Question about Garden
What kind of oil can I put in my Craftsman lawn mower
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,917 Answers
It is best to use what in recommended in your climate hotter climate lighter oil uasally the main oil to use is called 10w-30 no weight rateing just 10w-30 its a light oil made specifcally for lawn mowers engines
Posted on Jun 07, 2014
2 Suggested Answers
ccrozier_agr
  • 36 Answers
SOURCE: broken starter cord lawn mower #944.368300/craftsman
Please note ! patients is required with this one !
Hi, remove the recoil top cover with the recoil attached. ( DO NOT TAKE OUT THE SPOOL OR YOU COULD HAVE THE SPRING GET YOU IN THE FACE)
Remove old cord.
With your new cord lace it through the recoil spool centre hole with a knott on the end.
now depending if the recoil winds in clockwise when spool is facing you wind the cord around it a few times by turning the spool clockwise,
Then put the cord in the notch at the side of the spool & wind the spool & cord anticlockwise about twice the number of turns of cord (this should tension the spring).
Take your end of the cord & lace it through the hole outside of the casing & fit you pull handle.
But hold the spool firmly untill the cord has a good knott on the end of it.
(Sometimes I see the guys here putting a loop in the cord to stop it sliping in while they tie a knott on the end of the handle.)
Posted on Nov 29, 2008
Craftsman lawn mower won't start, low oil light is on, dip stick oil level is correct
Get some marvel mystery oil drian oil put in mystery oil let sit one hour with spark plug wire off try to start what this doses is clean the in sides ,do this about 10 times trying to start. Dump out mystery oil put new oil in don't over fill good luck
Jul 15, 2014 | Craftsman Garden
What kind of gas to used on lawn mower 55 158 cc craftman
Ori Hi, most lawnmowers use regular unleaded petrol now. If you have somewhere that oil goes into your mower then it will be normal unleaded but if on the fuel cap it has an oil can picture you need to mix it with two stroke oil.
Sep 07, 2013 | Craftsman 55 Torque 158cc 22" Push Lawn...
What kind of oil goes in my craftsman 625 model 944.367600
Tecumseh engines usually recommend SAE 30 oil. Briggs engines allow 5W 30 or 10W 30.
Aug 01, 2013 | Craftsman 675 Series 190cc 22" Briggs ...
Need to put oil in and don't know what kind of oil to put in or if it's gas oil mix????
ADD SAE 30 SMALL ENGINE OIL. 18oz TO 20oz
SEARS SALES A 20oz BOTTLE OF CRAFTSMAN SAE 30 OIL FOR $2.59
Oct 12, 2010 | Poulan Pro PR550N22SH 22Inch Briggs ...
Hi, what kind of oil can i put in my ridind lawnmower craftsman?
The domestic engines (Briggs, Tecumseh) take SAE 30 weight motor oil. The import engines (Honday, Kawasaki) usually take 10W30 motor oil. In either case, I recommend using a good quality name brand oil like Castrol, Pennzoil, etc. Most riding mower engine take about 48oz from a complete drain. If your engine has an external filter, it might require a few more ounces.
I hope this helps.
Aug 27, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Oil change
hi,the engine uses sae 30 oil,takes about 1 litre of oil,you can get this from most garages or mower centres,hope this helps
Apr 08, 2009 | Craftsman Garden
Garden Logo
55 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
