAs&UMOBID=vdxng5fcdcso0pdmdb---jAs
Hopefully, you will now be able to install your dishwasher correctly. If you need further assistance, I'm happy to explain any part of the instructions (in German or English), but you're going to have to explain what "mount it to the kitchen" means. I'm afraid that makes no sense to me at all ;)
Regards,
BElectric
Apr 12, 2011 | Dishwashers
Mounting of gps can't mount on windsheild.
Tomtom GPS devices come with a variety of windshield suction mounts. All have in common that the windshield and the suction cup both must be clean; use a mild soap dispersed in some warm water to remove any dirt. Rinse properly. Sometimes it helps to keep the cup a little moist.
Make sure the cup is not warped due to previous exposure to heat, and check for any nicks in the rubber. Small damage may easily make the mount unusable and you'd need to get a replacement.
Models with a lever mechanic: open the lever (cup becomes flat), press the cup against the windshield and while keeping pressure, close the lever. It will lift the middle of the cup away from the windshield, causing a vacuum.
Models with a ring around the cup base: Turn the ring all the way counter-clockwise (cup becomes flat), press cup against windshield and while keeping pressure, turn the ring clockwise 90 degrees. This requires some force, but in my experience these mounts stick more reliable,
Jan 04, 2011 | Tomtom ONE XL GPS
2008 Yamaha raider quick release Windshield mount directions
I looked for instructions everywhere. I saw your complaint on the web. Call the manufacturer and see what they say. Chaz Moto Dc
Feb 23, 2010 | Yamaha 1900 XV 1900 A Midnight Star
There is a black disc but I do not see any instructions for using it.Does it mount on the windshield?
my Magellen came with a black disk with adhesive on 1 side. Intended to be adhered to any smooth surface (e.g., windshield). The mount for my unit includes a suction cup. So, mount black disk to windshield and attach suction cup to smooth side of black disk. Be sure disk is positioned where suction cup and bracket and GPS will have sufficient room to mount everything.
Jun 05, 2009 | Garmin nuvi 255W GPS Receiver
Wiper motor replacement
SECTION 501-16: Wipers and Washers 1999 Town Car Workshop Manual REMOVAL AND INSTALLATION Mounting Arm and Pivot Shaft Removal
  1. Disconnect the battery ground cable (14301).
  1. Remove the windshield wiper pivot arms (17527).
    1. Remove the nuts (one each side).
    1. Remove the windshield wiper pivot arms.
  1. Remove the LH and RH cowl top vent panels.
    1. Remove the hood weatherstrip.
    1. Remove the screws.
    1. Remove the retaining clips.
      • Disconnect the LH and RH washer hoses.
  1. Position the windshield wiper mounting arm and pivot shaft (17566) assembly aside.
    1. Remove the nuts.
    1. Remove the bolt.
    1. Position the windshield wiper mounting arm and pivot shaft assembly aside.
  1. Remove the windshield wiper mounting arm and pivot shaft assembly.
Motor —Windshield Wiper Removal
  1. Remove the windshield wiper mounting arm and pivot shaft (17566) assembly; refer to Mounting Arm and Pivot Shaft .
  1. Remove the windshield wiper motor (17508).
    1. Remove the output shaft bolt.
    1. Remove the bolts.
May 01, 2009 | 1999 Lincoln Town Car
Unsure how to mount tomtom on car windshield
I was perplexed by the lack of instruction as well. However, I took the unit to my car and realized that the black disk is not needed for mounting the unit to the windshield. If you look carefully at the bumpy plastic ring just above the suction area, there are two little pictures on the back of a lock; one open and one closed. With the ring in the open position, push it against the windshield and turn it to the closed position. It then sticks to the glass very well. I now just snap the unit in and out of the mounting ring that I leave stuck to the glass. I hope this helps. I assume that the presence of the black disk is to bring people closer together with digital communication.
Dec 14, 2008 | Tomtom One XL GPS Receiver
Tomtom One attachement to the alternate mounting kit
I just hung up with TOMTOM support. If you have the first edition TOMTOM you need the EZ Port Mount Kit for the 1140, 1140S, XL340 or XL340s. Not it isn't rocket science, but it would have been nice to have clear compatability information on the box. Hope this helps.
Jul 14, 2008 | Tomtom One Alternate Mount Kit Mounting...
GPS Logo
96 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
