Question about Maytag Neptune MDE5500AY Electric Dryer
Loud noise How do you remove the top of a magtag neptune dryer. Mine started making a loud squealing noise, that might be the belt. I do not want to force the top apart and damage something. Are there just clips that hold the top on or screws I do not see. thanks
  • 3 more comments
  • grandpa jim Nov 02, 2007
    Thank you very much. This is exactly what I needed and will help me greatly.
  • Anonymous Nov 23, 2007
    Hey SolutionGuy,
    Thank you thank you! Your directions for taking my dryer apart were right on and I was easily able to fix the problem. It was a sticky roller in the back. This was my first time trying something like this and you saved me $$.
    Thanks,
    FirstTimer
  • Anonymous Feb 24, 2008
    dryer makes loud noise when spinning
  • paigemadi Mar 22, 2008
    I have a mde6700azw dryer and it is making a loud scratching sound inside the drum is it possible for somthing to get caught inside?
  • Anonymous Dec 20, 2008
    I had the loud scratching noize > followed Solutionguy's procedure > found a nail from a pocket > took it out > vacuumed up > no noize! Thanks!
    President:
  • 331 Answers
First, UNPLUG YOUR DRYER! Now open the dryer door and remove the 2 screws at the door hinges... remove the door and set aside, then remove the 2 screws opposite the hinges. Grasp the front panel near the top, just below the top panel and pull it toward you... do this on both sides. Tilt the panel forward then lift it off of the lower clips.
With the front panel gone, you'll see a 5/16" screw just below the top panel on both sides, top left and right. Remove these and the clips too... now you can lift the top panel like the hood of your car.
To gain further access, remove the 6 (3 on each side) screws holding the front drum support/blower vent panel, then set this aside.
If you want to remove the drum... first, take a flashlight and look closely at how the belt is routed around the idler pulley and the motor shaft. (You'll have to re-route it for reassembly.) Reach in there with both hands, with one hand rotate the spring loaded idler pulley back to release tension off the belt, then with the other hand remove the belt from the motor shaft. Now lift and pull the drum out the front of the cabinet.
Check to make sure the rollers in the back rotate freely. You can remove the rollers, buff the roller shafts with emery cloth, lube the shaft with light oil (like sewing machine oil) and reinstall the rollers. Lube the idler pulley also. Rotate the motor by hand and listen for the squeak you described.
Also check the front drum support panel you removed earlier. The drum rides on this as it rotates... As you are looking at the drum support from the drum side, inspect the 10 o'clock to the 2 o'clock area closely. If the glides (teflon) are worn it'll squeak when it rotates.
Hope this helps. Oh yeah! Almost forgot.... the belt won't squeak at all. It'll be the motor, rollers or drum glides.
Posted on Nov 02, 2007
  • Tracy Farrell
    Tracy Farrell Nov 02, 2007
    Grandpa, also check the blower wheel. After you have the drum support panel off, you'll see the blower wheel (impeller) at the lower left. Make sure that it's not "sloppy" on the motor shaft... it must be tight. Also make sure that it hasn't slipped either forward (which will make it rub against the aluminum cover) or backward on the motor shaft (which will make it rub on the plastic housing in the back by the motor).
    Rotate the blower many times... look for "wobbling". If it wobbles at slow rotational speeds, imagine what it's doing when ramped up to operating RPM's! ( A wobble can be caused by a sock being sucked through there while it's running or a large chunk of lint, too! That'll throw it out of balance.)
    If this advice gets you where you need to be, don't forget to upgrade this to "Solved"... (we don't get paid for rankings, it lets us and future posters know how we're doing).
I also had a scraping/banging noise. A screw holding on 1 of the plastic baffles inside the drum had backed out and was scraping both the left and right side on every rotation. I tightened all the screws while opened up and vacuumed out excess lint in the area.
Posted on Feb 19, 2008
Thanks SolutionGuy. I opened up my Maytag Neptune dryer just as you instructed. I had a loud banging on the right hand side of my dryer. When I opened the top, I noticed one of the screws protruding from my drum. It had backed out somehow and on every rotation it banged the dryer housing as it scraped the right hand side. I tightened the screw, reassembled the clips, front and door and it works perfectly. I thought I was going to have to buy a new dryer this weekend.
Posted on Feb 03, 2008
Maytag neptune dryer makes loud noise on the right side when top dryer is on
The belt tensioner bushing could be shot or there may be a piece missing from the belt. Did you check the back for a removable observation cover?
Jan 05, 2014 | Maytag Neptune MCE8000AY Electric Dryer
My Magtag Neptune TL 6800 started making a horrible squealing noise then smoke started coming out of the washer. What do you the problem may be?
You need to replace the belt needed to spin the drum. It sounds to me like you may have been overloading the drum, putting too much stress on the belt. Over time, it has begun to " burn rubber" as it spins, causing smoke, or worst case scenario, the motor that turns the belt is locking up as the drum spins causing friction on the belt.
Aug 17, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Dryer making a loud squeaking noise
Hi, You probably will need the following parts to fix the squeal;
6-3705180 Idler arm $6.78
6-3700340 bearing $16.04
[2] 6-3129480 Drum roller shaft $5.53
[2] 12001541 rollers $22.04
33002535 belt $23.80
MAKE SURE DRYER IS UNPLUGGED BEFORE WORKING ON IT
Remove two screws at front bottom, pull front out toward you and remove wires from door switch and remove. Remove front bulkhead and drum. Check all of these parts I listed and replace as needed. Hope this helps
Jan 28, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Maytag electric dryer is making a high pitched noise
The squealing noise is from the belt tensioner. Replace the pulley only on the tensioner along with a new belt. The bearing in the pulley is causing the squeal. Sears will sell this in a kit. The top and the front panel of the dryer will have to be removed to replace these parts
Jul 16, 2010 | Maytag Dryers
Dryer makes a loud squealing when first started
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your belt has slipped off of the idler arm pulley.
If you have a front loading machine, Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor. Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear. Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Dec 05, 2009 | Dryers
Maytag Neptune dryer increasingly loud.
Sounds like you need new drum rollers installed, when they get old they squeak,squeal, and make loud bumping noises.
Sep 25, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Loud squeaky noise when dryer starts, noise stops after several minutes
I would replace the belt that turns the drum. It is probably wearing out and that is causing your noise.
Jul 14, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Noisy dryer......when engaged...making squeaking/squealing noise.
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Apr 09, 2009 | GE Spacemaker Washer and Dryer Electric...
Craftsman Tiller makes loud, shrill, squealing noise when tilling
Noise comes and goes sound like metal on metal not a belt squealing
Apr 03, 2009 | Craftsman Garden
Maytag Neptune MDE5500AY Electric Dryer Logo
2,794 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
