Question about Cook's Essentials Smoothie Maker Work Top Blender
Want to order just base/motor of Cooks 5 in 1 power blender
2 Suggested Answers
mc1bean
  • 3053 Answers
SOURCE: Need replacement gaskets for Cooks
Hello, tomur
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about blenders andpossibly yours, from
repair to trouble shooting it. http://home.howstuffworks.com/how-to-repair-small-appliances5.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 28, 2011
Can you replace drive coupler on cooks XB9218WA
There would be no spare parts for that. Best plan would be to fix it with epoxy putty. Seal the lot together, if it fails again, you need a new one.
Jun 08, 2017 | Blenders
The motor base is not working. It was working fine for about a year, then just wouldn't work one day. Any suggestions on what I could do?
Check for power to the pcb, check for continuity through the motor. Once you have done that you will have an idea of where the fault lies.
Jul 11, 2014 | KitchenAid KSB560 5 Speed Blender
Problem with soup mate,all lights flashing but nothing happening
If this is a Kitchen Aid blender with the flashing lights then you will need to remove the motor base cover and check the motor for a circuit. If it is open circuit then either replace the motor or locate the thermal fuse (under some white tape and aluminium clip on one of the field windings) and either replace or bypass fuse if it is open circuit.
May 19, 2014 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
How to separate coupler
Assemble it with motor secure and base & feet on. Drill 3 or 4mm hole in edge of coupling Put screwdriver into hole on a large angle and whack the handle to undo the coupling. You are whacking it to turn in the same direction it turns when the motor is running.
Nov 20, 2013 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Cooks 5 in 1 power blender replacement cups
replacement cups can be found at amazon, click here and take a look: Amazon com cooks replacement parts cups. I hope this was helpful. Cheers
Nov 04, 2012 | Cook's Essentials Smoothie Maker Work Top...
Kitchenaid ksb560 won't turn on. No power at all...
Take the base off and check the motor for continuity.
Jan 08, 2012 | KitchenAid KSB560 5 Speed Blender
The blades stopped turning in the middle of blending a batch of hummus Its is a Kitchen Aid blender about 10 years old
Does the motor still work if you take the pitcher off of the base? If so, the rod that's in the blade assembly is probably corroded. The blades are connected to a metal rod that passes through a brass tube through to the piece that makes contact with the motor when you put the pitcher on the base. The grease wears down eventually and if you don't pulse and run the motor for a long time at once, the heat can corrode the bar and cause the blade to stop spinning. You can either disassemble the blade unit, or buy a new blade unit online. google blender parts and you can get one for $10
Dec 22, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Blender blade not turning, rotating piece on base not connected
this is getting more and more common there is a part between the motor and the drive gear that snaps for no reason . its job is to snap if the blades jam as a "fuse" to save your house from a overheating ,jammed motor . the problem is there are no parts to buy to fix this . if its new take it back to where you bought it . otherwise shipping it 2 ways for repair to the factory is sometimes as much or more as a new blender ........ i would recomend you do one of two things : go to a goodwill or other type shop and get a nice vintage blender , it will last forever ! or move up to a vita mix . its costly but it will realy last you ... this new made in china junk is just bad news even when it has the kitchen aid name on it . its still the same junk ..... good luck........ Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Mar 24, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Cook's Essentials Smoothie Maker Work Top Blender Logo
41 people viewed this question
Top Cook's Essentials Blenders Experts
Ross Keen
Tom Chichester
ray gallant
Are you a Cook's Essentials Blender Expert? Answer questions, earn points and help others
