Question about Jandy Laars Lt 400,000 Btu Heater
Lars LT400 works in pool mode but will not stay on in spa mode. Press sensor stays closed(0 ohm) in both modes
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Jandy Master
  • 1,448 Answers
Need more info is it using the 4 pin red plug or using pool and com?
Posted on Dec 01, 2014
PartsCenter
  • 125 Answers
SOURCE: Jandu Aqualink Pool/Spa Controller RS6
AQUALINK GUIDE BOOK
Posted on Feb 26, 2009
  • 5 Answers
SOURCE: I have Jandy RS4 system with 4-button poolside
Pull the cover off the control panel. You will probably find a button which would be accessible from outside the panel with a paper clip or pencil but is unlabeled. On the board itself by the button, in small letters it should say "reset". Push the button and see what happens.
Posted on Oct 09, 2009
  • 246 Answers
SOURCE: Jandy Lite 2 does not ignite
burners are plug with spider get a wire and bended get it inside the orifices where the gas come out every single one than try now ? magic heater comes on
Posted on Oct 16, 2009
  • 990 Answers
SOURCE: JVA 2440 rotates continuously in spa mode
If you remove the handel and open thr top of the actuator you will see a set nut on the center of the shaft that you use to set where the valve stops. If this is tight then you may have a bad micro switch in the unit and you should replace the actuator. Good luck.
Posted on Jan 20, 2010
  • 5 Answers
SOURCE: I have a Aqua link
its most lke a problem called ghosting which mean your spa side remote will turn system to spa mode or turn other thing on such as the blower or heater will come on without manualy turning it on to fix this problem open up outside control panel and unplug the four connection wire hooked on a red bar plug tape the ends after unplugging so nothing will get shorted also turn of breaker as well so guarnting no shortage
Posted on Feb 01, 2011
Dream maker spaX400. has a green spa control panel keeps flashing SL. I tried setting it to F2can't get it to stay thereIt keeps going back to SL can change the temperature up down temp ofstays at 91
It is in sleep mode. Press your mode button until it says sp again then hit temp up button or whatever button you use to change the f1 f2 f4 messages.. it should change to SD or ST or SN for standard mode...
May 06, 2015 | Pool & Spa
I have an EC display on my panel
That means your "Heating" mode is in Economy! Without knowing what make our model spa you have, or the manufacturer of spa controls, difficult to assist in telling you how to switch to other modes. Maybe try this:
Pressing the "Temperature" button and then immediately the "Light/Jets" button may change the system back to Standard? Once you press those buttons, the "Ec" code comes on and stays on (flashing), and then you can press the "Light/Jets" button to toggle between Standard and Economy and maybe SL - which is Sleep modes.
Good luck
Feb 22, 2015 | Pool & Spa
Vx salt chlorinator has suddenly stopped working fully, when on manually it just stays in sanitising mode. Every thing is fine chemical wise and pool level but output of chlorine is not happening
look for corroded valving or white powdery residue thatgs got the piping/hardware plugged up..may need replaced if you cant brush it off..
Jan 06, 2014 | Pool & Spa
Valve actuator stay in spa position
Actuator might be bad, not getting 24 volts, bad switch, or needs maintenance and grease.
Manual with troubleshoot on following link:
http://waterheatertimer.org/Digital-control-centers-and-manuals.html#PE24
Apr 21, 2013 | Pentair CVA-24T Valve Actuator 2 port 24V...
Pool heater is not working properly
So I assume you have pressed the button by pool to select the pool thermostat? If this doesn't work sounds like another mother board problem, or try powering down the unit a few minutes then restart. IF you haven't pressed the pool button, the read this: The heater comes factory set at 78° F. for the pool mode and 100° F. for the spa mode. If it's in spa mode it's trying to get to 100F. Using the up and down arrows,you can set the thermostats to a minimum temperature of 65° F., or a maximum of 104° F. If you desire to heat only one
body of water, the thermostat is capable of an off mode. As an example, if you only wish to heat the pool and not the spa simply depress and hold the spa down arrow, and the thermostat will lower its setting to 65° F. then go to an off mode. Here is a link to your manual :http://www.pentairpool.com/pdfs/MasterTempOM.pdf
Jul 07, 2010 | Pentair 460732 MasterTemp Heater 250BTU ...
Hayward H250 FDP Pool heater won't stay lite
sounds like a flame sensor.remove ignitor assembly and clean with fine emory cloth or steel wool.when properly cleaned it should feel smooth for entire length of sensor
Jun 20, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
LARS LITE #LLG175N BURNER WON'T STAY LIT.
Make sure your pool filter is clean. Low water flow through the heater will be detected by water pressure switch
Jun 19, 2009 | Teledyne Laars Teledyne_ Laars Lite2...
Jandy Laars Lt 400,000 Btu Heater Logo
62 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
