Question about Icom Radio Communications
Icom ic 718
Turned the 718 on and it immediately went into scan mode and would not stop. Tried everything.
    Novelist:
    Scholar:
  • 114 Answers
Check online (do a Google Search) for the IC-718. Very likely you can download a copy of the owner's manual
Posted on Jan 03, 2015
    Genius:
  • Icom Master
  • 1,795 Answers
Try unplugging it the plug it back in.I am not up on ham but they are basically the same as CBso I would have to dig around to get an answer to the question .It may be worth your while to call icom to see if they can answer your question.
Posted on Jun 05, 2014
It stuck in squeck mode when you turn it on
Start with simple things first. If using a hand mic, ground it as if it were hung up in a vehicle. Now look for the squelch knob, it likely does more than 1 thing. Try it all the way clockwise, then counter clockwise as you turn it on. Please let us know on your progress.
Feb 20, 2016 | Icom Ic-718 Hf Transceiver
Hallo iam using a icom 718 on 28mhz up to 14mhz have a problem of a high swr reading but the antenna is fine then power drop away
Check the feedline to the antenna, and the antenna itself. High SWR means that power is being reflected back from the antenna. A good discussion of SWR may be found here: http://www.hamuniverse.com/wc7iswr.html
If you antenna is designed for 10M and your are trying to transmit 20M on it, there will be a significant mis-match. You may want to look at installing a better broadband antenna, such as an OCFD that will operate better on multiple bands.
Feb 18, 2015 | Icom IC-718 Base radio, HF, 100W
No response when switched on
There is an internal fuses in most of the radio's for the low power circuitry. Open the case and have a look. In the 706, it is on the PA board and is a 3AG style fuse. Do not replace this fuse with a higher rating than it already is. A higher current rating will damage the radio beyond economical repair if there is a problem. If the fuse is OK, then take it in for service. There is very little, if anything, that most hams can do at this point as the electronic components are too small to work on without the proper tools.
Jan 25, 2014 | Icom Ic-7000, 706, 703, 718, 78 Amp Relay...
Frozen screen first, then went blank
Restart in safe mode. Install Malwarebytes Antimalware. Scan. Choose to delete all infected files. Restart. Start again in safe mode. Uninstall all antivirus software you have. Install AVAST. Update virus definitions. Full scan or choose BOOT TIME SCAN. Post results here please
Oct 25, 2012 | HP Computers & Internet
My toshiba laptop keeps turning off
This issue could be caused by any of the below possibilities.:::::
Heat related issue. >> Hardware issue or error. >> Computer virus. >> Issue with operating system. >> Other failing hardware
.... >>Two important things that you should do to fix a laptop which keeps shutting down are::::
1- Scanning computer to eliminate malwares, spywares and the viruses from your laptop.
2- Repairing and cleaning Windows registry. Run a system utility tool like ReginOut to repair corrupt registry and windows files.
Apr 16, 2012 | Toshiba Satellite L750 Notebook
How to program an Icom IC-R5 handheld scanner
to store a fcy press BAND to go to your fcy range ie 118.000 airband
dial your fcy ie 127.900(shanwick ocean area control) press and hold V/M for 1 sec, small numbers now blink, dial the memory slot you wish to store into ie 001 then press V/M again for 1sec and this will store 127.900 into mem slot 001. make a list:-
mem number / fcy / mode(am - fm) / station / bank
to prog a fcy into a "bank", press V/M for 1sec - blinking mem numbers - dial mem number ie 001(127.900) press MODE - "bank" flashes past-
-- -- -- -- 001 shows, turn dial to show A-00 this is the first "bank", pressing BAND scrolls through all the alpha "banks" - choose one.. ie A-00 (for airband..) press V/M this puts mem 001 into "bank" A mem slot 00, there are 100 slots in each letter 00 to 99. do this to any fcy you want to scan as a group.
to scan a bank press V/M - small numbers appear -
press BAND to scroll through any "banks" you have created ie A B C D etc (only banks with fcys in will display), press MODE -"bank"- press MODE again and you will start scanning just that "bank" of mem slots.
MODE starts and stops the scan... each letter holds 100 mem slots.. happy scanning!!!
Sep 22, 2009 | Icom IC-R5 Handheld Scanner
Radio Communications Logo
167 people viewed this question
Top Icom Radio Communications Experts
peter0911
Steve
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
