Question about Frigidaire Dishwashers
Whining noise in my Fridaidare dishwasher - Frigidaire Dishwashers
  • Official Brand Answer
  • 2,267 Answers
Good Afternoon Bcolcott,
I see that you are hearing a whining noise coming from your Frigidaire dishwasher. I suggest giving your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for at least 20-30 minutes. When power is restored to your dishwasher, if you are still hearing a whining noise, I suggest you contact your local authorized technician. I hope this is helpful.
-Best Regards-
WP
Posted on Apr 22, 2014
FFBD2411NS makes loud whining noise after water is pumped out and continues until pump stops.
Thank you for your inquiry, Robert!
From the information you have provided your Frigidaire dishwasher makes a whining noise after the water has been pumped out. This could be a potential issue with your drain pump or motor. To pinpoint the issue you would need to disassemble your dishwasher and test each component and this would best be done with a certified technician. This will help you avoid personal injury or future problems. Best of luck! -Matt
Jun 13, 2015 | Frigidaire FFBD2411NS
LG LDF6810ST whine noise
-After paying an LG serviceman for a home visit, I told to refer to the manual-and there in small print-USE ONLY POWDER CLEANER. Gel and liquids make too much bubbles(thus air) in the hose producing the noise. It will take several washes-but the noise will go away!
Feb 24, 2013 | LG LDF6810ST Stainless Steel Built-in...
Dishwasher makes a whinning noise during the washing cycle. I have opened to check inside, and the dishwasher is ok for a few minutes, then it starts whinning again. The dishwasher is just over a year old,...
If wash quality is OK leave it. Pump will make whining noise due to its' ball/bush bearing problem.
Some times if the water inlet flow is not free in flow also results in noise.
Clean the inlet water filter and check the flow before re- connecting to the machine.
Aug 30, 2010 | Dishwashers
Whirlpool dishwasher is making a loud whine while running.
Have you found a solution to your whinning? Mine is doing the same thing. Started about two weeks ago.
Mar 21, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Bosch dishwasher whining
if you listen to the appliance and the noise is louder on the rhs and low down this is probably the main wash motor they sometimes do whine if you can live with the noise leave it alone if not you basically have to take the whole applianmce apart for access to the motor costly repair would take a trained pro about 90 mins to replace the motor
if the noise is coming from the front of the appliance more to the lhs and is intermittant ie when it first starts up and then about half way through its likely to be the drain pump relitively easy to replace and you dont have to take the appliance to bits just go at from the front
good luck
Mar 02, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Kenmore quiet pak III dishwasher has a whining noise
Most of these dishwashers have separate circulation and drain pumps and there is a good chance that there is an issue with the circulation pump impeller issue under the lower wash arm. The bottom panels under the door can be removed to check it out.
Chris Z --- www.repairclinic.com
http://www.repairclinic.com/Kenmore-Dishwasher-Parts
Jan 25, 2009 | Kenmore 24032\24036 Top Load Washer
Dishwasher makes a whineing or squealing noise during wash cycle. No noise during filling and draining.
Motor has something in it ( dirt,dust etc..)If it gets worse replace the motor.
May 25, 2008 | Kenmore Dishwashers
Dishwasher Making Loud High Pitched Noise.
A loud high pitch whine while running the dishwasher means that there is something caught in the chopper assembly. To get to the chopper assembly you need to take the racks out and take the pump apart from the inside of the dishwasher. The chopper assembly looks like a metal grate with holes in it. And it might not even be stuck in the grate but somewhere in the pump area due to the water being pumped out, so the best idea is to take the whole thing apart and clean everywhere. However I do not recommend doing this unless you are completely certain you will remember where the screws and gaskets go, otherwise you risk damaging your pump or house from a leak or improper installation. You have been warned.
Dec 25, 2007 | Whirlpool 24 in. DU900PCD Built-in...
High pitched whining noise from bottom of dishwasher
the arms are only turned by water coming out of them thro angled jets, they are not electrically driven. the noise will be coming from the circulating pump, probably one of the bearings. no cure except to replace
Mar 10, 2007 | Baumatic 18 in. BDW45.1 Built-in...
Dishwashers Logo
255 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
