Question about Dell Inspiron 1525 Laptop
Sound i need to enable soundboard
    Top Expert:
  • Dell Master
  • 25,334 Answers
The sound should be on by default.
Posted on Apr 19, 2014
No sound although devices show working okay
make sure all your wires are connected, if you have external speakers, make sure they are plugged in at the correct port on your pc. do you have a sound card, if you do it needs to be enabled in your bios screen. if you don't have a seperate sound card and are using the sound card off *********** board it will also need to be enabled in your bios screen. on most pc's you enter the bios screen by rebooting, when the pc flickers press delete on your keyboard it should bring up the bios screen. good luck!
Jan 16, 2012 | Foxconn Computers & Internet
When i plugged speaker in the in the on-board jack it is working and i can hear sound but when i connected to the sound card,no sound is there..Is there any additional settings to enable sound card in the...
Assuming you are running some version of Windows, open the System Control Panel. Click on Device Manager to look at your hardware. Check your Sound devices. If you see a yellow or red icon over the one for your sound card, it is disabled or missing something. In that case, right-click on it to see what's going on - select Enable if it is disabled, otherwise select Properties for more information. You may have to disable the on-board sound to prevent conflicts.
May 02, 2011 | Gateway /Creative SoundBlaster Sound Card
Sound not deticting
you hve to install the sound driver of your sound card or mother board if it is a built in sound card.or enable the setting of your mobo.enable the built in soundcard.access it on the bios setting
Oct 16, 2010 | Intel CPU CORE 2 DUO T6400 200GHZ...
No sound in computor.Sound driver is SoundMax WDM driver
since the board does not have built in sound card u must be using and pc sound card! install the sound cards drivers again! if done go to control panel-> system -> hardware -> device manager see for a sound card installed and check if it is enabled
or else first go to the BIOS setup at the startup and see if the PCI Sound card is enabled or not!
reply and rate!
Jul 11, 2010 | Mercury Computers & Internet
INTEL MOTHERBOARD D915GLVG NOT SHOWING SOUND OR NOT GIVING WHICH TYPE OF SOUND CARD IS INSTALLED AND WHICH DRIVER REQUIRES
Maybe the on-board sound is not enabled in the bios. Restart, enter the cmos and enable the sound. Save and exit. Reboot and install sound driver that came with the system board.
Feb 16, 2010 | Intel D915GLVG Motherboard
How to enable audio in motherboard AOpen MX4GVR, I can't get any audio no. Do i have to set any pins at the main board?? Thanks you!!
go to control panel - sound and audio device - see if there is sound device active...you can configure anything from there related to sound or if none device enable...then you need to install the driver
Jun 07, 2009 | Intel D101GGC Motherboard
I cannot enable the on board sound card(sound Max)
check the driver status of your sound , in the device manager, if its not installed , then install the drivers or if your sound is not detecting then
go to the BIOS and load optimized bios default settings then check
Nov 20, 2008 | ASUS P4P800 SE (890552603657) Motherboard
Adam john napier
maybe the on-board sound are disabled check the bios setup by tapping del or F1 at the start of your pc then look for the sound driver thing if its enable if its enabled then it maybe internal
Sep 30, 2008 | Computers & Internet
Mother board installer
cd driver
P4VM800M7 Motherboard
Jul 18, 2008 | Mercury P4VM800M7 Motherboard
Enableing 2 sound cards
Err not sure but i think i remember trying to use 2 similar SBL cards and having nothing but problems with device manager.
Theoretically you should only need one of them , combined with your motherboards on-board audio.
This will enable you to play the two seperate samples , each exiting via its own lead to suit your mix console.
All you will need is windows media player using the standard on-board audio device
+ another similar player (configured to use the SB card via options)
Leave the on-board device set as the default audio device.
Jun 02, 2008 | Computers & Internet
Dell Inspiron 1525 Laptop Logo
21 people viewed this question
Alun Cox
