Question about Intel Motherboard
When start on asus motherboard 1beep+1beep sound total 2 beep sou
When start on asus motherboard 1beep+1beep sound total 2 beep sound no display
model no.945
  • Intel Master
  • 4,806 Answers
The problem is the system memory, get yourself a clean, dry soft paintbrush, remove the power cord from the back of the unit, remove the memory and clean the brass contacts on the memory modules, next clean the memory slots of any dust that may have built up and reseat the memory.
Put the side panel back on and plug in the power cord then power up.
Good luck
Posted on Jun 19, 2009
2 short beep continue after 30second
AMI BIOS:
1 beep - System boot successfull
*1beep - Refresh failure - (NO VIDEO) memory refresh failure (bad memory)
2 beeps - Parity error - bad memory
As it is a Memory problem, the first thing to do is gently remove the memory chips (there maybe 2) and firmly re-insert them, to make sure there is a good contact.
If it still Beeps on re-Booting, then you need to go to a supplier to get them tested, or re-placed.
Source: http://forum-en.msi.com/
Author: Svet
Jan 22, 2014 | MSI FM2-A85XA-G43 Desktop Motherboard -...
Ram beep but no display bios jumper is clear stat bios jumper is normal then no start machine
Please see this as reference
Continuous long beeps-RAM error
2 short beeps- BIOS error
1 long and 8 short beeps- Display Card error
1 long beep after few seconds 2 short beeps-FDC error
1 long beep after few seconds 1 short beeps-FDC is Ok
1 long beep and 2 short beeps-Display Card Error
Most probable cause is Ram memory, please try removing modules and reinserting, also try using alternately just one of them to determine which one is defective.
Mar 04, 2011 | ASUS P4GE-MX Motherboard
1 beep 5beeps 1beep 1beep
Try remove the ram and clean the part and put it back ,.
Dec 02, 2009 | Intel Server Board SDS2 Motherboard
ASUS K8S-MX PC powers up but no display on monitor and no error codes. Hard drives spin and sounds as if it is in boot routine
OPEN UR CPU AND OUT UR RAM FROM MOTHERBOARD AND START UR PC WITHOUT RAM IS IT BEEP OR NOT IF IT BEEP THEN CLEAN UR RAM AND RE INSERT IN MOTHER BOARD AND THEN START UR PC IS IT OK
IF NOT THEN PICOUT BATERY CELL 2032 FROM MOTHER BOARD AND THEN START UR PC
IS IT BEEP WITHOUT RAM AND CELL IF YES THEN CLEAN UR RAM AND RE INSERT IN MOTHER BOARD AND THEN START UR PC
IF IT IS OK THEN CHANGE UR BATTERY WITH NEW ONE
IF UR PC BEEP WITHOUT RAM BUT NO DISPLAY WITH RAM THEN CHANGE UR RAM WITH NEW ONE.
Jul 01, 2009 | ASUS K8S-MX Motherboard
ASUS P5GL-MX is not showing display power button is pressed
Pls go through the steps given below...
1. Ensure that the 12 volt 4 pin connector is fixed correctly
2. If there any Beep sounds(Long beep=Memmory complaint)
3. Try replacing or re-installing RAM and HDD
4.Try with another SMPS (Display will not come if 3.3V,5V....missing)
Mar 01, 2009 | ASUS P5GL-MX Motherboard
No boot and beeps
The exact fault code indicates RAM or a problem accessing the RAM.
Check that you are using recommended/Approved RAM as ASUS and ASROCK (the budget arm of ASUS) are notoriously fussy with RAM.
If it all checks out then your northbridge could be dead and it will probably be scrap.
Feb 21, 2009 | Asrock K7S8XE Motherboard
2 beep sound on restart in asus motherboard
memory problem or graphics problem change them
Jan 14, 2009 | Intel Motherboard
Pc is not booting and no display in monitor
First, try resetting the CMOS. If it is not working, replace the RAM. Could be a damaged RAM
Sep 11, 2008 | ASUS (P4BGV-MX) Motherboard
Asus Mother Boards - Beeps, Boots, Windows Login Sound, No Image
Yaa you are right. try to boot in Safe Mode and check out driver for display, otherwise you have to change your display card.......
thanks
iqbal
Apr 02, 2008 | ASUS A8N-SLI Deluxe Motherboard
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
