Question about Locks & Locksmithing
Gate house lock #0399128
Instructions for instillation
Gate lock with FM350
Change the gate to n/c but if you have two devises connected you will have to run in series
Aug 19, 2016 | GTO Gate Lock Fm144, Automatic / Electric...
I have 2005 chevy tahoe my doors all licks but my liftgate door with window stays open use to lock w all my doors? I havent check anytjing yet? I cant lock it.
Here is how it works !
Liftgate Locking Operation
The lift gate will lock any time the vehicle is shifted out of park on vehicles equipped with an automatic transmission and at vehicle speeds exceeding 5 kph with manual transmission. This happens in conjunction with auto door locks if enabled or independently of auto door locks if the feature is disabled. This ensures that the lift gate is locked anytime the vehicle is shifted out of park or when the vehicle is in motion.
The lift gate lock relay supply and coil sides receive a constant voltage through the battery voltage supply circuit and the ECC fuse. The normally closed contact is connected to ground and the control side is connected to the body control module (BCM). A lock function will occur when a door lock switch activation, keyless entry lock transmission, auto door lock function or a lift gate lock function has been received by the BCM. The BCM will then ground the control side of the lift gate lock relay. This energizes the relay and allows voltage to be applied to the lift gate lock actuator lock control circuit. Since the other side of the lift gate lock actuator is connected to the normally closed contacts of the door unlock relay to ground, the lift gate will lock. When an unlock function occurs the BCM will ground the control side of the unlock relay and the rear doors and lift gate will unlock.
The BCM also runs diagnostics on the lift gate lock relay control circuit and will set DTC B3825 as current and also send a Class 2 message to the DIC. The DIC will display REPLACE LIFTGATE FUSE to inform the driver that a fault has been detected in the lift gate lock circuit and that the lift gate is not locked. Faults that will set the DTC and cause the DIC to display the message could be any of the following:
An open ECC fuse
An open or short to ground in the lift gate lock relay battery positive voltage circuit
A faulty lift gate lock relay
An open or short to ground in the lift gate lock relay control circuit
A short to ground in the lift gate lock actuator lock control circuit
A faulty BCM
May 14, 2016 | Cars & Trucks
For Gate House lock #0320437 should the tape be 2 sided? Seems like it's only one
THERE IS MOST LIKELY ANOTHER STRIP OF COVERING TAPE TO REMOVE TO REVEAL THE SECOND STICKY SIDE
Nov 04, 2014 | Locks & Locksmithing
How would I support a heavy wooden gate over uneven terrain?
You need to go back to the hinges. The is a house near me that has a gated drive that rises sharply from the road. Needless to say a normal hinge system would only allow the gate an opening of a few inches. The hinges on the gate allow all the movement required, it is your problem in reverse, but the answer is the same. That is where you need to get your ironmonger to look.
Jul 22, 2014 | Home Fencing
I have the Wood Door Frame dog gate and need the information on how to put it up.
Where are you planning to install the wood dog gate? In an exterior door or is it one of those gate type barriers that keep the dog from going into different parts of the house?
Dec 23, 2013 | Orvis Steel/Wood Doorway Dog Gate /...
I was looking at buying a stanley lock S836-171. Do you have to use the key every time you use the gate? Or is the key just to lock the gate when on vacation?
Hi maraleequanb... I do not know this lock personally but according to what I am reading you do not have to use the key every time, only if you want to lock it while your away. I have found this quote about it on a website along with some others you might be interesting in reading . Please take time to rate me thumbs up **************************************************************************************************************** "4.0 out of 5 stars Great Gate Latch - Installation Instructions lacking, May 4, 2010 By M. D. Heidenreich "DIYWhenICan" (Dayton, OH USA) - See all my reviews
(REAL NAME) Amazon Verified Purchase(What's this?) This review is from: Stanley Lockable Gate Latch With Dual Access (S836-171) [Misc.] I installed this gate on a 6' tall by 4' wide cedar gate latching to another smaller gate section. The smaller one has the post the larger side has the catch. The ability to push a button and open from the inside was the key selling point for me, being able to lock it is secondary but still will be nice when on vacation. We had one similar but we had to drill a hole and run a string and half the time manually latch the gate. This latch solved that problem completely. Gate now shuts and latches without a hitch. Now to the installation instructions: First - DO NOT USE the little grey PVC tube unless you have a hollow vinyl post - would of been nice if this was in bold print somewhere in the instructions. I tried to use it on the wood gate and spent 45 minutes on it before I finally found the teeny tiny writing saying not to use unless on vinyl. Second: I typically do well with pics. in instructions rather than a bunch of drawn out written explanations - not so with these instructions. From the look and my experience you could install on any gate set up so chances are you can make it work. I read other reviews complaining about the plastic and was prepared for that but was pleasently surprised with the solid feel and sturdy construction - time will tell but if it lasts two years, for the money, I'd say it's money well spent. My 4 stars are due to the instructions not the product. "
More quotes and pictures of the lock.
http://www.amazon.com/Stanley-Lockable-Latch-Access-S836-171/product-reviews/B002L2R7K6
Sep 12, 2011 | Stanley Garden
Mitsubishi Endeavor 2004. 1. the tail gate and the tail gate glass do not open 2. the AC drains into the driver flooring instead of draining outside to the ground. Why? And where is the output drain...
The door and the glass just needs some penetrating lubricant( WD 40 ), just a few squirt will do on hinges and locks!
The drainage hose would be under the passenger side( RiGHT FRONT SiDE) glove box, look down there, u will see a black hose from the center that houses ur A/C & heater housing! Lift up ur floor covering to see it clearly. check and clean the hose it might already been clogged by moss and dirt or dislocated thru the drain holes on the flooring! Hope that helps out! Taah!
Nov 18, 2010 | 2004 Mitsubishi Endeavor
Trying to remove built in Kenmore microwave 1994 #89755?
A family member removed it while I was away. Returned home a short time later & it was outside under the C/P. Thanks anyway.
A.J.M.
Dec 30, 2008 | Kenmore 62622 Microwave Oven
I need the instructions for instillation.
Here is the link to the setup sheet that came with your printer...
http://www.lexmark.com/publications/pdfs/z600/EMEA/setupsh.pdf
Hope this helps...
May 23, 2008 | Lexmark Z645 InkJet Photo Printer
Locks & Locksmithing Logo
77 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
