Question about Kitchen Ranges
Ceramic stove top knob not working
We have a GE ceramic stove top, the knob that controls the front right burner started acting up a couple of months ago. When it started, if one of the other burners was turned on, it would work. But if you tried to use JUST that burner, it would not. Now, it doesn't work at all.
    Novelist:
  • 150 Answers
Are you referring to the spark, or the gas flame? Are you able to turn the faulty burner on low, and lite with a match? You most likely need the spark switch replaced. Pleazer Appliance...
Posted on Apr 21, 2014
jsrock516
  • 5911 Answers
SOURCE: Stove burner igniter does not work.
Your problem is not the igniter itself, but the burner switch that controls the igniter. All the igniters get their power from one spark module that is mounted somewhere in back of the oven. That's why you are able to get all the igniters to spark with only one burner control turned on. This is normal. That is also why you are able to light the burner in question buy turning on another burner. The spark is being provided by a switch that is working. To answer your question: the igniter is removable, but I don't think it's necessary. Cleaning them generally doesn't make them work better. I would check the wiring from the spark module to the burner switch and/or replace the switch. I hope this helps.
Posted on Jul 18, 2007
SOURCE: stove top pilot light
I have a GE Gas Stove XL44 the stove top buners don't light by themselves without manual lighting. When I turn on the buner knob the buner doesn't click. Also I used my self- cleaning oven for the first time and stopped it before the time was up after that is when the stove top buners wouldn't light by theirselves.
Posted on Feb 08, 2008
SOURCE: GE Spectra JBP64BB front right large burner won't work anymore
how are you the GE Spectra JBP78 Electric... Problem: Subject: the proble is that i had a shortge of power and i have the ""lockdoor"" showing
Posted on Aug 01, 2008
  • 521 Answers
SOURCE: burner on range will not turn off
  1. all these problems are given in the link below and the solutions with diagram is given in it
  2. http://www.applianceaid.com/micro.html
  3. A common flow chart for microwave repairs
  4. A breakdown of a newer counter style microwave
  5. Door switch caution and repair help
  6. How can I get at the handle screws on my microwave to replace the handle? This has a common GE style microwave picture to help you.
  7. How to install a common over the range microwave
  8. Important Disclaimer
  9. I set something on fire in my microwave and now it is dead...help!
  10. My GE OTR ( Over The Range ) microwave is running but will not cook
  11. My Frigidaire microwave is flashing a fault code in the display...what's up?
  12. My GE microwave is flashing a fault code in the display...whats up?
  13. My Panasonic microwave is flashing a fault code in the display...what's up?
  14. My Sharp microwave is flashing a fault code in the display...what's up?
  15. My Whirlpool microwave is flashing a fault code in the display...what's up?
  16. My microwave light bulbs burnt out...caution!!
  17. Ohm testing an capacitor
  18. Some common Microwave FAQ
  19. Some common components and how to check them with a ohm meter - like magnetron, high voltage transformer, high voltage capacitor, door switches and high voltage diode.
  20. Stainless Steel Cleaning
  21. Sparks from inside the oven area....why?
Posted on Aug 27, 2008
rickzilla
  • 706 Answers
SOURCE: ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Posted on Sep 01, 2008
Spectra GE model JBP64W0B4WW stove top burner stopped working
Which element is it? Try to switch the infinite switch from another element. This will tell you if it is the element or the switch problem.
Apr 06, 2013 | GE Spectra JBP78 Electric Kitchen Range
Gas ignitor keeps trying to ignite after stove is off.
Hi and welcome to FixYa. I am Kelly. On your cook-top the gas igniters are cycled on and off by a ceramic and copper switch on the front of each of the gas valves. Some of them are in wired Series ...i.e any burner on will cycle all igniters on the cook top and some of them are in Parallel where individual burners are controlled by each gas burner control knob. Inside these tiny ceramic switches there is a flat thin strip of copper that as the gas valve is rotated a cam of the switch actuates pushes the copper strip against the fixed contact. Those little strips over time either break or get bent and stay against the fixed contact. Hence you have and igniter on when the burner control is off. The only fix is to find out which little ceramic switch on the front of the gas valve is stuck. You do it with an Ohm meter POWER off. They all should read open with the burner controls off. The one that reads continuity across the 2 wires is the bad switch.
Thanks for Choosing FixYa.
Kelly
Sep 13, 2010 | GE Cooktops
Burner Igniter will not Spark
No, actually each knob has its own switch and any knob will energize the spark module which sparks at all burners. So, just replace the defective switch which slides over the shaft of the gas valve. Careful! unplug the unit, these are 120 volt switches. Good luck.
Jan 12, 2010 | GE Ovens
For the GE XL44 model, where would i find the pilot light? the stove is not working
There is not pilot light on the stove top since the burner is activated by a spark generate by high voltage to a small ceramic disk with a wire protruding from it by the burner.
You have the have AC Power to the stove and you should hear a clicking when you slightly turn on the burner. Once the burner is on fire then turn the burner control to the desired temperature. If the burner will not light after 4 seconds of clicking sounds turn the burner control off and make sure the round gas diffuser on top of the burner is correctly seated on the burner. It should lock in place and is removable for daily cleaning of the stove. Now try the burner control again in the light position for no more than four seconds to see if it lights.
Do you smell gas? Do you hear clicking when slightly turning the burner knob? If yes to both the stove is working and the top of the burner is not seated correctly. If no on either or both you may have a stove, electrical or gas problem.
Jul 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spectra - burner pops & blows breaker
Either the burner has gone bad or the limiter on the burner.
Jul 11, 2008 | GE Spectra JBP78 Electric Kitchen Range
Stove top pilot light
Jan 20, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Ticking Sound of spark igniter persists
Our GE cook-top burner igniter has started ticking even when the oven is shut off. Even after cleaning the bottom of controls the ticking persists. Any suggestions? Thanks
Aug 27, 2007 | GE 36 in. JGP628 Gas Cooktop
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
