Question about GE 24 in. Profile PDW7800 Built-in Dishwasher
10-yr old GE Profile dishwasher...lately there's been detergent left in the cup, and lots of items come out dirty...plastic, ceramic, etc. I've cleaned/rinsed the sprayer and filter, but it doesn't he
Per above, liquid detergent remaining in cup after cycle, many items not clean.
  • ajeske Apr 24, 2014
    Thanks, but it turned out to be a metal plate hanging off the bottom of the sprayer which prevent the sprayer from rotating. Snapped the plate back on, problem solved!
    "...prevented the sprayer..."
  • GE Master
  • 3,247 Answers
Check if the water is getting heated in the dishwasher. Most likely water temperature if not adeqaute will not fully use the detergent and cause dirty dishes. This could be caused by heater which is failing.
Posted on Apr 24, 2014
  • Sam Apr 24, 2014
    good to hear that.
SOURCE: GE Profile Dishwasher Not Cleaning
I removed the outer metal door cover by removing most of the phillips roundhead screws. The two screws closest to the latch should not be removed (they hold plastic pieces that help hold the outer door cover in place during reassembly), and the two flathead screws on the side of the door near the hinge should not be removed yet (they attach the pump). The door cover also has two small hex bolts on the bottom - these should be removed, too (or at least loosened). I removed them.
The outer door cover has two flat flexible wire bundles (for the buttons) that attach to the door using "quick-connect" push-pull connectors. One has a small tab which must be slightly depressed. Gently but firmly pull these out. Set the door cover aside.
I removed the pump by (one) gently but firmly removing the short (2" or so) gray rubber tube from the bottom of the detergent reservoir (NOTE: any detergent remaining in the reservoir will immediately drain on the floor at this time -- I let it drain most of the detergent into a cup, but then I taped a tapered wood screw into the opening to serve as a plug); (two) removing the 90 degree rubber fitting that attaches to the door; (three) disconnecting the motor wire electrical quick-connect; and (four) removing the two flathead screws that attach the pump to the door.
My (rotary peristaltic) pump has a black flexible tube that was clogged with solidified detergent. I verified the pump worked by first connecting the pump to power from the wall outlet. I used an old extension cord, cut the ends, crimped some small connectors that did not fit well to the pump connector, then taped the whole thing to help prevent a shock (I did not feel comfortable with this, but I did it anyway. Use caution. If I have to do it again, I would have used a pipe cleaner or wire instead of operating the pump as described below.). The pump motor is rated 110 volts ac., and the pump was operating fine. I think I got lucky (the pump spun the correct direction). It may be that if I reversed the wires, the pump might have operated backwards.
I then held the pump inlet hose under hot water in the sink for about 10-15 minutes, occasionally squeezing the hose, until the thick detergent had dissolved. During this time, the pump was pumping the water out the outlet.
I put everything back together, and the dishwasher cleans again.
Posted on May 20, 2008
MNTECH
  • 1543 Answers
SOURCE: Poor wash performance with GE Profile PDW9280 dishwasher
Check the holes in the spray arms for obstructions.
Posted on Mar 28, 2009
  • 108 Answers
SOURCE: GE Triton dishwasher won't drain.
It sounds like the drain pump has gone bad.
First, unplug the unit or turn of the breaker, then remove as much water as you can with a wet vac if possible.
Remove the panels from the bottom of the front of the dishwasher (removing the big door won't help you) Then, disconnect the drain hoses from the pump (squeeze the hose clamps with pliers), any remaining water will come out when you do this, so you might want to put a thick towel underneath.
Pull out the wires—use pliers so you don't yank the wires out of the plugs, and remove the pump. Look inside and make sure there is nothing stopping the propeller- you may need to unscrew the pump from the plastic housing check.
If there is no blockage, it has likely just "gone bad" but to do one last check: take an old, two wire extention cord and carefully connect each wire to one of the prongs on the pump (make sure no stray wires "dangle" by using electrical tape if you need to) and plug it into a wall outlet.
If the propeller spins, something else is wrong with the machine but if it doesn't, you need a new one.
Posted on Apr 09, 2009
SOURCE: My GE Profile Dishwasher PDW7880 Soap dispenser does not empty
I had the same problem. After some investigation I found that the hose that brings water to the top arm was clogged. There was a piece of chipped china logged in there. I have no idea how it got there as it is at the top and facing the the back wall but once I managed to take it off it solved the problem.
SOURCE: dishwasher detergent left in dispenser
there is no solution for it because of its design. i have same GE and same problem. It is happening because top rack is right front of the detergent cup and it is not opening 180 degree while it is washing. it opens only 15 or 20 degree and water just doesnt get in there as much as suppose to be because only water can get in there from the bottom sprayer arm because detergent cup lid is not allowing water to get in the cup from middle and top sprayer like any other dishwasher! i called them so many times and they are just jerks! they blame anyting about my house but their dishwasher. their tec. showed up 4 times and they just keep blaming hot water temrature etc. water temprature doesnt matter if water cant get in the detergent cup, right? but they dont want to admit that because they are like programed robots to give you same answers and just blame you but GE dishwasher. please fill out complain form with Consumer Complaint Department. you should be able to find their address and web site on the internet. Please do so, maybe we can get refund or replacement or something. Never ever buy GE again. Just get a Bosch.
Posted on Apr 10, 2009
PDWT300R10WW
Check the pump and filter for blockages as the dirty water may be not draining properly. A mix of detergents is ok. Run a prewash with the unit empty and see if the water is still greasy
May 09, 2012 | GE 24 in. Profile PDW9880JSS Built-in...
My office's GE QuietPower 3 dishwasher detergent
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Jul 29, 2011 | Maytag Dishwasher
Why does a lot of detergent remain in the soap dispenser after a washing cycle is complete
Was the dispenser cup wet when you added detergent?
Make sure the dispenser cup is dry before adding powdered detergent. If dispenser cup is wet, the detergent can clump.
Is the cycle incomplete?
If the previous cycle did not complete, the detergent can become caked in the dispenser cup if it is left sitting in the dishwasher.
Is the detergent old?
Older detergent exposed to air will clump and not dissolve well, which will cause the dispenser door to stick to the detergent. Replace detergent if necessary and store the detergent in a tightly closed container in a cool dry place.
Is the water temperature too low?
For best washing and drying results, water should be 120oF (49o C) as it enters the dishwasher.
Were items blocking the dispenser that kept it from opening?
Items blocking the detergent dispenser will keep it from opening. Make sure water action can reach the dispenser.
Detergent guidelines
  • Use automatic dishwashing detergent only.
  • Other detergents can produce excessive suds that can overflow out of the dishwasher and reduce washing performance.
  • Store tightly closed detergent in a cool, dry place.
  • Fresh automatic dishwasher detergent results in better cleaning.
  • Add detergents just before starting the cycle.
  • The amount of detergent to use depends on the hardness of your water and the type of detergent.
  • If you use too little, dishes won't be clean.
  • If you use too much in soft water, glassware will etch.
  • Suggested fill amounts are for standard powdered detergent. Amounts may vary if you use liquid or concentrated powdered detergent. Follow instructions on the package when using these detergents.
  • Water hardness can change over a period of time. Find out your water's hardness by asking your local water department, water softener company, or county extension agent.
Nov 25, 2010 | LG Washing Machines
Filmy substance after wash, looks like detergent residue no matter what setting i have
heatman101
Apr 10, 2010 | GE Profile PDW8400J Built-in Dishwasher
Detergent left in dispenser cup
You either do not have enough water getting itno the machine or it is not hot enough. 5 years old so I would suspect a plugged screen on the fill valve.
Eric
Dec 11, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
GE Profile dishwasher makes a humming noise
I had the same problem. The issue is due to the top rack water inlet not properly seating against the water line in the rear of the washer. I fixed it by placing heavier items (bowls, glass cups) on the rear of the rack and lighter items (plastic cups) near the front of the rack. As long as I arrange items on the top rack in this way the washer runs silently.
Oct 08, 2009 | GE GSD3800G - Multiple Color Built-in...
GE Profile PDW9200J dishwasher leaves a film and dirty dishes
Sounds like you have an excessive build up of hard water (mainly calcium) in it. Clean it like this: Close the detergent cup cover. Run hot water at the sink to clear cold out of the pipes. Start the machine on pots and pans/added heat. Wait about 10 minutes and open the door. If the detergent cup cover flops open, it is in the main wash. If it is still closed, let it run a few more minutes, check cup cover again, keep dong this until the cover is open. Once it is open it will be in the main wash (the longest cycle) and at that time put in about 2 cupfulls of Tang orange drink in the bottom of the tub. Tang is very high in citric acid and will clean the calcium and other hard water deposits from the tub, pump, spray arms, ect... Make sure your hot water is HOT (130 is great) and use Cascade Complete powdered detergent from now on. Should take care of it... Repeat every 6 months to keep it clean.
Dec 20, 2008 | GE 24 in. Profile PDW9200J Built-in...
Need a diagram for the kenmore dishwasher model 665.16645890
I have GE Dishwasher (model no:GSD1100G02),and for the last few month I was not able close the main detergent cup cap(it is coming back to full open position,even after keeping the CAP turned all the way to a closing postion)
I have called the GE spare parts division,and obtained the New detergent cup cap,and when I tried to remove the old one,inorder to replace with the new one,I was not able remove old one.
Please help me how to remove the old main detergent cup cap,and replace with a new one.
Hope I will hear from you soon in this regard.
Murthy Pillutla
Home Ph:630-428-3277
Cell:484-919-3653
Jun 14, 2008 | GE 24 in. Profile PDW9880JSS Built-in...
Dishwasher detergent left in dispenser cup on GE Profile dishwasher
Apr 14, 2008 | GE Dishwashers
Neff Dishwasher
It sound like a detergent cup issue (not opened in time). The detergent cup itself can become clogged with old dried detergent that prevents it from opening. Sometimes just cleaning the cup takes care of the problem. Let me know with your results. Good luck!
Sep 05, 2007 | Neff 24 in. S5543X2 Built-in Dishwasher
GE 24 in. Profile PDW7800 Built-in Dishwasher Logo
149 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
