Question about KitchenAid Kitchen Ranges
Bottom element still not working whirlpool after replacement
4 Suggested Answers
ethelpilgrim
SOURCE: bottom element needs replacing
the side right side panel comes off three screws hod it on the back pullout
Posted on Feb 08, 2009
buffalonyman
  • 1865 Answers
SOURCE: Whirlpool rf366pxyw bottom element replacement-
You need to troubleshoot the whole ciruit, from the control knob to the element
Posted on Apr 16, 2009
Macmarkus
  • 2605 Answers
SOURCE: The bottom element on my Whirlpool GOld
Hi, Are you equipped to check the bake element to determine if it's the problem ? You may be able to see if it has a burnt section on the element via a visual inspection. If so it is the problem, if not you'll need a multimeter or a pro technician to come and inspect it. With a meter you want to check the element for continuity (unplug the range and remove one of the wires at the element first) I will add the price of a bake element is cheaper than phoning for service "IF" you can change it yourself. Hope that help's you at least reach a place to make an informed descision on whether to attempt a repair on your own or call a pro. Thank's for visiting fixya. Please take a second to rate the info I provided for you today. Good luck in whichever way you choose. Macmarkus :)
Posted on Dec 11, 2009
Testimonial: "Haven't try the fix yet, but your response was very quick. Thank you."
Whirlpool built in electric oven bake (bottom)heating element does not heat up only tot heats when in bake mode
CHECK FOR CRACKS IN THE BAKE ELEMENT. IF THE UNIT IS NOT HEATING THE BOTTOM, BUT THE TOP IS STILL HEATING, YOU MORE THAN LIKELY HAVE TO REPLACE THE ELEMENT. THIS IS A 220 VOLT OVEN WITH 110 VOLTS ALWAYS GOING TO THIS ELEMENT, SO TURNING OF THE BREAKER IS VITAL FOR SAFETY PURPOSES. WITH AN OHM METER, UNINSTALL THE ELEMENT AND CHECK BOTH WIRE CONNECTIONS FOR OHMS. YOU SHOULD GET SOME KIND OF READING BETWEEN 10 OHMS AND 500 OHMS. IF YOU'RE NOT AT LEAST GETTING A SOLID READING, REPLACE THIS ELEMENT.
Jan 24, 2013 | Whirlpool 24" Double Electric Built-In...
Whirlpool oven model RDE6030A the bottom element
Unplug stove and remove screws holding element to oven cavity. Remove and take to nearest appliance shop and they will match up for you. Not an expensive repair. Hope this helps.
Feb 02, 2010 | Ovens
Bake element not working-electric oven
i had the same problem with my oven i think its a contact that conects to the bottom element the top one will work and olny go on broil cuz thats the olny time it comes on
Dec 24, 2009 | Whirlpool RBS305PR Electric Single Oven
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Replaced both elements, both thermostats. What else could it be?
no hidden switches!, did you replace bottom elements? and thermostats? one hint...bottom element heats first, then top...never both at one time.
Mar 24, 2009 | Kitchen Appliances - Others
Bottom element needs replacing
Jan 17, 2009 | Whirlpool GR399LXHS Electric Kitchen Range
Whirlpool Gold Range Mod GLP84900
Hi I have a whirlpool gold range mdl GJSP 84902 and had replaced the bottom hidden element after finding out it wasn't getting any heat. So replacement took a little figuring out. it ws easy after a removal of screws and pulling out the whole oven casing out fron the front. Anyhow I still don't get enough heat generate from the bottom element, what other cause are there. checked fuses wiring all is connected HELP ME PLEASE !!!!! thank you Paul
Nov 02, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Open Questions:
Kitchen Ranges Logo
12 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
