Question about Garden
How do i replace a Piston set on my Stihl FS 160
Dolfoff
  • 148 Answers
SOURCE: stihl fs 45 ignition problem no spark
Disconnect the small spade terminal wires from the coil itself and test for spark. If you do not have spark replace coil. If you do have spark check those small wires for insulation damage and grounding. If wires are OK check kill switch.
NOTE: DO NOT START MACHINE with small wires unplugged! Only test for spark.
Posted on Sep 26, 2009
rwvanlue
  • 486 Answers
SOURCE: how do i set the carburetor on a Stihl FS-55
Over the past 8 years, the FS55 has had at least 5 different carburetors, and they have at least 3 different systems with different adjustments. Many of them do not have much of an adjustment and will not cure running problems. If you are experiencing poor running conditions, I would suggest some basic checks first. The spark arrestor screen is a big culprit on this model.
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Posted on Nov 23, 2009
john224
  • 1378 Answers
SOURCE: no manual, starting stihl fs 38 brushcutter
Here is the owner's manual.
Posted on Dec 17, 2009
SOURCE: Replacing trimmer line with blade for stihl fs 90r trimmer
If you bought the trimmer new there should be a rod about 6" long and 1/8" thick. Above the trimmer head below the trimmer gearbox there is a hole. You have to put the rod in that hole and turn the head until that locks it from turning.
From there you can screw the trimmer head off by hand, or a strap wrench if it's really tight. It may be left hand threads.
Posted on May 24, 2010
  • 316 Answers
SOURCE: replace start cord on stihl fs 36
hello sir, i'm guessing the rope is broken , first you'll need a c-clamp large enough to clamp the spooler, needle-nose pliers,a small tipped screwdriver and a new length of rope.the safest way is to remove the rewind assembly cover leaving the spooler in place in its housing. try to remove the old rope with neddle nose pliers ans small tipped screwdriver.next hand spin the spooler to achieve spring tension until stops back off enough to line holes up, place c-clamp to hold it in place,now try to fish the new rope into the hole in the knot recess,trying to guide it to the exit hole in the cover, ( it's easier to feed the rope if you singe the end of the rope with a bic lighter and form to a point )and with a small knot at the other end,pull the rope all the way until you can seat the knot into the knot recess.next tie a loop knot into the other end of the rope,so the end wont be recoiled all the way into the housing.with tesion on the rope gently remove the c-clamp and let the rope be drawed in.if it draws all the way to the loop knot, check to see if the spooler is full if so,( not too full where rope is binding ) pull the rope about a foot and re clamp the spooler and install the pull handle, if rope is too long you may have to cut to length. if it doesn't draw all the way to the loop knot and the spooler is not full than you may need to add anoyher revolution to the spring tension in the same fashion as described above.there are eisier ways but that evolves removal of the spooler and repacking the reciol spring.( not for the novice ). hope this helps,MrFixIt,thank you. `
Posted on Feb 18, 2012
How do i replace piston rings stihl ms170 chain saw
Part 4: Stihl chainsaw piston and cylinder replace / repair ...
? 13:54
https://www.youtube.com/watch?v=jCbMCkGqCIQ
Dec 15, 2011 - Uploaded by Andy Reynolds
Refitting the cylinder to the rebuilt crankcase on a Stihl 026 chainsaw. ... Part 4: Stihl chainsaw piston and cylinder replace / repair. .... Part 3 Stihl 026 chainsaw fitting the rings, piston, anti vibration mountings - Duration: 15:10.
Part 3 Stihl 026 chainsaw fitting the rings, piston, anti ...
? 15:10
www.youtube.com/watch?v=n9RbtjNc-nc
Dec 16, 2011 - Uploaded by Andy Reynolds
Part 3 Stihl 026 chainsaw fitting the rings, piston, anti vibration mountings ... Part 4: Stihl chainsaw piston and cylinder replace/ repair.
Oct 29, 2015 | Stihl MS171 12" Chainsaw
Stihl fs 85 weed eater trigger replacement
Take a look...
This may give you a little guidance?
also check here for all things Stihl...
Stihl Trimmer Throttle Outdoor Power Equipment
And this video...
And you may find this useful...
http://www.stihlusa.com/WebContent/CMSFileLibrary/instructionmanuals/FS80_85_Manual.pdf
Jun 10, 2015 | Stihl FS 85 Weed Eater
Need Stihl FS55 parts diagram. Thanks!
Standard carb settings for stihl equipment: screw both needles in, then turn anit-clockwise L- 1 full turn H-3/4 of a turn.
Aug 11, 2012 | Garden
Can't start new stihl weedeater fs 45
The Stihl FS45 has a particular way of getting started as do all the stihl products. We sell Stihl equipment in our store and service and repair them also. The normal starting procedure is to:
Be sure the switch is turned to the ON position which is the negitive sign (-). The (O) is the off position.
Press the primer bulb 3 times.
Move the choke lever to on.
Pull the starter cord three times only. If the engine fires, turn the choke to the off position and pull till it starts.
If the engine did not try to start during the first three pulls with the choke on, you must turn the choke off and pull till it starts.
Remember:Pulling more than three times with the choke switch on will flood the carburator on every stihl product thats on the market.
However, if the units still refuses to start, being its new and still under warrenty, return it to the repair shop that services Stihl products and they will repair it according to warrenty. All parts and labor should be honored at no cost to you. Please provide your receipt and serial number located on a silver tag located on the unit or the mechanic will get it off the unit when he works on it. Either way, it will most likely have to have a new carburator put on it. I hope this helps. Please comment back if this was helpful. Thanks; George
Mar 17, 2012 | Weedeater Garden
Where do I find a free repair manual for Stihl FS 46
If you have a nice Stihl dealer he (or she) might be nice enought to print you the specific repair information that you may need but no place that I know of offers the complete manual for free.
Sep 06, 2010 | Oregon Scientific Complete Carburetor for...
Stihl FS 45 throttle problem
its a self fix just get a new one it will come complete
Jul 24, 2009 | Garden
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
