Question about Boss Micro BR Digital Recorder
1, 3, 5, and 6 br8 - Boss Micro BR Digital Recorder
Boss br8. I have no power is there a fuse inside the machine?
There should be a fuse on the power supply board inside the unit. If it is not that then it is most likely the board itself. You can get a replacement at Allied Electronics.
Nov 29, 2014 | Roland Boss BR-800 Digital Recorder
Can't download tracks from BR-800 to laptop
Go to this site:
http://www.vsplanet.com/ubbthreads/
In the forums tab, scroll down to the BR8 forums. There is software to convert the BR files to PC readable. You can find discussion there of where and what to get.
Jun 17, 2011 | Roland Boss BR-800 Digital Recorder
Can I use a computer hard drive in my Boss Br8 multitrack recorder the zip drive is not reading....something like 20 gig or whatever is in a pentium 3 would this work and if so how do I do it???
It is not likely the firmware will talk to a hard drive as the interface is different.
Refer to the VSPlanet.com site where some have converted to use SD cards in place of Zip drives.
Feb 06, 2010 | Boss Music
Each time I attempt to initialize a zip disk in my Roland BR8...
Probably the drive has gone bad as a first thought... this happens. Possibly the heads got dirty...
Make sure nobody has smoked tobacco around the unit as that is a killer for Zip drives.
Sometimes they have a second level of initializing/formatting. If the BR* has that, try it.
Jan 25, 2010 | Boss Music
Boss BR 8...I insert the 100 mb disk, then asks to initialize..I enter 'yes' then it asks 'sure?' I enter yes then it says 'medium error' then ejects the disk..what's the problem?
If the disk had data put on with a PC you might try deleting all files and folders using the PC before formatting the disk in the BR8.
It is also possible that the media has gone bad.
A final try would be to degauss the disk and try to format on the BR8.
Sep 09, 2009 | Boss Micro BR Digital Recorder
Need Help on a Boss B R 8
I think I solved this problem.
I used a different power adapter and it works now. Try different adapters, I used an old Nintendo one. It is 9V 1.3A, even though the back of the BR-8 says 9V 2A
Jul 18, 2009 | Boss Micro BR Digital Recorder
BR8 Digital recording studio lights up, but it doesn't do anything else
I called Roland at the number that you provided and gave they following proceedure which will re-intialize the BR 1180 and ERASE everything that was created on the HD:
  1. Simultaneously hold down button beneath volume control at track 5 and Undo/Redo button at upper right
  2. Press power button while holding down buttons as above, until test menu comes up
  3. Turn selector dial untill initialize screen shows
  4. Prdess ENTER and initialization will start
  5. Once initialization is completed, power off unit and then power it back-up.
NOTE: This proceedure erases all data!
Apr 16, 2009 | Boss Micro BR Digital Recorder
Boss Micro BR Digital Recorder Logo
Top Boss Music Experts
Michial Gueffroy
Darial Jr Lasaria
Darial Jr Lasaria
Vito Vacirca Jr.
Are you a Boss Music Expert? Answer questions, earn points and help others
