Question about HP Compaq 6910p Notebook PC PC Notebook
HP Compaq 6910p overheats and shutdown
BIOS Version F.19 07/06/2010 Issue started with Windows 7. Then I loaded Ubuntu. Same issue exist. Loaded a lightweight Linux Manjaro. I still see the problem. Also cleaned the thick dust beside the FAN but to no avail.
    Top Expert:
  • HP Master
  • 26,196 Answers
Being an Hp, I would suspect the GPU. Heat damage will make the CPU work very hard and it in turn will overheat. Unless the heatsink compound has lost its usefulness. Between the CPU and the heat sink.
Posted on Apr 19, 2014
tat4u
  • 520 Answers
SOURCE: is HP Pavilion dv6000 Laptop support Linux Enterprise Version 5
try out a live cd first for copatability...I use backtrack 3 with xp pro sp3 installed on hd..
Posted on Jan 22, 2009
odiebugs
  • 949 Answers
SOURCE: notebook heating problem(urgent help)
You bios versions start at f.03,f.04,f.05, f.07, f.08,,,
The date and version that you posted does not match and bios version for your model.
The only reason you update a bios is if it falls under the problems
listed for the new bios to correct.
Say your lap came with f.05, the only reason you would update to f.07 is because you had a graphic error,that the new update fixed.
The link below is the page for your drivers, if you look at bios,it shows the newest,if you click on version,you will see all the ones
that where made.
You should double check to make sure that you have the right bios version.
http://h10025.www1.hp.com/ewfrf/wc/previousVersions?softwareitem=ob-61399-1&lc=en&dlc=en&cc=us&lang=en&os=2093&product=3646603
Posted on Apr 14, 2009
leecom72
  • 4806 Answers
SOURCE: When typing on my HP notebook (Compaq 6910p) I
The sensitivity of the touchpad maybe too high, this is a common problem and can be easily sorted.
Go into the control panel and select mouse, there you can set the sensitivity of the pad.
See if that helps any!!!
Good luck.
Posted on Jul 01, 2009
Geekman
  • 32281 Answers
SOURCE: Audio drivers for HP compaq nx7010 with Windows 7
This WEB site can supply the Windows 7 drivers, please click on this link :-
http://www.user-guides.co.uk/cddownload/HP/HPCompaq/HP-Compaq-nx7010-Windows-7-Driver-Recovery-CD-Restore-Disk-313489.html
Posted on Mar 07, 2010
  • 54 Answers
SOURCE: HP 6910p will not boot upon restart. If the
seems like there is some s/w glitch in it. try to create a new admin a/c. hopefully it will fix the problem.
Posted on Apr 29, 2010
To much dust in the cpu-fan or gpu- fan or convex topped bulget or leaking capacitors inside
Apr 19, 2014 | HP Compaq 6910p Notebook PC PC Notebook
My computer shut off out of nowhere with no warning.
They are a problem when they overheat. No warning just off. Try cleaning the fan and radiator. You will have a fighting chance then.
Mar 09, 2014 | HEWLETT-PACKARD Compaq Presario CQ60-615DX...
Where dos jumper located on compaq 6910p and how can i remove bios password on 6910p
Most "laptop" computer do *NOT* have a jumper that can be used to bypass a BIOS password.
This is DELIBERATELY done, so that a thief in possession of your laptop cannot bypass your password, and thus cannot use your stolen laptop.
Find your original bill-of-sale, to prove ownership, and telephone HP/Compaq, and ask for Technical Supoprt in resetting the BIOS password.
Jun 20, 2011 | SIB SATA 250GB for HP/Compaq 6910P NW8440...
My sister has a two-plus-year-old MT6840 that just had the battery replaced. However, both before that issue and since she has had trouble with her display. The computer will load as though it is starting...
The easiest way to narrow down the problem would be to boot the computer with a copy of Ubuntu.
You can either create a boot cd or convert a flash drive into a bootable drive. The flash drive boots much much quicker so I definitely recommend you following the creation method for that on Ubuntu's download page. If you don't have a flash drive, don't worry, the boot cd will still work ;)
One thing to note is your computer's boot order. Usually pressing F12 on a Gateway will bring up a temporary menu so you can select your copy of Ubuntu. If not enter the BIOS setup menu and change your boot order.
Once the Ubuntu launch screen comes up just choose TRY UBUNTU this will create a live session.
If Ubuntu works without any hitches then it's likely a Windows software issue OR a hardware issue.
You can run a trail version of HDD REGENERATOR to physically scan the hard drive exactly like Ubuntu, LIVE.
If it comes back clean then YES, it's a windows software issue. Which entails more testing and button pushing.
Try the above and let me know how everything turns out.
Jan 03, 2011 | Gateway MT6840 Notebook PC
Hi there.I've hp compaq 5610b laptop and using vista operating system.Is it possible to use another operating system in my computer?Plz help me!
You can install the previous version of Windows - this is Windows XP or you can install the latest version of Windows - this is Windows 7.
You can install a Linux operating system such as Ubuntu or Red Hat
Google search for Linux operating systems to download Linux freeware program.
Dec 16, 2010 | HP Compaq 6510b PC Notebook
I own an older version of a Compaq laptop with
its usally facebook, they have some issues, but u may want to use firefox, not IE, also a reinstall of xp home might help, and make sure you have the latest version of flash player, or you could go the fun way and remove windows from it and install Ubuntu Linux (order it for free and free shipping and handeling from https://shipit.ubuntu.com/) happy holidays
Dec 30, 2009 | HP Compaq Evo n610c Notebook
HP Compaq 6910p New hard drive installed, XP os canot see the hard drive, asking for driver. ? where can i get it and how do i install it. Yours Steve
Method 1 :  Go to BIOS and set anything with SATA disable (usually find uns=der advance setting in IDE configuration setting).
Save the setting.
Windows Xp will detect your hard drive now.
Method 2 : This days BIOS comes with only few thing to configure.if that's is the case.
Download SATA driver,here is the link
http://download.cnet.com/SATA-Driver-Intel-Ver-7-0-0-1020-zip/3000-2122_4-162224.html
you need one more software called "nlite" in order to integrate the SATA driver in Windows XP CD so that it recognize SATA drives.
Here is the link for nlite download
http://home.midmaine.com/~nlite/nlite/nLite-1.4.9.1.installer.exe
On how to intergrate SATA driver with windows XP
Go to this page :
http://www.nliteos.com/guide/part1.html
Rate this answer.
Dec 28, 2009 | HP Compaq 6910p Notebook PC PC Notebook
My laptop keeps going off or if does go on it keeps on freezing. Why is that?
It might be a bios issue. Try entering the bios and selecting 'Default Settings' It might be a power management setting has been changed by windows. It that doesn't work then it might be a system fan or board fault which will require further investigation
Nov 06, 2009 | HP Compaq 6910p Notebook PC PC Notebook
Ntldr is missing
seems your MBR is damage. but you can repair it if only you can boot in windows cd and entering in the recovery console.
To run the Recovery Console from the Windows XP startup disks or the Windows XP CD-ROM, follow these steps:
1.    Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2.    When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3.    If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
4.    When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5.    At the command prompt, type this commands one at a time.
FIXMBR  C:
FIXBOOT  C:
COPY [CDDRIVE]:\I386\NTLDR  C:\
COPY [CDDRIVE]:\I386\NTDETECT.COM  C:\
BOOTCFG  /rebuild
6.    To exit the Recovery Console and restart the computer, type exit at the command prompt, and then press ENTER.
no warranty...you use on your own risk :)
Oct 27, 2007 | Compaq Presario sr1111nx 2.53GHz Celeron...
HP Compaq 6910p Notebook PC PC Notebook Logo
97 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
