Question about Galaxy Radios Microsystems DX98VHP CB Radio
Low volume strong signal no sf movement have to turn vol control up to hear most signals
    New Friend:
  • 24 Answers
Try an external speaker........it might be a bad speaker in the radio
Posted on Apr 27, 2014
I have a 2004 chevy avalanche and the driver side is blowing hot air and the passenger side is blowing cold what can I do
Have it check for codes , an scan data checked on a factory scan tool ! The temp.blend actuator is electronically controlled by the HVAC control panel . Do you hear any clicking behind the dash ? Is it manual or automatic climate control ?
Air Temperature Actuator
The air temperature actuators are a 5-wire bi-directional electric motor that incorporates a feedback potentiometer. Ignition 3 voltage, low reference, control, 5-volt reference and position signal circuits enable the actuator to operate. The control circuit uses either a 0, 2.5 or 5-volt signal to command the actuator movement. When the actuator is at rest, the control circuit value is 2.5 volts. A 0 or 5 volt control signal commands the actuator movement in opposite directions. When the actuator shaft rotates, the potentiometers adjustable contact changes the door position signal between 0-5 volts.
The HVAC control module uses a range of 0-255 counts to index the actuator position. The door position signal voltage is converted to a 0-255 count range. When the module sets a commanded, or targeted, value, the control signal is changed to either 0 or 5 volts depending upon the direction that the actuator needs to rotate to reach the commanded value. As the actuator shaft rotates the changing position signal is sent to the module. Once the position signal and the commanded value are the same, the module changes the control signal to 2.5 volts.
DTC'S
B0174 is for the upper left air temperature sensor.
• B0179 is for the lower left air temperature sensor
B0414 is for the left air temperature actuator.
• B0408 is for the left air temperature actuator.
Jun 23, 2017 | Cars & Trucks
I have a 2004 grand prix,sputters at 2000 rpm no engine light.w/ car off key on, press gas 5 times get codes 1125,2125. clear codes light goes out but still sputters. do i change accelerator and TPS?
.The control module provides the APP sensor a 5-volt reference circuit and a low reference circuit. The APP sensor then provides the control module a signal voltage proportional to pedal movement. The APP sensor 2 signal voltage is low at rest and increases as the pedal is depressed. When the control module detects that the APP sensor 2 signal or the APP sensor 5-volt reference voltage is outside the predetermined range, DTC P2125 sets.
The control module provides the APP sensors a 5-volt reference circuit and a low reference circuit. The APP sensors then provide the control module signal voltages proportional to pedal movement. The APP sensor 1 signal voltage is low at rest and increases as the pedal is depressed. The APP sensor 2 signal voltage is also low at rest and increases as the pedal is depressed. One APP sensor DTC will not cause the Reduced Engine Power message to be displayed. Two APP sensor DTCs for the same sensor also will not cause the Reduced Engine Power message to be displayed. However, if two or more DTCs are set involving more than one APP sensor, DTC P1125 will set.
Jan 17, 2017 | Cars & Trucks
ASUS PadFone X Mini lost all sound on phone
You phone is defective, either have it repaired lace it.
Jul 26, 2016 | ASUS Cell Phones
While i am making voice call ,i cannot hear what caller is telling me and they do not hear me as well
Have you tried adjusting the volume? Is your signal strength weak or strong when you are making the call? It may be a product defect if your volume is turned all the way up, and you have a strong signal.
What type of a phone do you have?
Jun 15, 2011 | Cell Phones
What does the check engine code p0406 mean on my dodge caravan with a 3.3L engine?
P0406 - Exhaust Gas Recirculation Sensor A Circuit High
An improper voltage signal is sent to ECM through the valve
Early Models : The EGR valve control the amount of exhaust gas routed to the intake manifold. Vacuum is applied to the EGR valve in response to the throttle opening. The vacuum control the movement of the taper valve connected to the vacuum diaphragm in the EGR valve.
Late Models : The EGR volume control valve uses a step motor to control the flow rate of EGR from exhaust manifold. This motor has four winding phases. It operates according to the output pulse signal of the ECM. Two windings are turned ON and OFF in sequence. Each time an ON pulse is issued, the valve opens or closes, changing the flow rate. When no change in the flow rate is needed, the ECM does not issue the pulse signal. A certain voltage signal is issued so that the valve remains at that particular opening.
Symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Engine hesitation
Possible causes
- Harness or connectors (EGR volume control valve circuit is open or shorted.)
- EGR volume control solenoid valve
- EGR temperature sensor and circuit
Possible solution
- Repair EGR harness or connector
- Replaced EGR volume control solenoid valve
- Replaced EGR volume control valve
Hope helps (remember to rate and comment this answer).
Mar 31, 2011 | Dodge Caravan Cars & Trucks
We have to hold the remote control button hard and straight at the reciever for ti to work
The volume keys should be working by default, but you may have volume punch through turned on (meaning the remote is sending signals for TV or CABLE volume function no matter what mode you are actually on). To unlock volume control for AUX mode, do the following:
1. Press and release AUX
2. Press and hold SETUP until the remote blinks twice
3. Type 993
4. Press and release VOL-
The remote should blink four times to confirm unlock.
May 20, 2010 | Yamaha HTR-5860 Receiver
The shaft of the volume control was contaminated with crazy-glue
3. Type 993
Jun 07, 2010 | Yamaha HTR-5740 Receiver
Dryer signal at cycle end is very weak cannot hear it if more than several feet away.
Most dryers have a volume adjustment knob on the control panel. If it is turned full on, the alarm signal device may need to be cleaned or replaced. The signal device is likely located within the control panel. Good luck!
Feb 20, 2010 | Dryers
Blue tooth low volume
Have you tried raising the call volume level on the phone?
The GMRS-X1 will only amplify a preset ammount, low signal in = Low signal out
Jul 14, 2009 | Chatterbox GMRS-X1 (15 Channels) 2-Way...
I record but the sound is very very low.
If you are recording from a line-out coming from a headphone output from the TV try increasing the TV volume. (and check the signal is strong by testing with headphones).
If you need to still increase the recorded volume... open the Volume control mixer; open the properties for Recording; select an Advanced option and then Microphone boost
Jul 09, 2009 | Pinnacle Dazzle DVD Recorder
Galaxy Radios Microsystems DX98VHP CB Radio Logo
47 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
