Question about Toro TimeCutter Zero Turn Lawn Mower Hourmeter Kit 1129763
Lawn tractor wont start with the key
I turn the key to the start position & it only clicks. I can feel it in the solenoid. I can turn it to the on position & jump the spolenoid it will start. Is my ignition switch bad?
    Champion:
  • 254 Answers
No, It sounds like you solenoid is bad. Just because it clicks does not mean current is going thru it. A Volt meter or test light can be used to confirm.
Posted on Apr 20, 2014
2 Suggested Answers
  • 6468 Answers
SOURCE: Toro ZTR won't start with key, I can jump across the solenoid and it will start and run fine, however, when I engage the PTO it starts snapping and popping like it's jumping in and out of bla
each lever has its own safety switch one of them has failed jumper each one to test them
Posted on Jul 11, 2012
Solenoid clicks but starter does not kick in to start tractor
Clicking Sound While Attempting to Key Start - Riding Mower
troybilt.custhelp.com/.../clicking-sound-while-attempting-to-key-start---r...
Jul 19, 2002 - Why does the tractor make a clicking sound and not start? ... Thesolenoid connects the battery to the starter motor when the solenoid is energized. ...It can click, but not make a complete connection. ... Starting - Riding Mower · Professional Shop Manuals · Basic Troubleshooting - Lawn & Garden Tractors.
How Do I Tell If the Starter Solenoid Is Bad on My Kohler ...
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
Most large Kohler engines on riding lawn mowers use an electric starting system. ... A bad solenoid can deny electricity to the starter motor and prevent engine startup. ...Lawn Mower Will Fire but Not Start · Replacing a Solenoid on a Craftsman Lawn Mower or Tractor · How Does a Starter Solenoid on a Lawn Mower Work?
My Bolens lawn tractor won't start. It just clicks when I turn ...
Dec 03, 2015 | Garden
I have 2000 john deere 420 and it wont turn over
The starting circuit is dependent upon the clutch safety ans PTO being off. Here are some steps to take:
1. Ensure battery is fully charged
2. Turn key on and turn PTO on then back off. Listen for clunk
3. Press clutch in fully and turn key to start position. If still no sound at all, hold key in start position and move clutch foot up and down, listening for solenoid click. If click but no crank, starter or solenoid or battery cable connection is bad. Start by wiggling cables, looking for any looseness. Next check solenoid and cables. If that doesn't fix it, starter or solenoid may be bad. There may be a fuse in the circuit. Check them out also.
if it cranks but doesn't start, you have a fuel or ignition problem. Good luck. Let us know what you find
Jun 22, 2014 | John Deere 420,1020,2010,2020,2510,2520...
Mastercraft 18hp B&S lawn tractor Won't start with key BUT am able to "hot wire" by srewdriver blade across starter solenoid - recently put in new - with ignition swith to "on". Good battery, good...
If you can cause the engine to turn over by shorting out the solenoid then it is OK.Your problem is probably that there is no power getting to the solenoid from the ignition switch. Connect a test light to the control wire at the solenoid and turn the key, if it doesn't light then follow the wire back to the switch looking for a break in the wire.The wire casing may not be broken while the wire may be open inside so feel for soft spots where wire may be broken. Check your ignition switch is sending power to this wire when in start position, the switch may be faulty.
Oct 08, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have had an electrical problem with this mower since ive had it. I have just changed the solenoid and switch and have looked at the wiring and switches all day and still nothing im getting power to the...
soliniod should have two small terminals one should get power when turn key to start position the other runs through ground curcuit which runs through break and pto switch most tractors wont start with out break switch working properly i would start with that first the i would go to pto switch. hope this helps
Aug 01, 2010 | Craftsman 42" Briggs Stratton 20 hp Gas...
I was riding the tractor mowing shut it off to get lunch returned 1 hr later would not start. I bought a new battery and had the starter checked all good still wont start. I get a click when i turn the key...
The starter solenoid sounds to be bad. Follow the + cable from the starter and it will lead to the solenoid. This is usually about $10. The battery produces power to the solenoid which then produces power to kick the starter over. The clicking is the contacts in the solenoid you are hearing.
May 17, 2010 | Yard Machines 155 Torque Briggs Stratton...
20 hp 42" craftman lawn tractor model 917.273482 I have fuel in the carb. but it won't start. I pour fuel in the carb. it will start and run until it uses that fuel. please help
Check to see if your fuel solenoid on the bottom of the carburetor is working. To do this, turn the key on and off a couple of times and listen for a "clicking" sound or with someone else turning the key, hold the solenoid between your thumb and fingers and see if you "feel" it clicking on and off
Sep 20, 2009 | Garden
Craftsmanlawn tractor will not start
Check for voltage at the solenoid when the key is in the start position.
The wire from the ignition should send 12 volts to the solenoid when the key is in the start position.
If it does not, you probably have a bad ignition switch.
(usually caused by water/corrosion)
Aug 10, 2009 | Garden
Craftsman zero turn model# 107.27774
If you are jumping the solenoid and it cranks but wont start leave the key in the on position and give it a try. Try replacing the solenoid and the wires conecting it to the battery.
Apr 24, 2009 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Toro TimeCutter Zero Turn Lawn Mower Hourmeter Kit  1129763 Logo
317 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
