Question about Whirlpool Refrigerators
Remove ice maker?
I just bought a Whirlpool model GB2FHDXWQ08. I want to remove the ice maker altogether. Can I do that? If so, do I need a cover for the inside plug?
  • 67 Answers
Yes you can just remove the ice maker and no cover is necessary for the female connector, it will not harm the operation of the unit at all. You just need to use trays if you want ice.
Posted on Apr 25, 2014
  • 3 Answers
SOURCE: Ice Maker Motor replacement
I was able to remove the motor module by pressing together the two tabs that held the left arm of the shut off bar to the motor module. I purchased a new KitchenAid motor module (substituted a part by the factory). I replaced the motor module and I now have ice making again. The only difference though is that with the new motor module, the on position with the shut off arm is know longer in a 3 o'clock position but more a 5 o'clock position.
Posted on Aug 03, 2008
peyton32034
  • 410 Answers
SOURCE: how to repair the ice dispenser door on a whirlpool refrigerator
If you will look on the bottom of the dispenser cover you will see 2 notches on the left and right side. carefully pry the cover off using a flat tip screw driver. then you will see a white switch plate that is either held on with latches or 2 srews depending on model. once this is removed you will gain access to the dispenser door.
once you gain access I think you will find the hinges for the dispenser door are broken off. if so you will need a dispenser door repair kit form whirlpool part # 8201756 this kit includes new door and hinge repair kit. this is something you can do yourself if you are pateint and pay lose attention to detail. otherwise I would recomend a god servie company. thanks for using FixYa Peyton
Posted on Feb 18, 2009
localwonder
  • 6784 Answers
SOURCE: I have a Whirlpool Model EC3JHAXRL00. The ice
Is the ice maker wire shutoff arm or switch (depending on
models) in the OFF position?
 Is the water line shutoff valve to the refrigerator turned on?
 Has the ice maker just been installed? Is the freezer
temperature cold enough to produce ice? Wait 24 hours
after ice maker hookup for ice production to begin. Allow
3 days after ice production begins to completely fill ice
container.
 Does the ice maker mold have water in it or has no ice
been produced? Make sure your refrigerator has been
connected to a water supply and the supply shutoff valve is
turned on.
 Has a large amount of ice just been removed? Allow
24 hours for ice maker to produce more ice.
 Is there a water filter installed on the refrigerator? The filter
may be clogged or installed incorrectly.
 Is an ice cube jammed in the ice maker ejector arm?
For models with an interior ice bin, remove the ice from the
ejector arm with a plastic utensil.
 Is a reverse osmosis water filtration system connected to
your cold water supply? Make sue your connections are secure.
Posted on Feb 19, 2009
aasc
  • 1606 Answers
SOURCE: Ice maker not producing any ice.
Pour about 1/2 cup of water into icemaker . Squeeze the black fill tub which is above the icemaker cup . If ice apears to be in it , this indicates that the weter valve is not completely closing , letting a drip ocasionally go thru and freezing inside the tube , ( water valve bad ) . that will be a different solution . If the icemaker dumps the cubes after freezing . and black tube is not frozen , replace the water inlet valve . If the icemaker does not dump the ice after frozen , replace the icemaker ( only 1 screw holds the icemaker in , located on rear portion on right , faceing down . Also check the icemaker rake , which should be about the 2:30 position . To thaw out the black tube (which runs thru the top of the refrig ) a 1/4 push on connector will be needed . Remove the icemaker and use a hairdryer aimed up into the hole . Cut the tubing to the fill tub behind the fridge about 9 inches from where it enters the top of the fridge . This will let warm air inside the top fill line to help thaw . Ocassionally blow thru the 9 inch tube until you can blow thru it . May take a day or 2 , depending how frozen the line is . Once air will go thru , install the push on connector to couple the cut lines back togather .
The blinking red light on the right side , is the receiver for the electric eye for cutting off the icemaker when the door bin is full , This blinking is normal . 2 blinks ...pause...2 blinks..etc .
Do not replace the filter if water flow is good thru the dispensor .
Posted on Aug 16, 2009
  • 28 Answers
SOURCE: The freezer is covered with ice on the inside
Sound like water leaking from tubing to ice maker or valve drips
Posted on Mar 03, 2010
Remove ice maker whirlpool refrigerator
Ice maker repair - How to remove Whirlpool Kitchenaid ...
? 2:01
https://www.youtube.com/watch?v=UHi59JFB3N8
Feb 13, 2014 - Uploaded by AdamDIY
This ice maker is used in: Whirlpool, Kenmore, KitchenAid this one ... ... How to remove an ice maker from a ...
Jan 08, 2016 | Whirlpool Refrigerators
How to remove Kenmore ice maker 363.59572994?
I sure hope you got an awesome deal on that refrigerator. I would hate to think they charged extra for the mouse :-) Unfortunately, the ice bucket in this model does not just slide out like your other one did. You should be able to remove the front cover & flap of the ice bucket to reveal the ice maker and yes, it is bolted in. below is an exploded parts diagram of the ice maker. As you can see, the whole thing can be taken apart - of course you then have to put it back together. If it were me, I would toss it & replace the ice maker rather than try to disinfect/ sterilize the one in there. Good Luck!!
Jun 05, 2014 | Whirlpool GS6NBEXR Side by Side...
HOw to remove ice maker module cover
Don't bother. If your icemaker is more than a few years old, it's probably pretty cruddy and needs to be replaced, especially if you have hard water. It's an easy job and you can get OEM replacements for Whirpool from Amazon for less than $100. But before you do, you need to check the diagnostics to make sure the full bucket sensor is working properly. This varies by model, but there is usually a blinking LED in the freezer that tells you what's going on.
Mar 31, 2014 | Whirlpool GZ25FSRXYY
Ice maker is over filling
Ice maker has adjustment on right side of power head. If ice maker is inside on upper left, you can remove white cover from it and the adjusting screw in on right. Turning counter-clockwise will decrease fill by 1/2 to 3/4 of ounce. Sounds like a small amount, but ice make only uses 4 ounces per fill. If this does not fix, try replacing fill valve. If ice maker ice bin is in the freezer door, you have to remove cover to ice maker in the top of freezer. Ice maker is screwed into top of freezer and need to be removed to take off cover to adjuster screw. same procedure for reducing water flow time as above.
Thanks
Aug 12, 2009 | Whirlpool Refrigerators
Ice Maker Overfills With Water
Jul 23, 2009 | Whirlpool ED2FHEXN Side by Side...
Side by side Whirlpool fridge with ice maker as well as ice and water dispenser in door. Dispenser works for both ice and water so water is getting to the system, but the ice maker has suddenly stopped...
If you have a whirlpool icemaker inside of your freezer (I've read on other posts that whirlpool ice makers are installed in various makes and models), there is a white cover over the ice maker (it's square). Remove the square cover with your hands or stick a flat head screwdriver in the side until you can pull it off.
Once the white square cover is removed, you should see a white wheel with gear teeth. In the middle of the white wheel is a plastic snap that should be holding it in. I noticed that one of the little plastic snaps was broken...which caused my "no ice" problem. A simple test is to push the white wheel toward the icemaker. If the wheel starts turning, you have found the problem. You see, behind the whhite wheel are metal contacts that need pressure for the ice maker to work. Without the center plastic snaps holding it it, the pressure is gone...and so is the metal to metal contact.
I previously called Whirlpool, searched all of the web...to no avail. Every other solution was "check for ice blocking the water tube" or "replace your water filter". That's all balony. If your regular water dispenser is working, you don't have an ice problem. And if your water dispenser is working, you don't have to change your fitler either.
If you realize that the little white wheel is the culprit, just google "whirlpool module" and you will see it for sale. I found one on ebay for under thirty buckaroos with free shipping.
Hope this helps.
Mar 24, 2009 | Whirlpool ED0GTQXMQ Side by Side...
WATER AND ICE INSIDE MY FRIG
Most likely whats happening is you have a frozen drain for the defrost cycle. here are step by step instrutions for repair
  • Unplug refrigerator
  • unload food from freezer
  • remove icemaker if present (there are 3 screws remove the one on the bottom and loosen the 2 on top of icemaker then lift it off the 2 screws unplug from wiring harness)
  • remove 2 screws holding rear cover in place
  • move cover to the side or remove from unit altogether
  • defrost any and all ice from bottom of freezer and aluminum drain pan that is now exposed
  • flush drain hole that you will see once ice is cleared with warm water. (sometimes I use a large syringe or turkey baster to forcefully flush hot water thru the drain tube)
  • reassemble in reverse order
These are general instrutions for most top freezer refrigs. but if you need more specific directions dont hesitate to ask Thanks Peyton
Mar 21, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water keeps gathering on shelves and occasionally
sounds like you have a frozen defrost drain. This is a fairly easy repair you can do yourself.
that should fix you up. if you have any further questions leave me a comment here and I'll gladly help any way I can. thanks Peyton
Mar 11, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
container.
turned on.
Feb 19, 2009 | Refrigerators
Icemaker stopped making ice
remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure you hold the plastic insulation so you don't get bit if the ice maker starts cycling remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didn’t fill replace the water valves if the icemaker doesnt cycle and you may have to kind of twist the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
May 24, 2008 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
104 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
